Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Hit 200K miles today!
by SLO_Town - 01/27/20 08:20 PM
Valve Cover at 304849 miles
by Marco620 - 01/27/20 08:17 PM
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
IslandOil, 01VFR, M10, H20ham, Meletz
70544 Registered Users
86 registered members (adams355, 01VFR, 77GrandPrix, 2010Civic, amblerman, 9 invisible), 2,348 guests, and 19 spiders.
Topics300,653
Posts5,180,361
Members70,544
ACdelco PF53 4100 miles #5317309 01/09/20 12:59 AM
K
KenshinHimura Offline OP
K
Ive got a few filters I need to upload from last year. Here is one from back in sept 2019.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Here is a cut ACdelco PF53 with 4100 miles off of a Saturn SC1 with Valvoline Maxlife 5w30 synthetic blend. Oil was refilled with the same oil and was replaced by a Bosch Premium filter
1997 Mitsubishi Eclipse Spyder Penzoil Plat 5w30 A Purple colored filter
2019 Hyundai Veloster Turbo QS 5W-30 OEM filter
Re: ACdelco PF53 4100 miles [Re: KenshinHimura] #5317320 01/09/20 01:19 AM
G
GMBoy Offline
G
Ecore, sloppy media, nitrile drainback valve, fiber end caps - just not a filter that I find worth it to use. Too many better choices.
Re: ACdelco PF53 4100 miles [Re: GMBoy] #5317355 01/09/20 04:27 AM
dave1251 Offline
How did you come to this conclusion? Using AC Delco filters causes a decrease in engine durability and longevity?
don't use.
Re: ACdelco PF53 4100 miles [Re: dave1251] #5317367 01/09/20 04:59 AM
T
Triple_Se7en Offline
T
Isn't that why better filters are available?
I quit using AC Delco at least 15 years ago, when GM started cutting costs to battle bankruptcy. The old PF 47s / 51s and 61s used to be better parts. Today's filters are inferior to those.
Heck, I even quit GM vehicles too, after buying them for 3-4 decades straight. The Ecore and Equinox I looked at are only available with TDGIs....... no thanks. Just wait until these newer models begin aging. GM will have to settle complaints as these engines turn to junk quickly.
Keep Your Dipstick Oil Clear
19' Hyundai SantaFe 2.4 GDI - Valv Adv. 5w30 / OEM Filter
20' Kia Soul X-Line 2.0 MPI / Pennz Gold 5W30 / OEM Filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
Re: ACdelco PF53 4100 miles [Re: KenshinHimura] #5317378 01/09/20 05:39 AM
M
MParr Offline
M
I guess those will work as well as entry level FRAM or STP filters. I think I will pass.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Professional OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Kendall GT-1 Max 5W30 FS & NAPA Gold 1348
93 Octane Non-Ethanol
Re: ACdelco PF53 4100 miles [Re: KenshinHimura] #5317385 01/09/20 05:54 AM
Sayjac Offline
I'll admit ecore spin on not my favorite filter, not huge fan of combo valve used in this one. That said, even with the less than great seam pleat area spacing, this one looks like it got the job done, @ ~4k miles. For ~5k mi fcis these likely ok. I'm thinking because this ACD for older GM, thus the combo valve. Newer for GM ACD use separate poppet type bypass.
Thanks for c&p.
Re: ACdelco PF53 4100 miles [Re: dave1251] #5317454 01/09/20 07:48 AM
4WD Offline
Somehow people are convinced that this stuff matters. The Fram OC has a new ADBV and now folks think that it is premium material. A good accountant at Fram probably knows more. The nitrile ADBV in ACD’s work fine … it’s holding back a bunch of oil every time I change them. Nitrile is used in thousands of industries … way more important stuff. The bonding on the ends is solid. The end devices fit tight in a very round bore. The spacing is perfect other than the seam area … well, tell the machine that’s a problem.Not.
Re: ACdelco PF53 4100 miles [Re: KenshinHimura] #5317482 01/09/20 08:18 AM
O
Oily_Thing Offline
O
Has an E-core filter ever failed on here?
2020 Nissan Rogue SV AWD
2015 Dodge Durango Limited 3.6
Re: ACdelco PF53 4100 miles [Re: Oily_Thing] #5317493 01/09/20 08:27 AM
Sayjac Offline
Member Oldtom had a similar question a couple years ago. Link shows responses.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4613360/Question_about_E_Cores
Re: ACdelco PF53 4100 miles [Re: Sayjac] #5317503 01/09/20 08:35 AM
4WD Offline
I did not see the mileage … Anyone see how many miles on the previous design failed ecore
Yes, they have changed the cage. Anyone think stray metal may have left the clean side of metal tubes.
Bet it has … I think the nylon cage is here to stay … they just had to learn how to make them.
Re: ACdelco PF53 4100 miles [Re: Sayjac] #5317509 01/09/20 08:40 AM
Sayjac Offline
Oci miles listed in Linctex originating thread in posted link. Member webfors user. Low miles
Re: ACdelco PF53 4100 miles [Re: KenshinHimura] #5317527 01/09/20 08:58 AM
A
ARCOgraphite Offline
A
The thing I don't like is that the very large core diameter on the e-core results in you room for media area which is of UTMOST importance on the these tiny form factor filters.
Never has issues with many iterations of branded and box store brand dissount champion labs filters until this.
My old 2007 Silverardo didn't like them for some unknown reason. Factory OE wasnt an e-core
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: ACdelco PF53 4100 miles [Re: dave1251] #5318319 01/09/20 11:56 PM
G
GMBoy Offline
G
My conclusion is based on the photos. I never once said it would decrease engine life or not function....I simply stated there are BETTER filters available and I choose to NOT use AC DELCO filters for that reason and that I had TWO fail on me in years past.
Re: ACdelco PF53 4100 miles [Re: 4WD] #5318321 01/09/20 11:59 PM
G
GMBoy Offline
G
Nitrile does matter past 5000 miles. Fram upgraded their lowest tier filter with the better silicone for a reason and it probably was not cost as much as perception of buyers looking for value and having the better silicone is a cheap move to achieve the "look" of a better filter.
I had TWO delcos fail on me where the NITRILE drain back valves failed and I had zero oil pressure at start up. TWO different filters, TWO different oil change intervals - stopped using them.
Re: ACdelco PF53 4100 miles [Re: GMBoy] #5318326 01/10/20 12:13 AM
Z
ZeeOSix Offline
Z
Fram most likely ungraded the ADBV to silicone on the EG as part of them increasing its use rating up to 10,000 miles to ensure the ADBV didn't with in longer use.
