Coolant flush machines
by Donald - 01/25/20 08:24 AM
How do you scratch the new car itch?
by supton - 01/25/20 08:07 AM
2019 f550 6.7
by ame299 - 01/25/20 07:49 AM
unthinkable problem after oil change
by NH73 - 01/25/20 07:37 AM
Anybody burn wood for heat? Advice please.
by dlundblad - 01/25/20 07:21 AM
2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
ame299, Whoop, coondog, steelbeams, Pete44
70522 Registered Users
104 registered members (1foxracing, 2010Civic, 53' Stude, 55hambone, 67ZL1, adams355, 11 invisible), 2,443 guests, and 19 spiders.
Topics300,525
Posts5,177,730
Members70,522
Ford PTU's and Oil choices #5316408 01/08/20 07:11 AM
M
Mekks Offline OP
M
I have a 2016 Ford Explorer Limited with the 3.5 NA v6. I need to change my PTU fluid. It calls for 75w140 but due to the huge heat load and small filling capacity of this unit I was wondering if you guy would advise using something different. Maybe a synthetic 80w140 or even Redline Lightweight Shock proof? The unit is known to hit 250-290F temps. I plan to change the fluid every 25k miles.
Re: Ford PTU's and Oil choices [Re: Mekks] #5316422 01/08/20 07:22 AM
4WD Offline
I would use Redline
It’s a pain to change fluid and the capacity is too low.
If you have a look at the exhaust … it can be very close to the PTU with some cheap little attempt at a heat shield.
I wrapped mine with Header Tape and stainless (hose) clamps … easy, cheap, effective
Re: Ford PTU's and Oil choices [Re: Mekks] #5316426 01/08/20 07:25 AM
M
Mekks Offline OP
M
I had planned on Redline regardless of weight. Would you advise 75w140, 80w140, or Lightweight Shockproof.
As you said its going to be a pain to change without a lift or even a compressor for a decent vac pump. I would prefer the best option for the longest fill I can get.
Re: Ford PTU's and Oil choices [Re: Mekks] #5316435 01/08/20 07:30 AM
4WD Offline
Redline GL5 gear oil is ester based …
mainly looking for the correct viscosity but with the extra ability to fight heat based oxidation
Re: Ford PTU's and Oil choices [Re: Mekks] #5316459 01/08/20 07:44 AM
CT8 Offline
Change the oil often.
2015 F150 2.7
2018 F350 6.2
Re: Ford PTU's and Oil choices [Re: Mekks] #5316480 01/08/20 07:56 AM
J
JLTD Offline
J
I'll be using Amsoil's Severe Gear 75w-140 in the Flex. Planning no longer than 50k, at least the first time.
"Let’s not pretend like 0w20 is anything but a CAFE required crutch to eek another 1/2MPG" - BLND1
Hers: 2018 Ford Flex AWD EB, 35k, dealer fill
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: Ford PTU's and Oil choices [Re: Mekks] #5316489 01/08/20 08:03 AM
P
PowerSurge Offline
P
Redline is overkill if you’re going to do it that often. The factory Ford Synthetic 75w-140 fluid is fine. https://www.youtube.com/watch?v=sS9JPaf1MDg
Re: Ford PTU's and Oil choices [Re: PowerSurge] #5316508 01/08/20 08:20 AM
4WD Offline
good chance by the time he does this job he will want to get 50k OCI if possible …
I regret not submitting mine to the worst design thread …
Re: Ford PTU's and Oil choices [Re: Mekks] #5316574 01/08/20 09:26 AM
Z
ZiTS Offline
Z
Use the weight called for, and change it often (30,000 miles MAX).
I'm running Valvoline Synthetic, and just changed it out in my 2018 Explorer. Get yourself a hand held suction pump. It really isn't a bad job at all. Suck out all the old fluid you can, then fill with the new fluid until it starts out the fill hole. I went to Lowe's and picked up some clear plastic tubing of the diameter that fit my suction pump, then cut it to the lengths that worked best. Get a smaller diameter for sucking out the old fluid, as it allows the tube to work around inside the PTU a little easier. Then put on a larger diameter for the fluid bottle you end up buying.
At 30K intervals, any quality synthetic fluid will work fine.
Z-
Re: Ford PTU's and Oil choices [Re: Mekks] #5316796 01/08/20 01:11 PM
SubieRubyRoo Offline
I'd say at the 30k interval recommended here, any synthetic will do just fine. I'd personally skip the Redline with that OCI, and save the extra for your inevitable water pump replacement/engine replacement. Not trying to be a jerk, just realistic.
De omnibus dubitandum.
Re: Ford PTU's and Oil choices [Re: SubieRubyRoo] #5316804 01/08/20 01:22 PM
4WD Offline
Have you done these yourself ?
Re: Ford PTU's and Oil choices [Re: Mekks] #5316879 01/08/20 03:02 PM
M
Mekks Offline OP
M
Ended up going with the Redline 75w140. @ $17.99 a bottle it was cheaper than the Motorcraft stuff. If I get more than 25-30k out of it I will be very happy.
Re: Ford PTU's and Oil choices [Re: 4WD] #5317121 01/08/20 07:30 PM
M
mpgo4th Offline
M
I have. Many times. My wifes car has one too. I have 5 police interceptor sedans (Taurus) and 4 police interceptor utilities (Explorer) in my fleet at work with all wheel drive. The police PTU is slightly different though. It has a 3/16 drain plug but no fill plug. Where the fill plug is supposed to be, they put a temp sensor with an o-ring to seal it. I unplug the sensor an take it out to fill the PTU then put it back every 25-30k miles. I've used mostly Motorcraft 75w140 but lately I've been getting Mag1 full syn 75w140 because it's about half of the cost. My wifes car is easy. It has a drain plug and fill plug. The ones you suck out are a lot easier if you can get that fluid warm first. Good luck.
Re: Ford PTU's and Oil choices [Re: 4WD] #5317131 01/08/20 07:39 PM
Nope; as I stated a couple weeks ago, I never buy a 1st year model of anything, and I watch for horror stories of vehicles I “may” at some point be interested in buying. If early adopters and/or extended information shows either really difficult maintenance or multiple indicators of poor engineering, I stay clear. The last part is, I speak and believe the fact that no oil or transmission fluid can fix an engineering gaffe in its respective equipment, so that’s why.
I wasn’t arguing your point that Redline is probably the best fluid in this case; just the fact that even Redline isn’t going to correct the issue of the differential running hot.
Re: Ford PTU's and Oil choices [Re: SubieRubyRoo] #5317141 01/08/20 07:45 PM
4WD Offline
For sure … I was doing the transmission on my Z71 a few days ago … looked up at the huge transfer case, oversized drain and fill plugs … and all the room in the world around it … Adios PTU …
There is not a single fluid hard to change now that I put a drain plug in the trans pan …
