Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Rotella Multivehicle 5W-30
by js1956 - 05/31/20 10:54 AM
Tesla Model 3 Driving Guide
by JeffKeryk - 05/31/20 10:41 AM
Keep OE carb vs replacement
by JHZR2 - 05/31/20 10:00 AM
Gave away some of my stash
by Chris142 - 05/31/20 08:32 AM
Two year check in - Dewalt 20 V String Trimmer
by Snagglefoot - 05/31/20 08:07 AM
AbbeyRoad, RPF, Rayi, juca, jrow96
71584 Registered Users
89 registered members (10WSmuckers, anndel, ammolab, A_Harman, 55hambone, 2015_PSD, 8 invisible), 2,386 guests, and 23 spiders.
Topics306,102
Posts5,286,465
Members71,584
Page 3 of 5 1 2 3 4 5
Re: Stupidest Designs....... [Re: ToadU] #5300308 12/20/19 09:57 PM
A
Anduril Offline
A
The 2.2 Cavaliers with the oil filter on the back of the engine and when you finally get your hand down in there just right and get it off, it spills oil all over your exhaust that you have to smell burn off for the next few days.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: Stupidest Designs....... [Re: The_Nuke] #5300311 12/20/19 10:01 PM
Skippy722 Offline
Originally Posted by The_Nuke
The late ‘90’s Chevy Tahoes has a real head scratcher built in at the factory as I recall:
the transmission control module/panel had some quirk that would end up causing a short on it out after enough miles/years, and the functionality it dropped as a result directly affected the fluid’s ability to circulate and keep the transmission cooled down when it was in operation.
Eventually the transmission would go out, but it was always on the vehicle owner to rectify since the underlying cause wasn’t discovered for many years. And even then, GM never admitted it was a factory defect in design, so they wouldn’t replace any of the transmissions their poor design choices ended up roasting.
And one more that bit me personally afflicted late 90s and early 00s Dodge Durangos (and other Dodge models as well, but I only know the Durango for sure):
They all had something wrong with their PCMs or how/where it was mounted that would eventually cause it to start overheating and killing the engine operation without warning. The driver would then be stranded where ever they could coast the dead vehicle and only have the cryptic “No BUS” message displayed on the EVIC as an indication of what went wrong.
The only remedy was to replace the PCM, but that could be an expensive approach since working ones were so rare to begin with.
Ah the good ol’ “No BUS” message. Or the craziness that can ensue from a battery that’s “mostly” okay, or CTM failures!
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Stupidest Designs....... [Re: Saabist] #5305739 12/27/19 06:33 PM
shiny Offline
Originally Posted by Saabist
The many vehicles that require removal of the entire dashboard to get at heater core, blower, and/or evaporator. It's like the entire car is built up around the HVAC box.
This describes the blend door actuator in Crown Vics. It's a cheap little $30 part that always breaks, with a 6-hour labor charge just to replace it. Every winter I commute an hour each direction with no heater because of this stupid design. The heater works GREAT, but the actuator died while on A/C. At least it's only a Phoenix winter, but still, driving in the 30's and 40's with no heat isn't what I call fun...
2008 Crown Vic P71; Kendall GT-1 Max Synthetic 10w30; Cooper CS5 Grand Touring radials; Raybestos police brake pads and rotors
Re: Stupidest Designs....... [Re: The_Nuke] #5305754 12/27/19 06:52 PM
Z
zzyzzx Offline
Z
I think that there is someone repairing these
Re: Stupidest Designs....... [Re: ToadU] #5310480 01/01/20 08:54 PM
L
Loobit Offline
L
Chevy Traverse/Buick Enclave/GMC Acadia 3.6 V6 oil changes make my head spin. Extremely cramped engine bays with oil filters crammed under the exhaust manifold, and that area you get your hand in is also surrounded in hot AC lines. No time to wait for it to cool down in a shop, especially during summer. The best way to do it fast is to get a giant shop towel over my arm and get my oil filter wrench in there without dropping it. Taking the oil filter off spills oil all over the subframe, so time is also wasted cleaning it even with a drain pan underneath. You'd be lucky if the shop you take yours to even bothers to change out the pil filter. I go through it because I wanna do an honest job.
Re: Stupidest Designs....... [Re: ToadU] #5310486 01/01/20 08:56 PM
L
Loobit Offline
L
Re: Stupidest Designs....... [Re: ToadU] #5310785 01/02/20 09:07 AM
L
littleant Offline
L
1990's i believe Cadillac starter under intake manifold.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Stupidest Designs....... [Re: ToadU] #5310814 01/02/20 09:33 AM
W
WylieCoyote Offline
W
2006 Mazdaspeed 6 apparently had faulty shifter cable ends (transmission end) from the factory. Mine kept popping off the transmission during the 1-2 shift. I could limp somewhere in 2nd gear and re-connect, but it was just dangerous to leave that way.
What I would've thought to be a simple replacement turned out to require the ENTIRE dashboard removed. The dealership said U.S.-made Mazda 6 wasn't plagued with this replacement method.
2015 Canyon 3.6
2018 Mustang Ecoboost Convertible
2017 Focus ST
Re: Stupidest Designs....... [Re: dnewton3] #5313513 01/04/20 10:47 PM
M
mbers1 Offline
M
+1 on the Ford water pump. Plus the headlights that are nearly useless on my 2014 Taurus.
Re: Stupidest Designs....... [Re: ToadU] #5313551 01/04/20 11:31 PM
6
69Torino Offline
6
When Blue Bird builds school buses, they run the interior wiring and THEN paint the whole interior white. So all of the interior wiring is painted. Makes tracing circuits an intolerable nightmare.
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2000 Nissan Xterra
2008 Hyundai Santa Fe
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: Stupidest Designs....... [Re: ToadU] #5313554 01/04/20 11:37 PM
6
69Torino Offline
6
Crown Victoria, Mercury Grand Marquis and Marauder rear window regulators. Mounted with rivets. Also window glass is riveted to the lift plate. Very nerve wracking drilling rivets out that mount glass. And metal chips everywhere. Then you have to find proper bolts, nuts, flat washers and lock washers to go back together with it all.
2000 Nissan Xterra
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: Stupidest Designs....... [Re: 69Torino] #5313599 01/05/20 01:16 AM
clinebarger Offline
Replacement rivets & tooling is readily available for this type of work. Knocking out the center pin on the old rivets before drilling them makes it pretty easy!
2001 Chevy Camaro L92/4L80E
Re: Stupidest Designs....... [Re: littleant] #5313601 01/05/20 01:23 AM
clinebarger Offline
Northstar, One of the easiest starters to replace as well.....It's the Toyota UZ V8 engines (Also under the intake) that are labor intensive.
The top bolt behind the solenoid on Ford 3 Bolt starters can be fun!
Re: Stupidest Designs....... [Re: 69Torino] #5314109 01/05/20 06:58 PM
J
Jarlaxle Offline
J
The Panthers are throwbacks, but Ford used rivets for window regulators for decades. I replaced the driver's one on the 1977 Cougar (the replacement came from a Torino)-pretty easy job, actually. Drilled out the rivets, installed the replacement with short bolts & nuts.
1979 Coupe de Ville, 542 stroker, Delo 15W-40, Delco filter
2013 Challenger SRT8 Core, Mobil 1 0W-40, Mopar
2011 Sportster 883, parked for winter SYN3 20W-50, HD black
Re: Stupidest Designs....... [Re: ToadU] #5314147 01/05/20 07:32 PM
J
jeepman3071 Offline
J
Just changed the oil on my mom's 2011 Honda Fit 1.5L. The oil fill hole is way too close to the cowl, in fact it is basically under the cowl, so it's very hard to get to. It also has a plastic screen about an inch inside the fill hole so the opening is not deep enough to allow most funnels to sit in the hole. I service several vehicles for family/friends of all makes, and this is the dumbest oil fill design I've seen. On the contrary, the drain plug and filter are super easy to get to and make for very little mess. crazy
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
