RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
reylafo, PastPresMike, RedBeard83, dfrybeck, ckinch1
70495 Registered Users
105 registered members (1978elcamino, AlaskaMike, 2015_PSD, aircooled, 2011335d, ABerns, 8 invisible), 2,310 guests, and 18 spiders.
Topics300,388
Posts5,174,772
Members70,495
The debate on Dex III vs Valvoline Dex/Merc for 4T65E #5317645 01/09/20 11:56 AM
J
jkennedy311 Offline OP
J
All,
In your personal experiences (hopefully with the same or a similar GM tranny) have you found the Valvoline Dex/Merc to register lower on the dipstick?
Back Story:
I have a 2003 Century with 60K miles and a 4T65E. Fluid was original Dex III and was near top of cross-hatches. I used a mighty-vac pump, and measuring containers to make sure I put in the same fluid I took out. The reading is now at the bottom of the hatch mark. Checked after warm up, several drives, shifting through all gears, on same level surface. I wasn't sure if Dex/Merc's formula has a lower expansion point that could explain this.
Thank you!
James
Re: The debate on Dex III vs Valvoline Dex/Merc for 4T65E [Re: jkennedy311] #5317656 01/09/20 12:19 PM
B
Bottom_Feeder Offline
B
If you've checked the level properly, is adding a smidge more fluid to get it where you want it on the stick not an option for some reason?
Re: The debate on Dex III vs Valvoline Dex/Merc for 4T65E [Re: Bottom_Feeder] #5317673 01/09/20 12:34 PM
J
J
It is, but this is more than a smidge, and I just didn't want to be over-filling the transmission. For some reason I've always run into problems when the tranny has more fluid put in than what it originally had.
Re: The debate on Dex III vs Valvoline Dex/Merc for 4T65E [Re: jkennedy311] #5317684 01/09/20 12:46 PM
K
kschachn Online Content
Online Content
K
I seriously doubt it. The coefficient of thermal expansion of any Group I, II or III hydrocarbon is going to be the same, and I looked up the values for a random PAO and it isn't that much different.
But it doesn't really matter because whether one has a different coefficient than the other is irrelevant. Determining the proper fluid level of your transmission is what's important regardless of what brand you happened to buy. If the level is low when checked properly then it should be brought to the correct level for the proper operation of the transmission.
And what exactly is the debate?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: The debate on Dex III vs Valvoline Dex/Merc for 4T65E [Re: kschachn] #5317782 01/09/20 02:42 PM
J
J
The debate was whether or not Dex/Merc had a different expansion point than Dex III in the 4T65E or similar tranny's. Thank you so much for filling me in on this information, I'll add more.
Re: The debate on Dex III vs Valvoline Dex/Merc for 4T65E [Re: jkennedy311] #5317792 01/09/20 02:50 PM
L
LeakySeals Offline
L
Its cold where you are, so thats probably why its staying lower. I would leave it a bit below the full hot line. Wait till summer to check again.
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: The debate on Dex III vs Valvoline Dex/Merc for 4T65E [Re: LeakySeals] #5318333 01/10/20 12:57 AM
G
GMBoy Offline
G
THIS ^^^
Re: The debate on Dex III vs Valvoline Dex/Merc for 4T65E [Re: LeakySeals] #5318455 01/10/20 07:34 AM
J
J
Thank you.
Re: The debate on Dex III vs Valvoline Dex/Merc for 4T65E [Re: jkennedy311] #5318889 01/10/20 04:39 PM
N
nascarnation Offline
N
Unless you can measure the oil temp with some accuracy, it's difficult to compare the two fills.
There's a temp sensor in the valve body you can read with some scanners, or an alternative is to look at the pan with a laser temp gun.
