30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
PastPresMike, RedBeard83, dfrybeck, ckinch1, EAC1
70494 Registered Users
106 registered members (2011335d, 53' Stude, 67ZL1, 2015_PSD, 28oz, 1978elcamino, 9 invisible), 2,171 guests, and 16 spiders.
Topics300,385
Posts5,174,704
Members70,492
How to clean Fridge condenser coils #5317465 01/09/20 08:00 AM
stockrex Offline OP
Is there an easy way to clean the dust off a fridge condenser coils?
I spend an hour plus with scrapes all over my arm with a small bottle brush, could not get to the right half of the coils, arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrgh.
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: How to clean Fridge condenser coils [Re: stockrex] #5317471 01/09/20 08:09 AM
Schmoe Offline
Depends on what kind of fridge you have. Mine has a bottom front cover that comes off and then I attach a vacuum tube to it and let it suck all the dust/hair out. I've had some that have a bottom cardboard like cover that you unscrew and that gives easy access to the coils and compressor.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: How to clean Fridge condenser coils [Re: stockrex] #5317473 01/09/20 08:09 AM
O
Oily_Thing Offline
O
Go to Lowes and get a specially designed brush for cleaning the coils. They are back in the appliance section. It looks kind of like a bottle brush, but the brush is a foot long on a two foot handle.
2020 Nissan Rogue SV AWD
2015 Dodge Durango Limited 3.6
Re: How to clean Fridge condenser coils [Re: stockrex] #5317475 01/09/20 08:13 AM
eagle23 Offline
I just vacuum them from the front and the back, though it would depend how accessible they are. Any vac can do, so nothing special needed since it's just dust.
One thing I cobbled together was an extension of the vac hose to reach well into the coils since space was tight vertically. It was a PITA to make and only moderately successful.
Too, the cleaning does not need to be perfect with all coils spotless [unless one is BITOG OCD ;o) ] for the fridge to work better. Good enough gets the job done unless (see previous BITOG disclaimer)
Re: How to clean Fridge condenser coils [Re: stockrex] #5317484 01/09/20 08:20 AM
stockrex Offline OP
I have the brush and it does not do SHHHHHHHHHHHHHHHHHesh for the areas away from the large holes.
I even opened the back of fridge and I could not reach most of the coil.
Re: How to clean Fridge condenser coils [Re: stockrex] #5317486 01/09/20 08:20 AM
L
Lou_Boyle Offline
L
Quote
Glad to know somebody does make a tool for this. My current fridge has tight spacing between the coil layers and I have to use a wet paper towel wrapped around a yard stick to be able to get to the back.
Think carefully about what you are doing, but be decisive. The road of life is paved with flat squirrels who couldn't make a decision.
Re: How to clean Fridge condenser coils [Re: stockrex] #5317492 01/09/20 08:26 AM
CT8 Offline
Years ago when there were intelligent engineers, the coils would be on the back of the fridge or a Ford pickup engine could be repaired with out cab removal.
2015 F150 2.7
2018 F350 6.2
Re: How to clean Fridge condenser coils [Re: CT8] #5317506 01/09/20 08:38 AM
H
HemiHawk Offline
H
Engineers are more intelligent than ever. Its the bean counters and corporate greed keeping things from lasting forever. Planned obsolescence is fun smile
I just use a soft brush and some water to clean mine from time to time. With pets and it being close to the floor they get gunked up.
2015 Mustang GT
2017 VW GTI sport
2001 Grand Cherokee
1995 Mustang GTS
Re: How to clean Fridge condenser coils [Re: stockrex] #5317589 01/09/20 10:43 AM
stockrex Offline OP
soft brush it is
but how does get to the inside of the rear coils?
Should I raise the coil side and reach from the bottom?
Re: How to clean Fridge condenser coils [Re: stockrex] #5317601 01/09/20 11:10 AM
N
NO2 Offline
N
If you have coils on the bottom use a compressor to blow out the dust from the rear.
Re: How to clean Fridge condenser coils [Re: stockrex] #5317660 01/09/20 12:21 PM
B
bullwinkle Online Confused
Online Confused
B
I brush clean the front ones & generally blow the rear ones out with an air tank, a wet towel over the air inlet opening catches most of the dust & dirt.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: How to clean Fridge condenser coils [Re: stockrex] #5317665 01/09/20 12:28 PM
F
Fitter30 Online Content
Online Content
F
Shop vac, old damp towels and air compressor with blow gun with a 1/4" copper or aluminum tubing on the end 18" long. Pull fridge out , roll the fridge back over towels with compressor off shop vac running short bursts of air. Vac picks up alot of dust towels pick up the rest. For something that needs service the manufacturers really don't care about shorten the life of the equipment and most people just the grill in the front get washed if and when the water filter clogs.
Re: How to clean Fridge condenser coils [Re: stockrex] #5317712 01/09/20 01:06 PM
J
JMJNet Online Content
Online Content
J
Get an air compressor to blow the dust and a vacuum cleaner to suck the dust being blown so it does not go all over the place or at least minimize it.
30 to 40 psi should loosen all those dust in unreachable places.
  • 2017 Toyota Sienna
Re: How to clean Fridge condenser coils [Re: stockrex] #5317723 01/09/20 01:25 PM
P
PandaBear Offline
P
I bought a brush off ebay (sort of like a giant pipe cleaner attached to a handle) and use that to brush the dust out of the bottom of my fridge. The problem is a lot of it got pushed to the back of the fridge and I can't get it out.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: How to clean Fridge condenser coils [Re: stockrex] #5317726 01/09/20 01:26 PM
O
Oldtom Offline
O
I use a shop vac with an 18 inch length of 1/2 inch CPVC pipe duct taped into the hose. A bright LED flashlight lets you see what to clean. I also have the special taper brush for loosening dust. Together, they work well on my frig. Years ago I tried cleaning my first frig with compressed air. I ran an air line from the basement compressor and went to work with an air gun with copper tube extension. I heard screams of wifely outrage and turned around to see a kitchen full of gray haze. I still hear about that periodically.
Best to capture the dust rather than spreading it around :-)
