Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward, MrH1325
70486 Registered Users
132 registered members (2002 Maxima SE, AandPDan, 67ZL1, 2015_PSD, 1978elcamino, 14Accent, 9 invisible), 2,321 guests, and 26 spiders.
Topics300,344
Posts5,173,761
Members70,486
Most Online3,825
Jan 19th, 2020
Air Filter with best Filtration #5315441 01/07/20 04:35 AM
Clubber_Lang Offline OP
Although this is an Oil Website, I think that some people downplay the importance of engine air Filtration in keeping an engine clean...
Who makes the Air Filter with the best particle Filtration? Would it be the Fram Ultra Air Filter? (Only sold at Walmart) or is it another brand I am missing?
Re: Air Filter with best Filtration [Re: Clubber_Lang] #5315445 01/07/20 04:45 AM
Char Baby Offline
Maybe!
But, I don't know if there is one brand of air filter that would be considered "best filtration" due to having so many different applications. However, there is a "higher line" of filtration such as the FRAM Ultra AF you mention, and I think this is where the focus could be.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Air Filter with best Filtration [Re: Clubber_Lang] #5315471 01/07/20 06:17 AM
B
BMWTurboDzl Offline
B
Depends on how often you want to change it. OE if you want to stick with the factory service interval or for better filtration at a much shorter interval you could look at something such a Micronair Blue by Corteco.
435i
Re: Air Filter with best Filtration [Re: Clubber_Lang] #5315476 01/07/20 06:29 AM
E
Ed_Flecko Offline
E
This article is 10 years old, but I find it interesting.
"Debunking the K&N Myth – Why OEM is Better" - https://bit.ly/37I00Mj
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Air Filter with best Filtration [Re: BMWTurboDzl] #5315506 01/07/20 06:54 AM
B
BMWTurboDzl Offline
B
Never mind. I thought OP meant Cabin Air Filter.
435i
Re: Air Filter with best Filtration [Re: Clubber_Lang] #5315520 01/07/20 07:10 AM
Donald Online Content
Online Content
Go with a quality filter like a WIX or OEM and make sure the sealing surfaces are perfect.
Many air filter housings are difficult to open up fully and so people spread apart the housing a few inches and slap in a new filter. Better to take more apart and make sure the filter is seated properly.
2015 Ford F-250 w/Powerstroke
Re: Air Filter with best Filtration [Re: Clubber_Lang] #5315522 01/07/20 07:11 AM
danez_yoda Offline
tests have shown that OEM filter on the second half of their life have better filtration than new ones. A little dirt caught and a little oil vapor makes it a finer filter. It still flows enough to give the engine near full power (how often do you really floor it anyway).
For a regular grocerygetter OEM will work fin as long as it is properly installed and sealed.
Re: Air Filter with best Filtration [Re: Clubber_Lang] #5315527 01/07/20 07:14 AM
K
Kira Offline
K
OP said, "Although this is an Oil Website, I think that some people downplay the importance of engine air Filtration in keeping an engine clean..."
I must explain my disagreement with notion.
Dirt in the engine air supply is commonly cited as THE source of silicone contaminants in oil.
Also, many have conversationally referred to air filtration as being "more important than oil filtration" for removing abrasives.
In fact, high silicone is mentioned as a red flag to alert heavy machine owners to incorrectly installed air cleaners.
Dirt = bad, ALWAYS.
Re: Air Filter with best Filtration [Re: Clubber_Lang] #5315555 01/07/20 07:48 AM
Chris142 Online Content
Online Content
I am going out on a limb. I think the air filter is more important than the oil filter.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Air Filter with best Filtration [Re: Donald] #5315557 01/07/20 07:50 AM
Online Content
Most cars that come through my shop have a mis installed air filter. Especially astro vans. None of them are installed correctly when they come in the door.
Re: Air Filter with best Filtration [Re: Clubber_Lang] #5315639 01/07/20 09:19 AM
F
Farnsworth Offline
F
Denso has triple layer construction, Fram Ultra at Walmart if they have your size, and AC Delco are good ones. I like them so that's what I unscientifically think.
Good to resurrect a topic now and then that is long in the dust bin of old topics.
Re: Air Filter with best Filtration [Re: danez_yoda] #5315810 01/07/20 01:04 PM
L
Linctex Offline
L
For a regular grocery getter, the OEM filter will work fin as long as it is properly installed and sealed.
^^ Agree with this...
And it should be a crime how poorly most air filters are installed. You can often blame the quick lube places for that error.
Re: Air Filter with best Filtration [Re: Clubber_Lang] #5315869 01/07/20 02:13 PM
Yah-Tah-Hey Offline
DENSO
Re: Air Filter with best Filtration [Re: Clubber_Lang] #5315898 01/07/20 02:50 PM
T
tc1446 Offline
T
I remember reading that test report years ago and promptly removed the K&N from my 2000 Ranger. That filter has been washed and still in my shed...haven't been able to give it away!
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: Air Filter with best Filtration [Re: Yah-Tah-Hey] #5316052 01/07/20 06:28 PM
T
tundraotto Online Content
Online Content
T
Originally Posted by Yah-Tah-Hey
DENSO
From what I have seen of airfilters....DENSO has always been a quality looking one....but I don't have any empirical data.
