How to sift through the BS Oils?
Maine
What are the standards used or methods for identifying when an oil may not be what it claims to be? Case in point would be Triax. Amazon reviews are great, lots of seller self-glorification, no API cert but a nice long list of manufacturer's specs it meets, but not endorsed by. I saw another thread here were someone quite pointedly said that the "approvals" should read "None."
Would this be the same case with AMSoil?, Liquimoly? Royal Purple's non-API line?
How do you conclude that an oil is good or not?
This is the whole intent of the API starburst and donut program.
Read your owner's manual.
Follow it's instructions.
Purchase oil that meets manufacturer recommendation.
Wash, rinse, repeat.
Here's a link to the API sponsored Motoroilmatters.org website that has additional information.
YUP I would not touch that stuff unless a user group for the vehicle I own has UOAs over several years to show it is good or better than a walmart synthetic. Even then I would not use it. Why take the chance that is has some hydraulic or foaming property that occurs in certain situations that are not compatible with your particular engine. Not worth chasing a ghost of a buttery smooth idle on an engine that is naturally board a valve train rattle trap. If you are getting bad UOAs on a variety of walmart oils, no boutique oil will save you.
I agree, though there is some ambiguity. For instance my newest truck says "FCA Material Standard MS-10902 and the API CJ-4 engine oil category is required. Products meeting Cummins CES 20081 may also be used." and along comes Triax (and most others, not picking on one particular oil) listing Cummins CES 20086 under "Product Specifications"...
There is a reference in the manual that does recommend only using API-certed oils... so I guess that's the short answer- if it doesn't have the API seal then it is unacceptable to use. That does run counter to the entire Amsoil culture.
Thanks for the feedback guys.
Why are you sifting?
Do you have a high performance, offroad application that would require a NON-ILSAC lubricant?
A classic, hot-rodded muscle car with no after treatment devices?
A Honda K24A1 in a '93 civic running a turbo kit with 3ATM boost?
I would look to some VOA to verify claims of ZDP and Moly EP. and see if there has been good reception amoungst certain powersport communities.
Otherwise you likely ain't putting this stuff in your car.
ps. We already know Amsoil and RL have a good rep over decades. So Trust and word of mouth would be the theme.
Unfortunately when it is a certification or standard it usually comes down to the reputation of the blender. Most of those are self-certified and are properly reported as "meets requirements." API licensed oils also need to appear on the EOLCS Licensee Directory, so you have that to help you determine if it is actually licensed (including CJ-4). For Cummins CES 20086 there is a way for you to determine if it actually meets the requirements but you need an account to view the listing at:
https://quickserve.cummins.com/info/qsol/news/oil_registration.html
You may wish to try registering and see if you get an account.
Approvals can be somewhat easier to verify but not always.The Mercedes-Benz approvals are easy to see on the BeVo website but in this case your product probably does not claim any such approvals.
So as I said earlier it often comes down to reputation. Sometimes a blender or manufacturer deliberately obfuscates the situation as we clearly saw on a recent Amalie PDS. On the other hand, ExxonMobil and a few other manufacturers are crystal clear on what is an actual approval or certification as opposed to what is opinion. Not everyone is so clear however.
Just throwing this out there, but it looks like Triax is API certified. At least, this one is.
[/quote]
[/quote]
Why not sift? is it not ok to be curious or ask for some guidance when I don't see a clear answer? I see someone say something as definitive as "its garbage oil" and I just want to know how they come to that conclusion. Isn't the bulk of this forum people sifting?
High performance, no, but offload? yes. Old machinery originally designed to run on Russian diesel or be lubricated with whale blubber? Yes.
If it meets the specs in the owners manual, I don't think you'll see any difference between different oils. Except, perhaps if multiple viscosities are recommended, you may see a difference in fuel economy between the different weights.
Good info, thank you!
That's not the question, the question is whether a particular oil actually meets the spec or not.
Yes for API SN PLUS, but the EOLCS listing shows there are no Triax lubricants that are API CJ-4 licensed. So that's another data point.
It looks like your right!
I was specifically looking at this response regarding their Fleet Supreme 15W-40:
[Linked Image]
With all of the well known brands out there that have been tested and proven plus the lack of data on Triax, why even consider it? Amazon reviews are not to be trusted.
I checked PQIA just now. No info on Triax. If it's me I just pass.
IDK, The questions seem very open ended.to me at this moment.
If you said "I'm thinking of using TRIAX 5W40 in my '66 J.Deere tractor, how can I tell if its any good".
There are a lot of non-starburst oils out there.
But it looks like kschachn is stepping up
I don't like Martin form Triax response - looks defensive and like it hit a nerve
. Plus how to they "prove" their oil without proper engine testing?
Also I don't think an API starburst costs " millions of dollars"
Unless you do a VOA to get a look at some basic Viscometrics and the visible DP- which would certainly ruin ANY value proposition,
I'd Pass.
I'd Pass.
I agree with you, I wasn't impressed by his response.
My intent was trying to see if there was something I was missing (aside from decades of word-of-mouth and good UOA's) to compare the non-starburst oils.
Winter front, block heater, coolant strength good for -50°C, maybe a bottle of Antigel, and 0W oil in your choice. Seen -50° lots of times working in the " Patch ". I don't shut my diesels off when it get below -25° on location. Also I believe travelling thru BC it's law to have winter rated tires.
