Originally Posted by The Critic
Originally Posted by 14Accent
All 4? At 98k?
Of all the Highlander's I've ever worked on (lots), I've never done a motor mount unless it was damaged. I HAVE done lots of the torque mounts (the one at the top, on the passenger side.
What symptoms are you having?
+1
Usually, the top dogbone mount gets torn. This is most likely due to excessive movement from the front mount (the one nearest the radiator). So I usually recommend replacing the front mount and the dogbone mount together with OE parts.
I have never seen the other ones go bad, even at high mileage.
OE parts are not cheap! $200 for the front mount and $90 for the dogbone...
