STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
Help choose a Nissan
by lealedwin485 - 04/06/20 02:31 PM
Ceramic wax
by rrretiree7 - 04/06/20 02:09 PM
Oil Change
by rrretiree7 - 04/06/20 01:47 PM
Animals and cancer
by IMSA_Racing_Fan - 04/06/20 01:17 PM
Shell oil help
by IvanPletex - 04/06/20 12:18 PM
Oil Selection Query
by moonlightblue - 04/06/20 12:00 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
131 registered members (01rangerxl, 379KITTY, 03s, 2015_PSD, 2KBMW, 11 invisible), 2,583 guests, and 20 spiders.
Topics303,693
Posts5,240,057
Members71,116
2015 VW Golf Sportwagen TDI #5315320 01/06/20 10:45 PM
W
whizbyu Offline OP
W
I've read stories about owners of this diesel deleting the DPF, cat, and AdBlu system. Is the 507 spec oil formulated specifically for the DPF? Once the DPF and other emissions hardware are removed, can any decent diesel oil (M1 TDT, for instance) be used in place of the 507? Or is there something about the lubricating properties of 507 that goes beyond the DPF application?
Re: 2015 VW Golf Sportwagen TDI [Re: whizbyu] #5315369 01/07/20 12:36 AM
sloinker Online Shocked
Online Shocked
Mostly it's about the low saps and it is a good oil specification wise in any circumstance. Once the DPF and Converter are gone you can use pretty much any oil that will protect the turbo and mitigate the dirty diesel combustion process. Rotella comes to mind among other brands. The 507 is a 5W30 so I wouldn't stray too far away from that.
Good info on this site for what is involved in the delete and re-flash.
https://forums.tdiclub.com
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: 2015 VW Golf Sportwagen TDI [Re: whizbyu] #5315386 01/07/20 01:28 AM
P
pezzy669 Offline
P
Yeah the 507 is meant to help extend the life of the DPF so theoretically you could run just about any HDEO if you are doing a DPF delete.
My ? is has this car already driven past the mileage extension limits (162k) for the diesel gate warranty? The TDI warranty pretty much covers everything from the fuel fill nozzle to tailpipe (except transmission) that will trigger a CEL and doing the delete will null and void the warranty leaving you on the hook for repairs.
2016 Volkswagen e-Golf SE - 59k
2011 Volkswagen Jetta Sportwagen TDI - 49k - Castrol Edge Professional LL03 5W30
Re: 2015 VW Golf Sportwagen TDI [Re: whizbyu] #5315513 01/07/20 08:00 AM
B
BMWTurboDzl Offline
B
So you want some assistance after you break federal emissions law? no-no
435i
Re: 2015 VW Golf Sportwagen TDI [Re: BMWTurboDzl] #5315535 01/07/20 08:23 AM
W
whizbyu Offline OP
W
I haven't broken any laws other than go over the speed limit. Notice I wrote "I've read stories....", your honor. banana
Re: 2015 VW Golf Sportwagen TDI [Re: whizbyu] #5318797 01/10/20 04:24 PM
H
Huie83 Offline
H
That's the plan with my 2013 Golf TDI once I'm past the CPO and Emissions warranty. DPF delete and tune. I'm planning on experimenting with diesel oils when that happens. Until then its a 507 and VW filter. Been running either Castrol Pro SLX ( OEM oil) or Pentosyn long life lll which is also 507. Can't tell a diff between them, Pentosyn is cheaper and I use their DSG fluid too so why not.
Re: 2015 VW Golf Sportwagen TDI [Re: Huie83] #5320930 01/12/20 05:47 PM
W
whizbyu Offline OP
W
That is what I've been thinking all along until I realized that I will be deleting the DPF probably way before the DPF gets destroyed by using non 507.00 oil. Maybe it is a risk. Parenthetically, I've always been told 505.01 has the strongest film strength due to the PD cam requirement. Does that translate to 505.01 being a really good oil as far as wear protection is concerned?
Re: 2015 VW Golf Sportwagen TDI [Re: pezzy669] #5320979 01/12/20 07:05 PM
L
littlehulkster Offline
L
And given how problematic and expensive the high pressure fuel pumps are on these cars, you'd absolutely want that warranty in tact.
If the HPFP goes out of warranty you're out thousands, as essentially your entire fuel system has to be replaced due to possible metal particle contamination.
Some TDI guys think you can extend the pump life with consistent use of Stanadyne at every fillup, but the jury is still very much out on that one.
2015 Mazda3 I 2.0
Re: 2015 VW Golf Sportwagen TDI [Re: whizbyu] #5327765 01/20/20 12:06 PM
J
jjblbi Offline
J
I am coming up on 200k miles with my 2014 Passat TDI SEL. I run Delvac 1 esp 5w-40 changed every 10k miles and still have original DPF. I run ~35k miles a year and average 40 mpg post fix.
Re: 2015 VW Golf Sportwagen TDI [Re: jjblbi] #5328288 01/20/20 09:52 PM
CleverUserName Offline
This is what I’m doing now in both my modern diesels that require a C3 type oil. They both run great on the synthetic HDEO and oil analysis always come back with low wear metals unlike when I used to use VW 507 oil. Never again
Re: 2015 VW Golf Sportwagen TDI [Re: jjblbi] #5328302 01/20/20 10:11 PM
N
NVRENUFF Offline
N
My 13’ passat TDI SEL averaged 51-52mpg Hwy, but since the emissions update it’s dropped to 38mpg at best and the oil reports show tons of aluminum now. In the last 15k miles it’s went from not using oil to using 1qt every 1,000 miles or less. VW really ruined a good car, and now best they can do is tell me to come buy a new car. I’m lookin into deleting it and rebuild it myself. Hopefully then I’ll have the reliable long haul car I had before.
Re: 2015 VW Golf Sportwagen TDI [Re: NVRENUFF] #5328315 01/20/20 10:33 PM
SubieRubyRoo Offline
Have you had a dealer check for other mechanical issues? How much exactly is a "ton" of aluminum since hyperbole is a unitless measurement? Are your post-update UOAs in line with universal averages for your engine? You do realize that: 1. You need at least three samples minimum to form any kind of trend, good or bad, and 2. UOA is not the correct tool for the job if you think your engine's eating itself? Analytical ferrography, filter debris analysis, or partial teardown are needed if you really think its serious.
UOA is looking at stuff the size of red blood cells. so small you'd need it under 10× magnification before it was even as big as a human hair. If you truly value your vehicle, don't waste your time complaining on a message board, get into the dealer and make it their problem, because a bunch of "aww man that sucks" posts isn't going to fix your car once things spontaneously disassemble themselves.
De omnibus dubitandum.
Re: 2015 VW Golf Sportwagen TDI [Re: CleverUserName] #5328393 01/21/20 01:21 AM
B
BBDartCA Offline
B
Originally Posted by CleverUserName
[quote=jjblbi]
I’ve not heard of 507 lubes causing wear problems. What was your experience?
Former lube industry insider...now vehicle OEM engineering insider.
Re: 2015 VW Golf Sportwagen TDI [Re: BBDartCA] #5328399 01/21/20 01:52 AM
U
UG_Passat Online Content
Online Content
U
[quote=jjblbi]
Early 507's were not compatible with the Touareg r5 TDI & V10 TDI. Early publications of the 507 oil lists advised against using it in those engines. I suspect the gear-based timing system (in lieu of a belt) excessively sheared the oils into nothing worth protecting.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: 2015 VW Golf Sportwagen TDI [Re: whizbyu] #5330159 01/23/20 10:43 AM
R
racin4ds Offline
R
Once again the EPA and emissions BS has apparently ruined things.... I be darned if I'd spend the money on a TDI for 38mpg when I can get that with any new gasoline eco car! TDI's have been getting 48-50mpg for many many years according to friends of mine that own them. I was contemplating buying one this year for a commuter but I think I'll pass now...
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
