1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Key FOB Will Only Open Doors
by Gebo - 02/20/20 03:47 PM
Leather Care
by Smoky14 - 02/20/20 03:36 PM
Does Caliper Pin Boot Over Bolt Or Sleeve?
by Fitz98 - 02/20/20 03:11 PM
Costco requiring membership for food court
by WhyMe - 02/20/20 02:56 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
41 registered members (bbhero, Black_Thunder, BBDartCA, 4WD, blufeb95, 4 invisible), 1,301 guests, and 17 spiders.
Topics301,729
Posts5,201,535
Members70,763
Page 1 of 3 1 2 3
Ford 2.7 ecoboost recommendation #5310384 01/01/20 05:53 PM
O
Oscar1 Offline OP
O
I have a 2015 F150 with the 2.7 ecoboost. I bought it used with 50,000 miles on it. I changed the oil immediately and put in Havoline ProDS 5w-30, and I plan on doing a UOA on it at 4000-5000 miles, which will be soon. I'm trying to decide on what to use next. With the recent thread about using a thicker oil in the 3.5 Ecoboost, I was thinking about trying that. Pennzoil Platinum Euro is currently on sale, so thought about maybe trying that in the 0W-40. It looks like it's SN-plus rated so should work ok in a GDI turbo motor. Other thought was Castrol Edge 5w-30, seems like the Ecoboost motors likes Castrol, at least the 3.5's do.
I won't know about fuel dilution or shearing until I get the UOA done, and not sure this motor suffers from it like the 3.5.
Any advice?
Re: Ford 2.7 ecoboost recommendation [Re: Oscar1] #5310407 01/01/20 06:10 PM
T
tcp71 Offline
T
It’s a hard working engine at 325hp and 400lb/ft of torque. Any 40 weight is fine. Or a 30wt with HTHS at 3.5+.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: Ford 2.7 ecoboost recommendation [Re: Oscar1] #5310422 01/01/20 06:33 PM
M
MParr Offline
M
The Havoline Pro DS 5W30 is perfectly fine for your 2.7 Ecoboost. So would be Mobil 1 original, QSUD. These oils are a little thicker out of the bottle. There are some 5W30 Euro oils that are VW 504.00/507.00 that may be just what you need. They will be a bit pricey. Do 5,000 mile oil changes and you should be fine.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Kendall GT-1 Max 5W30 FS & NAPA Gold 1348
2014 F-150 4x4 Now: Unk & Motorcraft FL-500s
Re: Ford 2.7 ecoboost recommendation [Re: Oscar1] #5310439 01/01/20 07:00 PM
J
jbutch Offline
J
Rotella Multi-Vehicle 5w-30 worked well in my TGDI, HTHS of 3.5 or more and is also SN+.
2015 Forester XT @ 104k km
Current fill: Pennzoil Euro LX 0w-30 with Fram Ultra XG7317
Re: Ford 2.7 ecoboost recommendation [Re: Oscar1] #5310445 01/01/20 07:07 PM
B
burla Offline
B
I'm not sure I would be using 0w40 in turbo direct injection engine, it's not recommended as far as I know in avoidance of lspi. Also moly is an lspi quencher, so if it were me I would look at short swing winter rating to weight oils with high moly and low calcium. Quaker state, RTAG, Amsoil, I do believe are all sn+ with higher than average moly. Might want to keep a short oci on that as well, like 5k mile range.
Re: Ford 2.7 ecoboost recommendation [Re: Oscar1] #5310454 01/01/20 07:19 PM
O
Oscar1 Offline OP
O
Thanks for the replies. I like the idea of a higher HTHS. Does the VW 504/507 certification ensure a certain HTHS level... higher than a normal 30wt? I looked up the Rotella multi-vehicle and it looks like it is only SN rated, not SN+. I'm sure it would work well though.
I guess I'll know more after the UOA, whether shearing is an issue or not. Just going back and forth now on what to use in the meantime, thicker 30w or go to a 40w
Re: Ford 2.7 ecoboost recommendation [Re: burla] #5310458 01/01/20 07:21 PM
O
Oscar1 Offline OP
O
Thanks for the advice. I was thinking the PP Euro 0w-40 might be a good fit being SN+, hoping that rating would take care of the lspi issues.
Re: Ford 2.7 ecoboost recommendation [Re: Oscar1] #5310465 01/01/20 07:36 PM
B
burla Offline
B
With lspi manu's have a real issue they can possibly deny warranty simple on oil choice. At a minimum with direct injection I would look at what oils meet your manu's spec. Good luck with it, Burla
Re: Ford 2.7 ecoboost recommendation [Re: Oscar1] #5310503 01/01/20 08:15 PM
J
jbutch Offline
J
I got confirmation that Rotella MV is indeed SN+ from an email I got from Shell, it is also very thick for a 30 weight, almost a 40 weight.
Re: Ford 2.7 ecoboost recommendation [Re: Oscar1] #5310537 01/01/20 08:53 PM
T
Triple_Se7en Offline
T
Castrol Edge worked real well in my GDI.
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: Ford 2.7 ecoboost recommendation [Re: Triple_Se7en] #5310588 01/01/20 09:58 PM
G
Gillsy Offline
G
I've not found anything that I like as much as Magnatec. I've run it in all my vehicles including a 2016, and 2018 F150 with 2.7 eco. I didn't like Edge.
Many are the afflictions of a righteous man
2019 Nissan Murano S
2018 Gravely ZT HD 52
2016 Kawasaki 650 Versys LT
2012 Mazda 3 Skyactiv 2 ltr
Re: Ford 2.7 ecoboost recommendation [Re: Oscar1] #5310612 01/01/20 11:01 PM
B
Black_Thunder Online Content
Online Content
B
My brother has a F150 with the 2.7 and we just did the opposite actually, last change put in Magnatec and next time will be going with Havoline Full Syn because its convenient 6 quart box packaging.
Probably stick with either or throughout its life or maybe opt for RGT at some point if there are some sales.
I think the first oil change we did on it after he got it around 16k was Pennzoil Platinum after that switched to Magnatec.
anyways no issues with either or and we'll see how the Havoline goes next time around.
I'd buy Callahan autoparts if I could.
Re: Ford 2.7 ecoboost recommendation [Re: Oscar1] #5310635 01/01/20 11:38 PM
double vanos Offline
Going through the UOA section here at bitog shows Magnatec to be a good fit with EB engines. In 5w30 it meets Ford specs too. I used Edge 0w40 in my gen 1 EB but Ford has these things sorted out now and there’s probably no need for thicker oil. Good news is, if you want to go thick, the engine does just fine with it.
5k OCIs are the key.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Ford 2.7 ecoboost recommendation [Re: Oscar1] #5311016 01/02/20 12:28 PM
Cujet Offline
I use M1 10W-30 EP in my 2.7EB 4x4 with good results.
Re: Ford 2.7 ecoboost recommendation [Re: Cujet] #5311025 01/02/20 12:39 PM
Brian553 Offline
+1
If you want something thicker, try mobil 1 high mileage 10w30, or delvac 1 esp
Page 1 of 3 1 2 3
