oil extractors manual type
by passgas55 - 02/24/20 06:14 AM
Tesla Disrupts German Economy
by Y_K - 02/24/20 01:53 AM
Difference in Valvoline Asian red offerings?
by MichaelRS - 02/24/20 01:51 AM
RV's . give me the good and bad of owning one
by WhyMe - 02/24/20 01:36 AM
Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
S&W 38 Special
by BlueOvalFitter - 02/23/20 07:23 PM
Oil Life Monitor question
by Mark72 - 02/23/20 07:06 PM
Any member a tax accountant ?
by mjk - 02/23/20 07:00 PM
Driven oil delivered after 6 months
by luna - 02/23/20 06:48 PM
M1 209 VS M1 209A
by BlueOvalFitter - 02/23/20 06:19 PM
Sig P516 - my take
by stockrex - 02/23/20 05:45 PM
Advise for Euro E36 M50 engine
by Lucase483 - 02/23/20 05:43 PM
Those with 5.3's weigh in
by Speak2Mountain - 02/23/20 04:26 PM
wix 2019 sienna oil filter cartridge fitment
by s2krunner - 02/23/20 02:19 PM
Urban Carry G3
by Gebo - 02/23/20 02:16 PM
Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Bama65, wjamyers, L00btech, Lucase483, Chaucha
70791 Registered Users
77 registered members (askani79705, atikovi, 2002 Maxima SE, 2015_PSD, AZjeff, 97K15004WD, 6 invisible), 1,572 guests, and 22 spiders.
Topics301,854
Posts5,204,055
Members70,791
Remote start kit for many Fords #5312013 01/03/20 09:27 AM
dnewton3 Offline OP
Global Moderator
Global Moderator
Our 2018 Taurus was totaled recently, and so the remote start kit is available to someone else. Because we replaced it with a used 2017 Fusion, this particular kit will not transfer to our "new" car.
Here is the kit:
https://www.12volt.solutions/produc...honk?_pos=4&_sid=af7507411&_ss=r
Although is says "Taurus" it actually will cover a WIDE variety of Ford vehicles. See the second page for all the cars/trucks it would work on: (I will include a partial list)
https://cdn.shopify.com/s/files/1/1705/6595/files/FRD-6-MAIN.pdf?11829941645779531256
F-150s
Superdutys
Focus
Fusions
Flex
Taurus
Explorer
Mustang
Escape
There is absolutely nothing wrong with it; it works fine and did work even after the car was totaled. We only just installed it after Thanksgiving a month ago; it was an early Christmas present to my wife. After only a few weeks of use, she totaled the Taurus.
The kit is 100% plug-n-play. There are no vehicle wires to splice or cut into to make the remote start function. I removed it as quickly and easily as I installed it. Depending upon vehicle, it would take anywhere from 5 minutes to 20 minutes to install, only because of the wire routing you may choose to do for your particular vehicle. You will need two OEM keys to program the unit to your car; if you don't have two keys, you have to send it back to the company so they can program it directly.
I am negotiable on the price; PM me if interested. Shipping would be negotiated based on destination.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Remote start kit for many Fords [Re: dnewton3] #5312158 01/03/20 11:49 AM
R
rideahorse Offline
R
I have Fords and I don't need this. I applaud you for offering this to someone.
Re: Remote start kit for many Fords [Re: dnewton3] #5312637 01/03/20 09:06 PM
A
AdRock Offline
A
For anyone thinking about buying this. I have a 12v solutions no honk kit on my F150. It's a good quality product.
2018 Ford F150 STX Crew Cab 5.0
2002 Ford Mustang GT 4.6
2016 Ford Escape 2.4
Pennzoil Platinum 5w30 in all 3
Re: Remote start kit for many Fords [Re: AdRock] #5315941 01/07/20 03:36 PM
A
atikovi Online Content
Online Content
A
Aren't late model Fords already pre-installed with remote start and just need a hood switch and some programming to activate it? On my 16 Taurus I used Forscan to activate and got two remote keys off Ebay.
Re: Remote start kit for many Fords [Re: atikovi] #5317427 01/09/20 07:08 AM
dnewton3 Offline OP
Global Moderator
Global Moderator
It sort of depends ...
I did something similar to what you did, with my truck. I have a 2018 F-250 that is an XL; pretty darn basic truck. The OEM remote start does require that a hood switch be present, but that may or may not be in your vehicle depending upon vehicle build sheet. My truck had one because I had the upgraded Power Equipment Group (power windows and locks, under-hood light) and it included the hood switch. I added the OEM remote start kit to my truck; I had to buy the OEM intercept/program module; it plugs in between the OBDII port and the harness. Then I use the OEM key fobs in a specific sequence. But to make the OEM hardware active, I also did what you did; I had to go into the truck BCM program (using the "ForScan") and toggle some permissive inputs to acknowledge the hardware as being present, and then instruct certain options to display on the dash for selection modes.
Our 2018 Taurus SE (the one I'm offering the kit from) did not come with a hood switch, but the aftermarket kit (12volt.solutions) didn't require that to be present like the OEM kit does. That is why I chose the aftermarket kit for the Taurus; less cost and stuff to add. But, the aftermarket kit installs in a similar manner (not exactly the same, but close to it). And then you have to program the module to the BCM recognized key list via the OEM key introduction task. It may sound complicated, but it's super easy and there are plenty of vidoes out there how to do this. The installation takes longer than the programming; the programming only takes about 30 seconds if done right. I looked into using the Ford OEM remote start, but there were several things I'd have to buy (hood switch, hood switch harness, RS module). I didn't find anyone with good info as to how/where the hood switch was located or where the harness should be routed. In the end, I just determined it was easier to use the aftermarket kit instead; less cost and complexity of install. Was your Taurus a model that included the hood switch? SEL, Limited, etc? The SE's didn't come with the hood switch nor the RS module, at least not in the 2018 models. if you had a premium Taurus model, it's quite likely that it may have come with that stuff and just needed to be activated. But if that stuff is not present (and it's not in all Taurus models), it's just cheaper/easier to use the aftermarket kit. And for those not familiar with ForScan, or uncomfortable in modifying their BCM, the aftermarket kit is "plug-n-play" with no need to enter the vehicle BCM language, because the aftermarket kit uses the multi-key program mode to accept the aftermarket module as a permitted transmitter unit.
