Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Rotella Multivehicle 5W-30
by js1956 - 05/31/20 10:54 AM
Tesla Model 3 Driving Guide
by JeffKeryk - 05/31/20 10:41 AM
Keep OE carb vs replacement
by JHZR2 - 05/31/20 10:00 AM
Gave away some of my stash
by Chris142 - 05/31/20 08:32 AM
Two year check in - Dewalt 20 V String Trimmer
by Snagglefoot - 05/31/20 08:07 AM
Sturmey Archer 3 Speed-Shifting?
by ET16 - 05/31/20 07:45 AM
Power washing your home
by ARB1977 - 05/31/20 07:05 AM
AbbeyRoad, RPF, Rayi, juca, jrow96
71584 Registered Users
104 registered members (53' Stude, AlienBug, addyguy, 55hambone, 10WSmuckers, 87sammy, 5 invisible), 2,420 guests, and 18 spiders.
Topics306,099
Posts5,286,403
Members71,584
Page 2 of 2 1 2
Re: Classic cars classic oils? [Re: slybunda] #5314064 01/05/20 06:23 PM
W
WiskyBadger Offline
W
I have Valvoline VR1 in my 355 with a big cam and flat tappets. 4 qts of 10w30 and 1 qt of 20w50. I could only find 4 qts of the 10w30 locally. Seems like everyone goes straight to the 20w50 around here in the classics.
11 Silverado 76k Rotella Gas Truck and Champion filter
11 Traverse 123k Rotella Gas Truck and Delco filter
78 Chevy C10 Stepside VR1 10w30/20w50 mix Wix filter
Re: Classic cars classic oils? [Re: slybunda] #5314088 01/05/20 06:41 PM
W
wtd Offline
W
I run a 10W-40 with a zinc additive in the 396 BB that is in my 70 Monte. I tried running a 10W-30 in it after the rebuild but the oil pressure was lower than I liked at a hot in gear idle.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: Classic cars classic oils? [Re: slybunda] #5314144 01/05/20 07:29 PM
O
oldhp Offline
O
Use this:
Red Line Engine Break-In Additive provides conventional motor oils with anti-wear additives like zinc and phosphorus (ZDDP) that are necessary to protect against premature camshaft and valvetrain wear. While designed for optimal engine break-in, this formula is ideal for extra anti-wear protection at any time. 1/2 bottle each oil change should do the trick. Part # 81403
Half Bottle (8oz.) when treating adds the following;
Capacity - Phosphorus - Zinc
12 quarts - 382 ppm - 460 ppm
10 quarts - 458 ppm - 552 ppm
8 quarts - 572 ppm - 690 ppm
6 quarts - 763 ppm - 920 ppm
5 quarts - 915 ppm - 1104 ppm
4 quarts - 1145 ppm - 1380 ppm
1 bottle (16oz) when treating adds the following;
15 quarts - 610 ppm - 736 ppm
12 quarts - 763 ppm - 920 ppm
10 quarts - 915 ppm - 1104 ppm
8 quarts - 1145 ppm - 1380 ppm
7 quarts - 1307 ppm - 1577 ppm
6 quarts - 1525 ppm - 1840 ppm
5 quarts - 1830 ppm - 2208 ppm
4 quarts - 2288 ppm - 2760 ppm
1 quart - 9160 ppm - 11040 ppm
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Classic cars classic oils? [Re: slybunda] #5314187 01/05/20 08:26 PM
O
OilUzer Offline
O
Are new synthetic oils harsh(er) on seals especially for older cars?
Also aren't API SL (or lower?) easier on seals than SM/N?
Re: Classic cars classic oils? [Re: OilUzer] #5314191 01/05/20 08:28 PM
RDY4WAR Online Content
Online Content
No. PAO can be harsh to seals (any elastomer seals), but there's few oils out there where PAO is the primary base oil. The ones that are, they usually have a good bit of ester which is an excellent seal conditioner. Group III synthetics are not a concern for seals.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Classic cars classic oils? [Re: nascarnation] #5314287 01/05/20 10:20 PM
Chris142 Online Content
Online Content
Originally Posted by nascarnation
I've got a 67 Camaro 250 six and it seems to do fine with Pennzoil Platinum 5W30. I change it every three years.
That thing will be running long after our world ends. It and the slant6, 6.9 diesel and roaches will be the only things left.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Page 2 of 2 1 2
