3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
RSH, Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward
70487 Registered Users
111 registered members (69GTX, 1978elcamino, 2011335d, 14Accent, 66ROGUE, 65convertible, 7 invisible), 2,678 guests, and 40 spiders.
Topics300,347
Posts5,173,826
Members70,487
Most Online3,825
Jan 19th, 2020
GMT900 pattern failure #5316258 01/07/20 11:26 PM
clinebarger Offline OP
Seeing more & more of this as the platform ages, Applies to 2007-2013 GM fullsize trucks & SUV's. This is a 2011 Silverado 1500 4.8L with 273,xxx miles.
DTC B0085-00 set in the Airbag module, Open or Short to voltage in the Left Front Impact Sensor. The sensor is located in the left front door.
I don't even bother diagnosing this code anymore, Go straight to the wires that pass through the door jamb bellows! You will find the Purple/White or the White wire.....Or both broken. The Impact Sensor circuits are actually a auxiliary jumper harness that is normally pulled a little tighter than the main door harness. This of course puts more strain on those 2 circuits.
Trucks with crank windows may not be affected by this as there isn't a separate harness to pull & work the impact sensor jumper harness.
I like to add a section of wires to make the harness a little longer.....Spiral the wires around the main door harness to relieve it. If you try to simply splice the circuits back together, Especially if you solder the connections....It will break again in short order!
The harnesses must be pulled through the body side, Requires removing the Dash end cap trim, Door sill trim, And Footwell trim to release the Bellows locks & feed the harness through the opening in the cab/body.
Remove the Door Panel & release the Bellows locks.
Slide the Bellow down the harness (Away from the door) & carefully cut the 2 rubber "wings" that hold the Bellows to the harness.....I do not reattach the harness back to the Bellows.....Further relieving the harness. To disassemble it without cutting the "wings", You must disconnect all the door components & pull the harness out of the door enough to untape the harness from the "wings" by sliding the bellows toward the door.
You want the solder joints as small as possible, Don't let the solder wick down the wires! The longer the rigid spot in the wire is.....The more apt the copper strands are to break on either side of the solder joint!
[Linked Image from i.imgur.com]
2001 Chevy Camaro L92/4L80E
Re: GMT900 pattern failure [Re: clinebarger] #5316263 01/07/20 11:40 PM
O
oldhp Offline
O
Good tip!!! Somebodies gunna like this!!!
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: GMT900 pattern failure [Re: clinebarger] #5316266 01/07/20 11:44 PM
1
14Accent Online Content
Online Content
1
These types of repeat failures crack me up. How much more would it have cost to add 5-10mm worth of extra wire in the harness. Fractions of a cent?
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: GMT900 pattern failure [Re: 14Accent] #5316275 01/08/20 12:30 AM
Looks like there is enough wire/length in the impact sensor jumper harness.....It just got taped up a little weird/wrong.
Re: GMT900 pattern failure [Re: clinebarger] #5316288 01/08/20 01:05 AM
01rangerxl Offline
I was thinking "I'm surprised the silver truck [at work] hasn't done this," then I remembered the air bag light is on. LOL.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
Re: GMT900 pattern failure [Re: clinebarger] #5316329 01/08/20 04:01 AM
V
va2001ss Offline
V
Thanks, saving this one, just in case for my Tahoe.
2018 Chevrolet Malibu 2.0T LTG
2013 Chevrolet Tahoe 5.3 LMG
Re: GMT900 pattern failure [Re: clinebarger] #5316807 01/08/20 01:24 PM
G
GMguy84 Offline
G
No airbag issues on my 07 Burban ?? But it is on a recall since its on the takata bags
Although the 4L60E did finally give out with 3/4 gears So there's $1200 POOF !! from my bank account smirk2
Dave
01 Silverado 1500HD 5W30 RTG/XG3675
07 Suburban 1500 LTZ CQSHM 10W40/ M1-201A
09 Crown Vic Police SAP PKG 5W20 RGT/POBOSS
82 Trans Am (KITT) M1HM10W40/M1-102A
Re: GMT900 pattern failure [Re: clinebarger] #5316865 01/08/20 02:49 PM
DriveHard Online Content
Online Content
Thank you! I have an intermittent airbag light in my truck...I'll check it out.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: GMT900 pattern failure [Re: clinebarger] #5316888 01/08/20 03:15 PM
cb_13 Offline
Have you fixed many this way? I have always soldered in new wire for the entire length of the bend. By making the repair in the bend it is more likely to break again. Likely to the side of your solder joint.
If you have done many this way maybe there's not much pressure on the wiring anymore due to you disconnecting it from the bellows. Making it a non issue. I just know that I started laying new wire for the entire length of the bend due to dealing with issues already repaired by other shops.
Re: GMT900 pattern failure [Re: 14Accent] #5316904 01/08/20 03:28 PM
A
AC1DD Offline
A
Almost makes you wonder if it isn't a deliberate "feature" so that the dealer can make some cash money on a repair after the warranty is up...haha.
Re: GMT900 pattern failure [Re: cb_13] #5317173 01/08/20 08:30 PM
I've repaired several this way. The Bellows is offset quite a bit....So it does more twisting than bending if that makes sense? The reason I loosely spiral the wires around the harness.
But, You bring up a valid point & this method wouldn't work on every vehicle. 2002-2009 Dodge Ram's are notorious for breaking wires in a similar manner & you must replace the sections.
Re: GMT900 pattern failure [Re: AC1DD] #5318362 01/10/20 03:45 AM
dave1251 Offline
This does not benefit the manufacturer thus I don't follow your logic.
don't use.
