Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
18 registered members (Bjornviken, blufeb95, alcyon, CARJ, Bailes1992, ctechbob, 2 invisible), 613 guests, and 27 spiders.
Topics307,388
Posts5,309,620
Members71,821
S2000 First UOA, 1000 Miles, Penrite Racing 10w40 #5315424 01/07/20 04:06 AM
DV0993 Offline OP
First UOA on my S2000, changed early due to hard driving including one track day. Car has approximately 150,000km on the clock (90,000 miles) with 1000 miles on this oil.
Short OCI conducted as I was eager to check up on the motor following valve retainer replacement and following the vehicle's first track day.
Penrite Racing 10w40 was used, no doubt would've been safe to go much further and I will do so on the next batch of oil.
Can I get thoughts on the wear metals in the images below? I'm worried Iron, Aluminium and Lead are high on such a short interval.
Thank you!
Re: S2000 First UOA, 1000 Miles, Penrite Racing 10w40 [Re: DV0993] #5315455 01/07/20 06:15 AM
A
adams355 Offline
A
Seems fine, those wear metal levels are not high. Are you using the same oil again?
Re: S2000 First UOA, 1000 Miles, Penrite Racing 10w40 [Re: DV0993] #5315484 01/07/20 07:34 AM
SubieRubyRoo Offline
Not high at all considering you are tracking the car. A very short interval is not really valuable at all to "estimate" wear, especially since UOA is not intended to assess wear. All you really get is relevant data on the items in the "physical tests" section, and those all look good.
You need longer intervals and/or more UOAs to be able to assess a trend; 5ppm Fe may turn out to be 10ppm Fe at 4k miles, etc.... remember that when you take such a short UOA there is some minor carryover from the last oil change; i.e. you don't get every last bit of oil out of the engine on a drain no matter how long you leave it, and this remainder will always cause your "virgin" oil to have slightly higher levels at very short mileages. These will then begin to trend more in line with what is actually going on. But again, don't make the mistake of thinking UOAs are a valid indicator of "wear".
De omnibus dubitandum.
Re: S2000 First UOA, 1000 Miles, Penrite Racing 10w40 [Re: DV0993] #5315525 01/07/20 08:14 AM
Cujet Offline
That's a wonderful UOA.
Re: S2000 First UOA, 1000 Miles, Penrite Racing 10w40 [Re: DV0993] #5315623 01/07/20 09:59 AM
A
ARCOgraphite Offline
A
Looks like the ancient Valvoline VR-1
Maybe try an oil with more moly, similar ZDP, lower CA. Mg
basically high EP/AW low DP
No need to change just sample.
I drive my car like a madman, it doesn't wear fast, it would just blow if I make a boo-boo.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: S2000 First UOA, 1000 Miles, Penrite Racing 10w40 [Re: ARCOgraphite] #5315936 01/07/20 04:33 PM
DV0993 Offline OP
Thanks everyone, currently using Nulon Racing 5w30 that will see a track day in January and another in April, as well as some driving in between.
Don't know what the full add pack is, but the bottle says there is 2300ppm of Zinc and Moly combined.
Re: S2000 First UOA, 1000 Miles, Penrite Racing 10w40 [Re: DV0993] #5444209 06/01/20 08:05 PM
DV0993 Offline OP
Hello all,
I just received my UOA for Nulon Racing 5w30. I picked up the wrong oil in error (I was actually planning on using the 5w40) but used it anyway. Whilst the additive pack looks good, the viscosity simply did not seem good enough for the bearings.
The oil saw one track day and some spirited street use totaling approximately 2200km/1400 miles. I ended up topping up with 500ml of 5w40 over the course of the interval with the oil burn rate increasing in the last 500km.
See image below indicating increased Tin (bearing wear)
My next oil is HKS Super Oil 7.5w35 (4L) with 7.5w45 (0.6L) I did not replace the oil filter.
[Linked Image]
Re: S2000 First UOA, 1000 Miles, Penrite Racing 10w40 [Re: DV0993] #5445708 06/03/20 08:18 PM
DV0993 Offline OP
Bump: Wondering if anyone has any comment on the above? Should I be concerned? I will be reverting to #w40 oil permanently.
Re: S2000 First UOA, 1000 Miles, Penrite Racing 10w40 [Re: DV0993] #5445749 06/03/20 09:12 PM
R
robertcope Offline
R
I guess technically Tin has elevated, but really, it seems hardly noteworthy. IMHO, of course, and I know nothing.
