Originally Posted by Jake_J
It's the latest and greatest BASF/Glysantin G65 coolant, which according to the datasheet they have added phosphate to the Si-OAT, to make it a PSi-OAT.
Quote
GLYSANTIN® G65® contains a corrosion inhibitor package based on
salts of organic acids, phosphate and silicate (PSi-OAT coolant).
GLYSANTIN® G65® is free from nitrites, amines and borates.
GLYSANTIN® G65® is officially approved by:
ï‚· DEUTZ DQC CC-14
ï‚· Volkswagen Group TL 774-L / G12evo
https://cdn.website-editor.net/61024071e2e048f499c0dc27deb2b46a/files/uploaded/Glysantin_G65.pdf
There is also a G64 green coolant which is the new Volvo coolant, and looks to be the same or very similar to G65 minus the dye added. It is mentioned that it is the "climate successor" of G48 and that it is compatible with flux-brazed aluminium heat exchangers.
https://schmierstoffe.kaufen/gb/fre...l_kleinfass/154-basf-glysantin_g64_green
https://img.diytrade.com/smimg/2916517/49552973-11834931-0/nn/f8b0.jpg
Can't find a SDS for G65 so can't say if they changed the amount of Glycerin that was in VW G13, although it is odd they went back in their naming convention and didn't name the new coolant G13+ or G14.
Yes it would appear to have the same inhibitor package as G64.
And yes it's odd they didn't name it G13+ or G14
