2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
26 registered members (Bailes1992, bachman, 97prizm, boostedtsiawd, ArrestMeRedZ, BlakeB, 1 invisible), 809 guests, and 16 spiders.
Topics301,814
Posts5,203,184
Members70,784
OE Caliper carrier bolt doesn't fit on reman #5312488 01/03/20 06:34 PM
L
lairdwd Offline OP
L
You guys ever see where they didn't tap it correctly in reman land? Or didn't tap it at all and the bracket bolt is a different size entirely?
The left caliper went on beautifully and had no issues with the old OE bolts.
I cleaned and lubed everything.. no go. too small.
I'm wondering if I heat up the threads if it will expand enough for me to catch a thread. But I don't want to cross thread it and then have them not take it back. Thoughts?
Re: OE Caliper carrier bolt doesn't fit on reman [Re: lairdwd] #5312491 01/03/20 06:36 PM
I
Imp4 Offline
I
Is it a coated caliper?
Sometimes the coating will cover the 1st thread and you can't get the bolt started.
Run a tap down the threads and try again.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: OE Caliper carrier bolt doesn't fit on reman [Re: lairdwd] #5312517 01/03/20 07:05 PM
E
eljefino Offline
E
Can you start the bolt through the back side? It might ram through whatever's in the way.
Re: OE Caliper carrier bolt doesn't fit on reman [Re: lairdwd] #5312578 01/03/20 07:57 PM
spasm3 Offline
Sounds like a cardone caliper.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: OE Caliper carrier bolt doesn't fit on reman [Re: spasm3] #5312610 01/03/20 08:32 PM
T
Trav Offline
T
Sure does, the op needs to check if the bracket is parallel if he does get it mounted.
Re: OE Caliper carrier bolt doesn't fit on reman [Re: lairdwd] #5312683 01/03/20 09:55 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
If reusing old bolts proper for caliper brackets? I was under the impression these should be new bolts always. As such, could the bolts be at fault from stretch?
Re: OE Caliper carrier bolt doesn't fit on reman [Re: lairdwd] #5312728 01/03/20 10:49 PM
The Critic Offline
This is the exact reason why I never use the supplied brackets.
I have seen this issue before. Plus pad clearance issues because the last guy ground the bracket too much to remove rust.
Reuse your old brackets.
2011 Toyota Prius 1.8L - 203K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: OE Caliper carrier bolt doesn't fit on reman [Re: The Critic] #5315054 01/06/20 05:08 PM
L
lairdwd Offline OP
L
Amen to that brother. That's exactly what I ended up doing.
If I had to do it all over again, I would have left the brackets in place as the metal itself was fine.
I also re-used the pins and bushings. The pins from reman land were a cheaper grade steel and the boots were adequate, but inferior to the 16 year old OE boots.
Re: OE Caliper carrier bolt doesn't fit on reman [Re: lairdwd] #5330862 01/24/20 07:48 AM
L
lairdwd Offline OP
L
Just got my core refund. Rockauto didn't seem to care that I gave back some parts from re-man land.
Pistons are holding up well for now, and the ebrake is like a hot knife through butter compared to the siezed one.
I'll give reman land some credit. The piston work looked solid - even on the entry level cardone I bought. These things did have QA stickers all over them. However, the diameter problem on the bracket was a huge f*** up. Plus the grade of the metal is decent, but not OE grade. Same for the boots and slider pins.
Thanks for making me think through this job. Between this and the brake line work, I feel I have graduated to 2 wrenches now.
banana
