Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
reylafo, PastPresMike, RedBeard83, dfrybeck, ckinch1
70495 Registered Users
94 registered members (90crvtec, 1978elcamino, 2011335d, 53' Stude, 2015_PSD, 28oz, 6 invisible), 2,254 guests, and 23 spiders.
Topics300,387
Posts5,174,750
Members70,495
Adding heavy oil treatment changes oil viscosity? #5316306 01/08/20 02:06 AM
E
Espada Offline OP
E
I wanted to know if i add a heavy oil treatment like stp as my engine is burning oil " 500ml every 1000km " to 20w50 oil would that increase the viscosity like 30w60 or something like that or does it thicken in the gap areas in combustion chamber, as the weather now in Egypt is kinda cold " 6 Celsius to 12 Celsius maximum " and i am worried about the cold flow in such low temps even if the engine is consuming oil
Re: Adding heavy oil treatment changes oil viscosity? [Re: Espada] #5316347 01/08/20 05:20 AM
1
1911CHAMPION Offline
1
I've never had any success with any "oil treatment" successfully reducing oil consumption on an engine that is already consuming that much oil.
Can you provide some details on the vehicle and what oil you are using? I would NOT be using a 20W-50 weight in those temperatures. It's going to flow like gear lube...
Re: Adding heavy oil treatment changes oil viscosity? [Re: 1911CHAMPION] #5316356 01/08/20 05:44 AM
E
Espada Offline OP
E
I have a 98 Mitsubishi lancer with an engine that was badly rebuilt 😔
Re: Adding heavy oil treatment changes oil viscosity? [Re: Espada] #5316367 01/08/20 06:09 AM
1
1
What's the factory recommended oil viscosity for your year/make/model/engine?
And does it spec something different dependent on ambient temperature?
Re: Adding heavy oil treatment changes oil viscosity? [Re: Espada] #5316372 01/08/20 06:17 AM
E
Espada Offline OP
E
Its okay to use 20w50 as temp never go lower than 6 Celsius as per the manual but does the oil treatment increase the viscosity to higher number?
Re: Adding heavy oil treatment changes oil viscosity? [Re: Espada] #5316376 01/08/20 06:20 AM
I
Imp4 Offline
I
No engine treatment will fix a poorly rebuilt engine.
Only an additional rebuild will fix it.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Adding heavy oil treatment changes oil viscosity? [Re: Imp4] #5316381 01/08/20 06:26 AM
E
Espada Offline OP
E
Nah won't do that trying to prolong the life of the engine i have now untill it dies then i will get a 1500cc short block and throw the old one till then i am trying to save the engine oil as much as i can
Re: Adding heavy oil treatment changes oil viscosity? [Re: Espada] #5316420 01/08/20 07:20 AM
Donald Offline
I would work on the reason for oil burning vs trying to stop it with a heavy weight oil.
2015 Ford F-250 w/Powerstroke
Re: Adding heavy oil treatment changes oil viscosity? [Re: Espada] #5316430 01/08/20 07:26 AM
G
gfh77665 Offline
G
I agree with your strategy. The advice some give to "rebuild it again" is not particularly practical.
Try the 20-50. It may or may not work. Try the STP too. My favorite for worn engines is "Restore". Its a proven product.
Re: Adding heavy oil treatment changes oil viscosity? [Re: gfh77665] #5316548 01/08/20 08:54 AM
E
Espada Offline OP
E
Finally someone that understand my point of view but its okay to use 20w50 with heavyweight oil treatment? Talking about oil flow at start up, And I don't have that item called " restore " in Egypt unfortunately i have to stick with STP
Re: Adding heavy oil treatment changes oil viscosity? [Re: Espada] #5316721 01/08/20 11:55 AM
L
Linctex Offline
L
I had an Isuzu 1.8 liter in a 1980 Chevy Luv....
It burned so much oil, a quart every 25 miles - All I ever put in was thick goop, VERY SELDOM ever added "engine oil"
I drove it that way for 2 years, even in Montana winters below 0*C
It still ran perfect when I sold it.
You can try your idea - if it works, no harm was done.
Re: Adding heavy oil treatment changes oil viscosity? [Re: Espada] #5316768 01/08/20 12:40 PM
N
nickaluch Offline
N
I used STP in a beat up bad rebuild Chevy box truck 20 years ago definitely slowed down consumption I would definitely try it. I'm guessing In Egypt it's pretty hot year round so start up concerns less concerning.
2007 G6 beater.2012 E450 box truck. 2018 Chevy Traverse.2017 E450 box truck.2017 Chevy 3500 extend cargo van.
Re: Adding heavy oil treatment changes oil viscosity? [Re: Espada] #5316770 01/08/20 12:42 PM
G
gfh77665 Offline
G
I don't know the exact answer but I believe with the Egypt climate, yes, the STP is OK to use. The only time I would not use STP would be if I lived in a very cold climate. The STP will not be much thicker than the 20-50 anyway, so you do not risk much since the viscosity change will not be a very great difference.
Re: Adding heavy oil treatment changes oil viscosity? [Re: gfh77665] #5316849 01/08/20 02:19 PM
SubieRubyRoo Offline
Cairo is on the same latitude as New Orleans; record low in Cairo is 34*F, record high is 118*F. It's been significantly colder in New Orleans, however. Just a reference since we don't know where in Egypt OP is at.
Re: Adding heavy oil treatment changes oil viscosity? [Re: Espada] #5316886 01/08/20 03:14 PM
Dave1027 Offline
Sometimes going with a heavier oil or a thick oil treatment can be the wrong thing to do on an oil burner. It all depends on why the engine is burning oil. Sometimes the ring groves get caked up and don't allow the rings to seal properly. In this case you would need an oil with greater cleaning ability such has a diesel oil. Also may help to go with a lower viscosity to help dissolve the sludge.
