Which of the car value books are accurate ?
by WhyMe - 01/27/20 09:05 PM
Severe Service
by tiger862 - 01/27/20 08:53 PM
Platinum, Iridium, Ruthenium, oh my!
by Astro_Guy - 01/27/20 08:28 PM
Hit 200K miles today!
by SLO_Town - 01/27/20 08:20 PM
Valve Cover at 304849 miles
by Marco620 - 01/27/20 08:17 PM
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
IslandOil, 01VFR, M10, H20ham, Meletz
70544 Registered Users
60 registered members (2009Caraman, 2strokeNorthstar, 4WD, bbhero, BigCahuna, 5 invisible), 1,846 guests, and 16 spiders.
Topics300,653
Posts5,180,382
Members70,544
2011 Fusion Sport issues #5313479 01/04/20 08:49 PM
dan_erickson Offline OP
I have a 2011 Fusion Sport that has the 3.5L V6 that is shared with the MKZ, Edge, Taurus, and others. I have searched high and low on the internet, watched YouTube videos, and signed on a Fusion forum with out much help.
The issue I’m having is that intermittently the engine will stall at idle or very low speed like you just turned the key off. No warning or chugging just shuts off and then I can restart the car. No codes either. Everything i have researched pointed to a bad throttle body. Seems to be a common problem across Fords from what i can tell. Throttle body was already recently replaced so that leaves me a bit puzzled what do do next.
Second issues is that the brakes are soft. Not the fusion issue where the HCU is failing and the brakes randomly go soft. It feels like there is air in the system and i can not bleed it out.
Any help would be great!
15 Accord Coupe EX-L V6 Navi
Castrol Magnatec 0w20
Re: 2011 Fusion Sport issues [Re: dan_erickson] #5313481 01/04/20 08:55 PM
gathermewool Offline
The OEM brakes felt soft near the end of their life in our '14 FXT - you used the perfect word for it, since they were not spongy and braking power at full pressure seemed fine. Flushing the entire system with DOT 5.1 changed nothing but the color of the fluid (and was obviously needed for PM).
After a pad/rotor swap, braking was as new. Some effort was required to bang most of the pads out, especially in the front, meaning they were likely corroded AND possibly slightly cocked, though not visibly noticeable. I didn't bleed the system since it had been done recently.
You could also try bedding-in the brakes again if they have plenty of meat left on them. My issue is that the pads on both of my Subies are a major pain to install. It's a clearance fit due to a retention clip. I had no choice but to get it right with the new pads, but it's not worth the effort to pull them for lubing yearly or biyearly, as I used to do, which is a shame.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: 2011 Fusion Sport issues [Re: dan_erickson] #5313563 01/04/20 10:49 PM
O
oldhp Online Content
Online Content
O
Try cleaning the throttle body plate, might have gunk behind it not closing fully. Clean the MAF sensor. You need the MAF sensor cleaner here. TB cleaner shouldn't be used. When done reset it. Google/You tube is your friend here. Good Luck!!!
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: 2011 Fusion Sport issues [Re: dan_erickson] #5313569 01/04/20 11:13 PM
Nick1994 Online Content
Online Content
Might be a crank position sensor going bad. Had it happen to my Jeep, would randomly stall at idle. Though it wouldn't want to start usually until you waited a while.
2015 Hyundai Genesis 5.0L 56k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: 2011 Fusion Sport issues [Re: dan_erickson] #5313588 01/04/20 11:49 PM
W
wallyuwl Online Content
Online Content
W
Had a similar stalling issue with my boat motor, 1986 Johnson. Rebuilding the carbs fixed it. Did you try that? j/k
Re: 2011 Fusion Sport issues [Re: dan_erickson] #5313596 01/05/20 12:01 AM
clinebarger Online Content
Online Content
Have you scanned it with a scan tool or you relying solely on the check engine lamp to alert you of DTC's?
Was the TB replaced with a genuine Ford unit?
2001 Chevy Camaro L92/4L80E
Re: 2011 Fusion Sport issues [Re: dan_erickson] #5313624 01/05/20 04:13 AM
M
michaelluscher Offline
M
I hear there's a recall coming for HCU problems, best wait for it before spending any money
For drivability issues, I know Fords have chronic purge valve problems, how's yours check out?
I'd hook it up to FORScan, run the KOEO and KOER tests, look at fuel trims, etc before you start throwing parts at it
You haven't had the issue with coil pack failures taking out the PCM?
2006 Toyota Camry SE V6
131k
Re: 2011 Fusion Sport issues [Re: dan_erickson] #5313669 01/05/20 06:58 AM
DaleRider Offline
This has been a problem for Ford for years. In 2017, Ford recalled some Fusions and Edges (with the 2.0) with similar complaints as yours, OP. The problem according to Ford were badly welded studs on the torque converter in the trans.
There have been numerous complaints about other engine/trans combos of similar vintage Fords for stalling while driving....like just shutting off. Last I heard Ford was resisting a recall and there's a class action suit brewing. Good luck.
Re: 2011 Fusion Sport issues [Re: dan_erickson] #5313781 01/05/20 09:53 AM
I have not had a chance to do any live scanning with FORscan just checked for code and nothing. Throttle body was already replaced with a Ford unit.
Re: 2011 Fusion Sport issues [Re: dan_erickson] #5318260 01/09/20 10:18 PM
Cleaned the MAF and cleaned a handful of ground wire connections under the hood including the battery post. Nothing was excessively corroded but I’m out of ideas with out a check engine light
Re: 2011 Fusion Sport issues [Re: dan_erickson] #5332296 01/25/20 09:40 PM
The car has only stalled once since Jan 9th and that seems to be less frequent then before. I might replace the sensor and see if the problem completely goes away now
