Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Walmart Oil Change?
by Talent_Keyhole - 01/18/20 12:50 AM
Bleh, mother’s gas furnace fan burned up
by Rmay635703 - 01/17/20 11:23 PM
Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
Not on sale but theeeeeeyyyyy're here!
by jayjr1105 - 01/17/20 06:47 PM
2EHA, jonnyb433, kzbd, 54Robert, CPA1989
70464 Registered Users
98 registered members (2015_PSD, 53' Stude, 55hambone, aba4430, 2strokeNorthstar, 2010Civic, 8 invisible), 1,622 guests, and 15 spiders.
Topics300,273
Posts5,172,129
Members70,464
Most Online3,728
Jan 11th, 2020
New Honda eu2200i break in during winter, also remove spark plug put oil in? #5315380 01/07/20 12:18 AM
T
ttggzz Offline OP
T
Hello, I have a brand new Honda eu2200i which I'm going to be breaking in soon. I'm on the coast of New England USA. There were some delays getting to this which turned out to be a good thing! I'm a internet research hound and in the interim found the motoman/mototune/run hard break-in article and read a bunch of related threads here and elsewhere as well. Just learned of this a couple days back so still sinking in, completely new info to me, makes sense! A couple questions. I live in a small apartment, this break-in will occur in front of my walk in rented storage area where I can do such things like run generators:
1. Prior to finding the mototune info I had seen a few mentions of removing the spark plug and dribbling some oil in, maybe Marvel Mystery Oil or the like, then pulling the start cord a few times before first starting. Read 4 or 5 really good generator break in threads here on BITOG and didn't see nary a mention of such. Not needed? Can't hurt? Procedure?
2. I'd like to get at least 40 degree temps to do this [start the break in procedure] but may venture forth in colder temps. Maybe have the generator inside overnight to be somewhat warm at start? After the first oil change it may be another day/time when I get back to it for the next run. Let it warm up inside again? Or does it matter. Can't see how but does this staggered approach matter? One thing I liked when researching the Honda is it has that cap that really seals in the gas odors, so I should be good sneaking it into my apartment under wraps smile
The generator will be used regularly year round, perhaps as much as several times a week. Run power tools, heater, etc. Also I flip stuff on Craigslist and meet buyers at a parking lot. I will now be able to offer on-site testing for all manner of electrical items.
thanks for your time and any info!
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5315414 01/07/20 01:52 AM
ctechbob Offline
I don't think you're going to hurt a thing by doing all of that, and the warmer oil at start is going to flow better, although you could use a thinner oil.
Properly taken car of, that thing is going to run forever anyways, but nothing you've described could do anything but add life to it, however minor.
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5315423 01/07/20 02:55 AM
K
Kamele0N Offline
K
I would use 2stroke oil for a conservation...
You could also use mix (1:50) for the first tank fill...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5315478 01/07/20 06:30 AM
DuckRyder Offline
Unless you have a concern of corrosion in the cylinder I would not oil the cylinder, some ring manufacturers warn against this (and dipping pistons) because it inhibits break in. If you do elect to do it use something very light and not much of it.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5315499 01/07/20 06:47 AM
Cujet Offline
Those little engines are robust and don't need any special treatment. Use a quality oil, a quality fuel and go on your way. Adding oil to the fuel will simply serve to lean out the air/fuel mixture on an already "lean" engine. This may lead to operational issues.
From a practical point of view, good maintenance practices (regular oil changes with the proper oil, air filter service, etc) will provide the longest service life.
I would not even worry about a break in procedure. Simply use it normally, when you need to use it. Think about that for a bit, you are taking a cold engine and starting it up, warm it up for a bit, then apply a load. What could possibly be a better break in procedure?
If possible in your area, an ethanol free fuel would be a nice choice.
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5315624 01/07/20 08:59 AM
stockrex Offline
put in synthetic oil,
add a tad bit 2 cycle in gas (if you are not going to use it a long time (I would not, it might clog jets when it dries)
let it warm up ,
plug in room heater in high, let it run for few hours and change oil and drain gas from tank and carb.
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5315646 01/07/20 09:25 AM
F
FastLane Offline
F
Put oil and gas in it. Nothing more. Let it break in for a few hours with various loads on it. Change the oil.
2010 Silverado 4.8 4x4 Mobil 1 5W30 Fram XG10060
2002 Mustang GT 4.6 Mobil 1 5W30 Fram XG2
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Mystic 25W40
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5315748 01/07/20 11:24 AM
Dave Sherman Offline
Never had to worry about putting oil into the spark plug hole on any of my small engines. If you're concerned about corrosion, maybe pull the rope until you feel the compression stroke, then the valves are closed.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5315792 01/07/20 12:40 PM
L
Linctex Offline
L
No need to put oil in the spark plug hole - these engines are already run from the factory, then drained.
HOwever, I *do* mix 128:1 (1 oz of 2-cycle oil per gallon) in every engine I am doing a break in.
Honestly - the engine side should run nearly forever. The greater chance of failure is usually the electrical side of it all.
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: FastLane] #5315852 01/07/20 01:59 PM
M
meep Offline
M
^^^ This. I owned a eu2000i. Don't overthink it. Put the proper fluids in it, keep it clean, and change the oil more frequently if you want. It's pretty easy on oil, and is a very efficient machine. Use and enjoy.
2018 F150
2015 crv (wifey!)
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5316065 01/07/20 06:38 PM
A
Astro_Guy Online Content
Online Content
A
I neither agree nor disagree with the article, as the applications are completely different. A generator is going to attenuate the load on the motor no matter how hard you try to beat on it. Just run it with varying loads of 30-90% capacity for the first five hours, change the oil, and live a happy life.
'01 Volvo V70XC, 248k, 5W-30 M1 EP
'16 Accord, 46k, 0W-20 M1 EP
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5316134 01/07/20 07:56 PM
J
JimPghPA Offline
J
Putting a spoon full of oil in the cylinder and pulling the rope a few times and then stopping when the resistance of compression is felt on the pulled rope so the valves are closed is for when you are putting away an engine that may not be used for a long time, like more than 6 months.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5316344 01/08/20 05:06 AM
K
Kamele0N Offline
K
Re: New Honda eu2200i break in during winter, also remove spark plug put oil in? [Re: ttggzz] #5319405 01/11/20 08:15 AM
cronk Offline
Ive broken in a couple new generators.
The process I have used was to use a 500w halogen work light for a light load and a 1500 watt heater for a heavier load. I would alternate the loads around for about a 5 hour break in, then dump the oil. Refilled with dino 10w30 hdeo, then used the generator normally. At about additional 10 hours on this oil change, I dump it and refill with the Amsoil ase and consider break in complete.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
