Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
michWB, Brianhefty, JimBremer, Katdaddy, graphine
70470 Registered Users
45 registered members (2013ecof150, alchargo, Armkb, 2015_PSD, AurionX2, 7 invisible), 1,203 guests, and 25 spiders.
Topics300,305
Posts5,172,856
Members70,468
Most Online3,728
Jan 11th, 2020
Winch Disconnect Switch and Mounting Plate #5317000 01/08/20 05:37 PM
2015_PSD Online Content OP
OP Online Content
I waffled quite a bit on using a 500amp solenoid or a disconnect switch for the power to the winch. I did not want constant power to the winch and wanted a way to break the connection. I elected to install a disconnect switch so that I do not lose one of my auxiliary switches to power the solenoid and a solenoid would likely be one more thing to fail when it is needed most.
I am still in the mock up stages, but I thought that I would share what I have done so far. I made a template out of cardboard and traced it out onto a 1/4" thick T6061 aluminum plate grabbed from Amazon to mount a Blue Sea Systems disconnect switch also from Amazon.
Enjoy!
Raw Plate:
[Linked Image from iili.io]
Finished Plate:
Mock of Plate 1:
Mock of Plate 2:
Switch View 1:
Switch View 2:
Switch View 3:
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Mahle]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Winch Disconnect Switch and Mounting Plate [Re: 2015_PSD] #5317252 01/08/20 10:01 PM
E
E150GT Offline
E
Very cool. I like projects like this.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 68k 5w30
2006 Buick Lucerne CXL 3.8 40k 5w30
Re: Winch Disconnect Switch and Mounting Plate [Re: 2015_PSD] #5320959 01/12/20 05:27 PM
OP Online Content
All finished (just some minor cleanup remaining). Now I simply turn the switch on before heading off road and back off again when back in civilization.
Re: Winch Disconnect Switch and Mounting Plate [Re: 2015_PSD] #5320969 01/12/20 05:35 PM
4WD Offline
Yeah ~ I used to make sure they are out of the line of fire if the cable breaks … looks like you have done that.
I’d also recommend safety glasses and sturdy impact style gloves.
Re: Winch Disconnect Switch and Mounting Plate [Re: 4WD] #5320997 01/12/20 06:25 PM
OP Online Content
The controller is wireless and the cable is synthetic so less energy released if it snaps and I use snatch blocks and cable dampeners too (can never be too careful).
Re: Winch Disconnect Switch and Mounting Plate [Re: 2015_PSD] #5321003 01/12/20 06:29 PM
4WD Offline
Saw that non metallic when my wife forced me to look at Wranglers 😜
Is that made from Spectra ?
Re: Winch Disconnect Switch and Mounting Plate [Re: 4WD] #5321274 01/13/20 06:31 AM
OP Online Content
It is a Smittybilt 12K winch that came with synthetic rope, I am not sure who makes it for them.
Re: Winch Disconnect Switch and Mounting Plate [Re: 2015_PSD] #5321284 01/13/20 06:53 AM
4WD Offline
Ok … maybe Dyneema
