belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
26 registered members (4WD, aleneros, carviewsonic, Bogdon, Bailes1992, CATERHAM, 2 invisible), 1,279 guests, and 29 spiders.
Topics301,894
Posts5,204,858
Members70,798
Why can't they make an engine that will hold water? #5313814 01/05/20 10:30 AM
B
Burt Offline OP
B
I have owned four fords in the last 40 years and all have developed either intake or head gasket leaks.
1981 Capri 2.3 L
1987 Taurus 3.0 Vulcan
1998 Windstar 3.8 L (intake manifold leak)
2015 Fiesta 1.0 L (TBD)
I know that some of this is due to dissimilar metals in block and head, but after making engines for 100 years, you'd think they would've perfected the design and manufacturing process. Most of these, a mechanic can make a long lasting permanent repair. And some manufacturers don't seem to have this problem.
Why is that many American manufacturers don't bother to get something like this right, when they know it is key to brand loyality? How much more can it cost to do it right?
2011 RX350 63k miles
2015 Fiesta SFE eco-boost 34k miles
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313837 01/05/20 11:11 AM
Propflux01 Offline
Economics. Gasket lasts a few years. Person takes it in to dealer. Dealer makes money. Person chalks it up to bad luck. Mechanic fixes it permanently. Never leaks again. Flag waiver still waves his FORD flag. Trades for a newer model.Rinse, Repeat.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313838 01/05/20 11:12 AM
E
E150GT Offline
E
I don't know but I've owned 3 Fords and no leaks.
1990 Econoline 225k miles when I sold it
1995 f150. 252k miles and counting
Both have 4.9L
1988 crown Victoria. 5.0 good car. Should have kept it.
Nothing lasts forever though. Except herpes
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 68k 5w30
2006 Buick Lucerne CXL 3.8 40k 5w30
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313844 01/05/20 11:21 AM
I
Imp4 Online Content
Online Content
I
Who would believe that the 4 Toyotas I've owned have never leaked coolant. Two of them are 250k+ and still in use.
Oh, also an 18 year old Mitsubishi. Also still in circulation. It's never leaked either. And that thing has been beat to death. Another year or two and the rust demon will finally consume it.
Maybe I'm just lucky...
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313870 01/05/20 12:05 PM
N
Neely97 Offline
N
Yet, you keep buying Fords.
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313878 01/05/20 12:12 PM
T
thastinger Offline
T
I've never had a head gasket issue
88 ranger 2.3
98 f150 5.4
99 lightning
04 escape 3.0
13 gt500
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313882 01/05/20 12:20 PM
Dave9 Offline
I haven't had my Ford leak but have had a few GM's with intake leaks.
Why can't certain brands make auto trannys that last as long as the vehicle? Something is always the weakest link.
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313888 01/05/20 12:28 PM
T
tenderloin Offline
T
Never had a leak in 17 Ford cars, vans and SUV/s Many with over 200,000 miles A few over 300,000 miles
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313914 01/05/20 01:21 PM
N
nobb Offline
N
Had the timing cover leak on a Ford Ranger with the 3.0 Vulcan same as yours. Only 150,000 kms and have only been using OE Motorcraft coolant. Maybe the reason is because there's hardly any material in the gasket design on the coolant side. Apparently this is a really common problem on these engines.
Re: Why can't they make an engine that will hold water? [Re: Imp4] #5313938 01/05/20 02:05 PM
01rangerxl Offline
Plenty of Toyotas have leaked coolant, so if you owned them a long time, I would call that luck, not just Toyota magic. The 3.0 in the 4Runner and Pickup comes to mind. It's not uncommon for 4.7s to leak from the water pump before the timing belt is due as well. And the Prius head gasket issues have been described in detail on BITOG.
Ford does their share of corner cutting, but coolant leaks are a fact of life on liquid cooled engines. Nobody has perfected it. I've dealt with coolant leaks on my Fords, all fixed in my driveway except for the water pump on my 3.0, which happened at almost 200k. I can live with a water pump, tstat, and heater hoses in 200k.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313950 01/05/20 02:24 PM
J
joegreen Offline
J
I have a Ford ranger with the 3.0 Vulcan. It has close to 200k and doesn't use any coolant.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Why can't they make an engine that will hold water? [Re: 01rangerxl] #5313951 01/05/20 02:27 PM
N
nobb Offline
N
Water pumps by the nature of their design, leak coolant in the shaft seal but at such a low rate that it's negligible. That's why there's a weep hole. Ideally if they could last 300k that would be great, but it's not unreasonable to say that water pumps are a regular service item every 200k. It is a moving part after all. But what's unreasonable is to have leaks from the various gaskets. There's a whole whack of theory behind gasket materials, design, and such...I would've thought manufacturers could have that perfected by now. But then again, I don't think most vehicle are designed with a 30 year service life like the Land Cruiser so OEMs may just do the minimum required sizing and selection of these parts to meet their design service life requirements and call it a day.
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313956 01/05/20 02:41 PM
Nick1994 Offline
Maybe don’t buy junk cars in the first place?
2015 Hyundai Genesis 5.0L 57k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313978 01/05/20 03:32 PM
L
Lubener Offline
L
1981 Capri 2.3 L
Weak gaskets that aren't up to sealing both aluminum and iron. Plastic manifolds do not belong on an engine.Go look at GM's 3.8 and see how their engineers screwed up a real good engine with their faulty manifolds and gaskets..
The "thinking" man's friend.
Re: Why can't they make an engine that will hold water? [Re: Burt] #5313982 01/05/20 03:36 PM
dareo Offline
Gaskets and seals are going to leak eventually, and are designed to be replaceable. What is the alternative? Assemble entire engine with JB Weld?
2018 Regal TourX, 2016 Golf Wagon 5MT, 2016 GMC 1500 SLT 6.2
