Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward, MrH1325
70486 Registered Users
97 registered members (aquariuscsm, Alex_V, angeloc, 2004tdigls, 25ring, Alfred_B, 10 invisible), 2,074 guests, and 27 spiders.
Topics300,340
Posts5,173,704
Members70,486
Most Online3,825
Jan 19th, 2020
Neglected Prius - Kreen or not Kreen? #5317310 01/09/20 12:59 AM
W
wlai Offline OP
W
The Prius was/is driven by a kid and he hasn't taken care of it. Around 150K it started losing some oil. Kid let the oil ran low a couple of times (Twice the red triangle lit up briefly when at the bottom of a steep hill briefly, so the oil was sloshing around just enough to not reach the pickup, presumably, for a few seconds). Told him to top it back up after it happened, both times. The bottom of dip stick has varnish marks on it. It's now 180K.
I just did an oil change and the oil came out very dark; it's been baking in there for too long. I did an oil change and put in Penzoil Platinum High Mileage Synthetic 5w-30 & an OEM Toyota filter. As this was before I came to this forum, I used Seafoam in the crankcase at slightly higher than the recommended rate. With 4.2 qt volume there are about ~6-7 oz in there. It's been running for about 338 miles. I was hoping it would clean up whatever sludge/vanish has developed.
But now I know that Kreen would have been a better choice for what I was intending. Two questions: Do you recommend I do an oil/filter change now or later? And should I just stick with the detergent in the synthetic oil? Or should I use synthetic with Kreen for the next OCI?
Thanks for your recommendation.
Re: Neglected Prius - Kreen or not Kreen? [Re: wlai] #5317325 01/09/20 01:33 AM
dave1251 Offline
Monitor what happens from today forward. I would just use the synthetic of your choice for a 5K OCI and then reevaluate. Since you put Seafoam in the crankcase it may behoove you to do any oil change soon the last thing you need is sludge dislodging and starving the engine of oil.
don't use.
Re: Neglected Prius - Kreen or not Kreen? [Re: wlai] #5317360 01/09/20 04:44 AM
T
Triple_Se7en Online Content
Online Content
T
Stay with synthetic. 3K OCIs next couple times. Let the engine clean more slowly. Then re-evaluate before extending to 5K.
19' Hyundai Santa Fe 2.4 GDI - Valv Adv. 5w30 / OEM Oil Filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Pennzoil Gold 5W30 / OEM filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
Re: Neglected Prius - Kreen or not Kreen? [Re: wlai] #5317380 01/09/20 05:41 AM
Donald Offline
Seafoam in the crankcase is not a great idea, its a solvent.
I would try a piston soak with your favorite solvent and quickly change the oil. '
2015 Ford F-250 w/Powerstroke
Re: Neglected Prius - Kreen or not Kreen? [Re: wlai] #5317383 01/09/20 05:53 AM
D1dad Offline
Although my car went through mobil1 Hm like there was a hole in the block, it removed a varnish spot on the dipstick that had been there for yrs.
Re: Neglected Prius - Kreen or not Kreen? [Re: wlai] #5317389 01/09/20 06:09 AM
K
Kira Offline
K
Q: Besides Seafoam, Kreen and Berryman's product (I'd need to be informed as to which), what other solvents are used for a piston soak?
NOTE: This is a completely legit, straight question.
Re: Neglected Prius - Kreen or not Kreen? [Re: wlai] #5317403 01/09/20 06:20 AM
B
BLND1 Offline
B
Swap the oil now and use a name brand synthetic oil and filter from here on out. High mileage flavor if you feel like it.
Re: Neglected Prius - Kreen or not Kreen? [Re: Kira] #5317438 01/09/20 07:27 AM
D1dad Offline
I just did a piston soak on my altima with kreen. It blew some pretty nasty crap out of the engine. I let it set a full 24hrs and don’t believe it did anything, but then again my car was screwed up on the assembly line and not something I did when I bought it new. I did notice that the oil stayed cleaner for the first 700 miles than it did before. I sacrificed a cheap set of plugs fwiw. They say you don’t have to but when I pulled the new autolites out after 700 miles they were just plain nasty.
I did the kreen purge with new plugs (my ngks) were $20 a plug, changed the oil, ran the car 700 miles and changed the plugs and oil again. My son checked the oil after he got back to school and it used some oil...surprise surprise. If your car started using oil at some point I think kreen will help you. Unfortunately mine used oil from day 1 so nothing will help that.
Re: Neglected Prius - Kreen or not Kreen? [Re: wlai] #5317445 01/09/20 07:31 AM
D1dad Offline
In nissans defense, they said up to 1qt per 1k is acceptable and the car has stayed true to its word. No more no less, just 3/4 a qt every 1k. I’ve talked to others on forums whose same cars use none so I must have got a Friday car. I keep kicking around putting a low mileage yard motor in it but don’t know. The cars in great shape and I do have a 13 yr old so maybe I will.
Re: Neglected Prius - Kreen or not Kreen? [Re: Kira] #5317446 01/09/20 07:34 AM
P
pandus13 Offline
P
The Saturn guys used MMO also.
I thought TRAV posted in the past a very specific sequence on how to use kerosene on an engine bath.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Neglected Prius - Kreen or not Kreen? [Re: wlai] #5317447 01/09/20 07:37 AM
P
pandus13 Offline
P
The Critic and CR94, can we have your input please?
OP, I think the "PCV" Prius equivalent needs to be cleaned too. I think they have been reported as cooked after 100k miles. The priuschat forum has a write up about dis-mounting and clean up.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Neglected Prius - Kreen or not Kreen? [Re: Kira] #5317496 01/09/20 08:28 AM
B
BMWTurboDzl Offline
B
Liquimoly Proline Engine Flush reportedly loosens stuck rings when used as intended (not a piston soak).
435i
Re: Neglected Prius - Kreen or not Kreen? [Re: wlai] #5317520 01/09/20 08:55 AM
F
Farnsworth Offline
F
Change oil as normal and don't fix what isn't broke until it is known if there is actually any need for kreen and all that.
Re: Neglected Prius - Kreen or not Kreen? [Re: pandus13] #5317538 01/09/20 09:16 AM
M
Mad_Hatter Offline
M
I've used MMO. It's relatively cheap and got mineral spirits in it plus kerosene. Gunk makes Motor Medic and Valve Medic, which have solvents and a good no solvents flush is Lubegard Flush, I believe that one uses esters???
OP, Mobil 1 recommends doing 3~5k mile oci's for the next couple drain intervals when beginning to use their HiMi formula.
[Linked Image]
Re: Neglected Prius - Kreen or not Kreen? [Re: wlai] #5317542 01/09/20 09:21 AM
A
andyd Offline
A
I have used Seafoam for a hot soak overnight. beside an impressive smoke show, results were inconclusive. Berrymen's is a 1/3 the price and is a mixture of some real aromatic stuff. It is my first go to when a OPE carb starts acting up. I would use it for a piston soak,if i ever felt the need.
Thick oil is better grin2
