I had to open up the driver's door on my new-to-us (relatively) 2003 civic - step-sons starter car. I have to re-pin the lock cylinder - the horrible lock quality Honda used back then caught up to it.
I didn't like all the moisture and debris inside the door well. Pic below. The vapor barrier is intact/ok. Granted this is the PNW, but...
I was thinking to clean it all out and dry it, then cover it with a coat of 3M spray undercoating. I've used that with great effect in the past on motorcyles, fenders, etc. is that a bad idea? I just don't think there's actually drainage anywhere I could block, is there? I can't find any. There was also moisture all throughout; the inner door brace, lock hardware, etc. were all damp or had a drop of water here and there.
The window gasket above is clean and conditioned with some Sil-Glyde in the fall, so it's as good as it's going to get.
Ideas? Is that a good idea or bad?
