Washing coolant down a storm drain?
by jharrison - 02/22/20 12:57 AM
storm door installation question
by FirstNissan - 02/22/20 12:13 AM
Kirkland VS M1
by A_Spruce - 02/21/20 11:24 PM
Ryan Newman bar
by P10crew - 02/21/20 10:16 PM
Good aftermarket shocks and struts?
by Micahmcmeen - 02/21/20 09:49 PM
Oil Marketing
by Mathew_Boss - 02/21/20 09:45 PM
run to your walmart NOW!
by willow - 02/21/20 09:39 PM
When redundancy goes out the window
by Exhaustgases - 02/21/20 08:34 PM
Please help me decide....
by ecureed - 02/21/20 08:03 PM
Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Hubbs1982, AW4BYT, YOUSSEF, b3e3, Bogdon
70775 Registered Users
33 registered members (BBDartCA, 750IX, aquariuscsm, 2013ecof150, bhmax, Aero540T, 2 invisible), 1,219 guests, and 18 spiders.
Topics301,769
Posts5,202,397
Members70,775
295/65/r20 vs 35x12.50r20 weight carrying differences #5291547 12/11/19 01:09 PM
J
J_mo Offline OP
J
The tires on my ram are now 5 years old and nearing 45k miles.
it's about time to replace, and while I'd prefer a 35x12.50r20 for a pair of SOTA 20x10 wheels I bought, I've noticed the 295/65r20 carry a considerable amount of weight in comparison.
Nitto puts them at a 35.45x12.13, rated at a hefty 4080lb per tire.
I pull a heavy 5th wheel so tires and weight ratings are something I do not mess with. .my factory tires are 265/65r20 and are rated at 3640 and have been sufficient for many miles of pulling.
2015 cummins 6.7 - DBL7349- eabp100- M1 5-40 TDT
2006 F-350 6.0 - Lf3656 - eabp110 - Rotella t6 / 5-40 M1 5-40 TDT
2018 Wrangler JL 3.6 (The lady's) under warranty - mopar mo349 - Valvoline Syn 0-20
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5291580 12/11/19 01:40 PM
dareo Offline
It will vary by manufacturer. I have the Michelin LTX in 35 12 50 20 size and it comes in at 3,195 lbs at 75 psi. Same LTX in the 295/65 size is 4,080 lbs at 80 psi. Flotation tires measured in inches somehow have a different "E" range than LT P metric sizes. I'm guessing it is more designed to go offroad than heavy loads.
My goal in selecting this tire was to have the smoothest and quietest ride possible. It is very good at that. Offroad traction is okay, good enough for me since i don't go looking for mud puddles to drive through. I'm happy to trade some off road traction for luxury car ride quality for the vast majority of miles that are on pavement.
You may want to stick with a P metric size for heavy tow.
2018 Regal TourX, 2016 Golf Wagon 5MT, 2016 GMC 1500 SLT 6.2
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5292137 12/12/19 07:25 AM
CapriRacer Offline
A word of caution:
P metric (and Euro-metric and Hard Metric) tires - that is, those designated as Passenger Car tires - have to have their load carrying capacity reduced by a factor of 1.1 when used on pickup trucks, SUV's, and trailers.
A 32X12.50R20LT and an LT295/65R20 are both LT designations (one flotation and the other LT metric) and those do NOT have to have their load carrying capacities adjusted for use on pickup trucks, SUV's, and trailers.
Because of this, I think it is a good idea to include the letters in front of or behind the numbers so that it is clear what is being talked about.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5293500 12/13/19 01:21 PM
02SE Offline
You might check the load rating of your wheels, too. Quite a few aftermarket wheels don't have the same load capacity as the tires that fit them. You should find the load rating somewhere on the backside of the wheel.
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5310162 01/01/20 01:58 PM
U
userfriendly Offline
U
Some 35/12.50/20s are now "F" rated with 80 psi instead of "E" rated 65 psi. Flotation sizes are measured by outside gross inflated dimension including tread depth.
I put Toyo CT 295/65/20 on Fuel Cyclone 20X10". The outside dimensions on those wheels is 12.2 x 35.3" . Load rating 129 @ 80 psi, I run them at 65 psi on a 2011 GMC D-Max.
The next size up, maybe in 2 years will be 325/60/20 (likely Nitto EXO) on 20X12" wheels.
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: userfriendly] #5310746 01/02/20 07:27 AM
CapriRacer Offline
Originally Posted by userfriendly
Some 35/12.50/20s are now "F" rated with 80 psi instead of "E" rated 65 psi. ….
I know that statement will confuse quite a few people. What userfriendly stated is true, and it's a long story why that is so.
CapriRacer
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5311057 01/02/20 01:12 PM
U
U
CapriRacer;
After posting, I thought you might catch my error;
295/65/20 load rating [email protected] psi, should be;
load rating 129
max pressure 80 psi
My tires had to be seated with starter fluid.
By installing the tires on the max recommended 10" wide wheels, sidewall flex is reduced and the tires should run cooler.
Re: 295/65/r20 vs 35x12.50r20 weight carrying differences [Re: J_mo] #5311325 01/02/20 05:22 PM
U
U
Another size I'm contemplating next time around is 35/13.50/20 also "F" rated 80psi cold max on 12" wide wheels.
Finding 20X12" zero off-set wheels is hard without springing for custom forged.
I need fender flares for what I have now, as mud & snow showers the side of the truck including the mirrors.
Those monster lifted trucks with negative off set 14" wide wheels are pavement princesses.
