Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Hit 200K miles today!
by SLO_Town - 01/27/20 08:20 PM
Valve Cover at 304849 miles
by Marco620 - 01/27/20 08:17 PM
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
IslandOil, 01VFR, M10, H20ham, Meletz
70544 Registered Users
74 registered members (Antiquity, 4WD, 01VFR, ArrestMeRedZ, adams355, 8 invisible), 1,722 guests, and 19 spiders.
Topics300,653
Posts5,180,372
Members70,544
Centric GCX Rotors #5316948 01/08/20 04:39 PM
The Critic Offline OP
The finish reminds me of the smooth, semi-glossy finish found on Bosch Quietcast rotors.
The price is marginally more than Centric’s 121 ctek economy rotors.
The box that the rotors come in is also really really nice. Much nicer than the box used for their Premium Rotors.
https://www.apcautotech.com/getmedia/e930cfc7-04e7-4503-9dd5-8addbd725a4c/GCXSS.pdf
578BB2D8-2BE1-4E62-AC45-992589925219.jpeg8020EED9-57B7-4AA1-A346-3BCA7F78AA5B.jpeg3BEF2C20-1282-4BC9-9821-56D7C106CFAE.jpeg4650DB97-B238-4B73-AEC7-E0407F58040F.jpegB48FD756-D4F6-467E-8456-B8075D34566D.jpeg
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Centric GCX Rotors [Re: The Critic] #5316957 01/08/20 04:47 PM
K
Kira Offline
K
Did they shoot the paint into the cooling veins?
I was thinking about painting my veins black for heat dissipation.
Re: Centric GCX Rotors [Re: The Critic] #5316965 01/08/20 04:51 PM
B
bullwinkle Offline
B
The Rock Auto box just showed up 1 hour ago-proof that great minds think alike! For the rear of the Grand Marquis in my sig- [Linked Image]
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Centric GCX Rotors [Re: Kira] #5316969 01/08/20 04:58 PM
B
bullwinkle Offline
B
Vanes on mine look coated, as is the inside parking brake shoe area. Only the pad friction area doesn't have much on it.
Re: Centric GCX Rotors [Re: The Critic] #5316970 01/08/20 05:00 PM
B
bullwinkle Offline
B
The Ram 3500 in my sig is getting a front set of the eBay zinc plated drilled & slotted rotors from Brakemotive-they've done really well on the front of my xB for several years with no rust. This is going to be the test if coated can hold up as well.
Re: Centric GCX Rotors [Re: The Critic] #5316998 01/08/20 05:36 PM
A
Audios Offline
A
Same packaging and coating as Meyle, Textar Bosch, and the Raybestos recently posted. The spray pattern matches the Akebonos zinc coating, the others are more completely coated, and also comes packaged the exact same way. Ive used these a few times with no issues.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Centric GCX Rotors [Re: Audios] #5317043 01/08/20 06:16 PM
I suspect that many companies are using the same vendor in China.
Re: Centric GCX Rotors [Re: Kira] #5317195 01/08/20 08:54 PM
H
HangFire Offline
H
Must... resist... smart alek... remarks...
Various musings: http://hangfire.net
Re: Centric GCX Rotors [Re: The Critic] #5317230 01/08/20 09:39 PM
slacktide_bitog Offline
The partial coating is weird crzy
I read the PDF attachment. Apparently they like the partial coating for ceramic pads and full coating for semi-metallic. Most companies offer only the full-coated rotors for all pad types. I used the Power Stop Geomet coated rotors with Raybestos ceramic pads, and there are no problems.
Yes, I know the coating on the swept area isn't really necessary since it comes off the first time you hit the brakes
From the last pic you posted, it appears the inside hat where it meets the hub is uncoated mad
This isn't a problem where you are, but where rust exists, they will not come off the hub when it's time to replace them.
[Linked Image]
Re: Centric GCX Rotors [Re: The Critic] #5317575 01/09/20 10:16 AM
M
meep Offline
M
^^^ I like to paint that mating surface, especially the inner lip ^^^ and i've had good luck with anti-seize on the inner lip as well.
Note: THIN coat of paint, as to minimize effects of run-out from an uneven surface!
2018 F150
2015 crv (wifey!)
Re: Centric GCX Rotors [Re: The Critic] #5317617 01/09/20 11:27 AM
J
JTK Offline
J
Who doesn't appreciate a nice box.
Thanks for sharing the pics!
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Centric GCX Rotors [Re: The Critic] #5317631 01/09/20 11:40 AM
R
Redright9 Offline
R
Awesome!! I have used Cetnric rotors and pads for years now on multiple vehicles. I have continuously been impressed and happy with the quality and performance of the parts.
Re: Centric GCX Rotors [Re: JTK] #5318799 01/10/20 03:25 PM
1
1978elcamino Offline
1
I also appreciate a nice box!
2018 F150 5.0
2016 Ford Fusion 2.5
