Originally Posted by kschachn
Originally Posted by Mad_Hatter
Ok, seriously now.. isn't PTFE the slipperiest (friction coefficient) substance known to man?..so load your oil up with a bunch of Teflon and Bam.. instant slippery!
No not the lowest "known to man", that would be a superfluid which has a coefficient of zero.
Wet ice on ice is probably a bit lower than PTFE, it depends on how you measure it. But it is very low.
Yeah but can you coat the inside of a ketchup bottle with it to get that last drop?...‚
Ice on ice aside, apparently "BAM" is now the "solid" record holder.. with a coefficient of a little less than half of Teflon. Did not know this..who said BITOG can't be informative?...
