Originally Posted by kschachn
Originally Posted by JLTD
Where are all the "positive displacement" guys?
Are you claiming that the oil pumps on engines aren't positive displacement?
No.
Resaerch "MRV". pumpability. SAE J300...anything I've posted in the last 20years...and inform youself on why that advertising is made by the department of redundent information....
Yes, the pumps are PD...your knowledge continues to be lacking, in spite of a couple of years of the same lacking in fundamental understanding jabs...
No intent to offend or show ignorance here Shannow. Taking a jab in fun as you noted. If I said it in person you would laugh with me due to facial expression and inflection.
I actually was looking for some PD commentary, since apparently Shell has done some testing..... I wish they would publish some data to show how much quicker the 5w circulated rather than making a blanket statement.
My opinion has always been that even though flow may occur at the same rate
at the pump that a thinner oil at startup will circulate more freely elsewhere and thus flow a bit quicker in some areas since fluids choose the path of least resistance.
Thanks for the suggestion, I'll look up the J300.
....after some reading, it appears that engine design and oil chemistry have a large effect in oiling times - as expected. Although old data, I found this article and (kidding aside) would value your thoughts.
https://www.jstor.org/stable/44467123?read-now=1&seq=1#metadata_info_tab_contents
Sorry I'm not a scientist in the lubrication field.
