Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Rotella Multivehicle 5W-30
by js1956 - 05/31/20 10:54 AM
Tesla Model 3 Driving Guide
by JeffKeryk - 05/31/20 10:41 AM
Keep OE carb vs replacement
by JHZR2 - 05/31/20 10:00 AM
Gave away some of my stash
by Chris142 - 05/31/20 08:32 AM
Two year check in - Dewalt 20 V String Trimmer
by Snagglefoot - 05/31/20 08:07 AM
AbbeyRoad, RPF, Rayi, juca, jrow96
71584 Registered Users
100 registered members (2015_PSD, 10WSmuckers, ammolab, ArrestMeRedZ, Alfred_B, 330indy, 11 invisible), 2,316 guests, and 24 spiders.
Topics306,102
Posts5,286,447
Members71,584
Classic cars classic oils? #5313842 01/05/20 12:20 PM
slybunda Offline OP
So iv seen many sites selling whats called classic car oil. Usually its 20w50.
If you own an older car made in the 1960s does that mean you have to use oil technology from that period?
1995 Ford Fiesta 1.6i 16v Si
2000 Toyota Celica 1.8 VVTL-i
2007 Toyota Aygo+ 1.0i
Re: Classic cars classic oils? [Re: slybunda] #5313857 01/05/20 12:38 PM
B
BigCahuna Offline
B
Alot of cars from the '60's used 10w40 wt. Today's oils are worlds better then what was available then. The only thing to watch for is oils that can cause excessive cam lobe wear. I forget which ingredient you want it to be high in, I'm thinking moly. A motorcycle rated oil might cover that issue.,,,
Re: Classic cars classic oils? [Re: slybunda] #5313863 01/05/20 12:47 PM
L
Lolvoguy Online Shocked
Online Shocked
L
no.
Most oils are backward compatible. Meaning you can use newer oil on older machines.
That being said, there's a few additives you can purchase for older engines which benefit from anti-wear additives such as Moly or Zinc that are not required for newer engines.
Most anti-wear additives are found in many diesel motor oils, Rotella T4 being one of them.
Downside to diesel oils is they tend to have a detergent package that some believe is too harsh on gasoline engines.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Classic cars classic oils? [Re: slybunda] #5313896 01/05/20 01:40 PM
A
andyd Offline
A
Engines of 50s era had larger tolerances. For that reason alone, I'd use 20w50 or at least a 10w30 or a 30 or 40w HD. Checking the oil at every fillup was a good practice in those days grin2
Thick oil is better grin2
Re: Classic cars classic oils? [Re: slybunda] #5313897 01/05/20 01:41 PM
R
roadrunner1 Offline
R
I have several late 40’s flat heads and run 10w-30 HDEO in them. Most are dual rated (CK-4, SN).
If you have a worn engine with low oil pressure would be the only reason to jump up to heavier oil.
'15 F350 6.7
Re: Classic cars classic oils? [Re: slybunda] #5313899 01/05/20 01:49 PM
SpitFire6 Offline
Oils marked "Classic" or green metal cans for 60's & 70's cars are normally group 1 oils with old tech additives that generate a lot of profit for the brand owners. If you have an old car using oil or very low oil pressure, fix it?
Some say different.
2002 206 CC 2L 4Cyl. 0W40 FS
1972 Spit 2L5 6Cyl. 0W40 FS
Re: Classic cars classic oils? [Re: slybunda] #5313906 01/05/20 02:13 PM
6
69Torino Offline
6
There is no reason to use anything fancier than Rotella, Valvoline Premium Blue, Delo or Valvoline VR-1 in 10w-30 or 15w-40 in older engines unless you have a specific goal to achieve or a problem to work around. Or because you simply want something “special”.
Lots of guys I know with the local antique machinery club run Delo or Rotella 15w-40 in their antique tractors no matter if they are show rigs or working tractors.
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2000 Nissan Xterra
2008 Hyundai Santa Fe
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: Classic cars classic oils? [Re: slybunda] #5313926 01/05/20 02:39 PM
O
ofelas Offline
O
I've had excellent oil analysis results running Amsoil's 10w30 ZRT in 60's big block Chryslers.
R12 in the summer, Webasto in the winter, and cassette tapes all year.
Re: Classic cars classic oils? [Re: ofelas] #5313933 01/05/20 02:56 PM
6
69Torino Offline
6
I’ll be using that or Dominator 10w-30 in the FE for the Torino when it’s done. Was using VR-1. Sometimes even Valvoline white jug.
Using Valvoline Premium Blue in the ‘47 Ford tractor at the moment but going to Valvoline white jug 10w-40 for a few years since I picked it up super cheap.
2000 Nissan Xterra
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: Classic cars classic oils? [Re: slybunda] #5313936 01/05/20 03:02 PM
Chris142 Offline
The muscle cars with the high performance cams and stiffer valve springs like the 375 hp 396, boss 302,426 hemi may eat the cam if todays SN oils are used. Those cars need more ZDDP to protect their cams and lifters.
The regular run of the mill engines should be fine on the SN oil.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Classic cars classic oils? [Re: Chris142] #5313954 01/05/20 03:37 PM
T
Trav Offline
T
Not just engines with higher spring rates, while that certainly does exacerbate the cam lobe wear issue. Anything using rocker arms can be very hard on cam lobes because of the pressure multiplying effects of the rocker arm ratio.
Re: Classic cars classic oils? [Re: slybunda] #5313967 01/05/20 04:05 PM
N
nascarnation Offline
N
I've got a 67 Camaro 250 six and it seems to do fine with Pennzoil Platinum 5W30. I change it every three years.
Re: Classic cars classic oils? [Re: slybunda] #5313968 01/05/20 04:09 PM
RDY4WAR Online Content
Online Content
This really depends on the particular engine in question. If it's a stock engine with a stock cam, any API SN/SN+ oil will be fine. If it has an aftermarket cam with flat tappet lifters, you'll want a cam with more ZDDP (>1,000 ppm Zn).
I ran Amsoil Z-Rod 10w-30 when I had my '66 Mustang. If I still had it, I'd probably be using Driven GP-1 10w-30. The bearing clearances from that era weren't really wider, but had a wider tolerance. I've seen them be as tight as .0010" and as wide as .0026" from OEM. I would use a 30 grade so long as you have sufficient oil pressure. If the oil pressure is wanting to fall below 15 psi or so at hot idle, I'd go to a 40 grade.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Classic cars classic oils? [Re: andyd] #5313972 01/05/20 04:21 PM
A
ARCOgraphite Offline
A
Funny I just re-maned a 67 buick 340-4 block and the crank pins checked out at 0.0022 > .0.0023 which is a one-thousandth running clearance. I did clean up some pins on a ford 351 and that had a wide tolerance of almost a thou instead of a 1/2 thou or less.
That's about the best you can do given block distortion and crank harmonics.
I think I've seen some honda's running under a thou, I have never measured the bearing width or dia on those.
I might guess they need to be a tad wider and possibly fatter to work with the 20 grade low HTHS oil
Piston tech has moved a bit with the silicon hypereutectec and plasma moly short skirts but I'm hearing more noise with them.
Oh and I forgot , we tore into this "low mileage" engine to check out an odd noise.
It had two wiped cam lobes. Car had under 70K on it.
That's with high ZDDP oil and over the nose of under 160 lbs!
So after its broken in I'd go for the moly.
Race cam you should have roller followers. But.
"Motorcycle" and ATV 4T oil has HIgh ZDDP and is a light 40 grade.
its usually API S- rated in to the (now obsolete) high zinc period of pre SL
Perfect !
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Classic cars classic oils? [Re: slybunda] #5313997 01/05/20 04:50 PM
J
JeffKeryk Online Content
Online Content
J
The main issue is flat tappet camshafts with higher than stock valve spring pressure and/or higher lift ratios.
Shell Rorella T 15w40 used to do the trick, but I would not trust it any longer.
I have 2 classics with original engines; they need about 1200 ppm Zinc.
I recommend reviewing this analysis:
Flat tappet oils
If I ever pull apart one of these engines again I will stab a hydralic roller and be done with it.
And run 10w30.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
