What oil to choose
Poland
Hello
I have a question for you I bought a Honda Valkyrie F6C 2014 year, mileage 1000mil.
What oil do you recommend for this engine.
Oils available in Poland are:
- Motul 300V 10w40
- Motul 7100 10W40
- Motul 7100 10W30
- AMSOIL 10W30 MCT
- AMSOIL 10W40 MCF
- BelRay 10W40
- ENEOS MAX Performance 10W40
- SHELL ADVANCE 4T 10W40 AX-7
Greetings from Poland
Here in the states, Honda recommended 10w40. Any of those will work just fine..
Recommended Engine Oil:
Pro Honda GN4 4 stroke oil (USA and Canada) or equivalent motorcycle oil.
API service classification: SG or Higher (except oils labeled as energy conserving on the circular API service label)
JASO T 903 standard: MA
Viscosity: SAE 10W-30
Originally Posted by Olas
Shared sump?
Yes, it's basically a Goldwing sans bodywork.
As for which oil you should use OP, that's up to you.
I will say that I use Motul 300V 4T in all of our sportbikes. I've tried most of the oil out there, but that 300v 4T just seems to let the bikes run and shift their best.
Originally Posted by kschachn
What does your owner's manual give as requirements? That is a lot more important than brand.
This is important.
Originally Posted by Maniek
Hello Greetings from Poland
Greeting from USA...
Any of the oils you list will meet and exceed your mileage expectations ... only the
freer flowing 30 grade will lower your engines operating temp and free up HP...
[Linked Image]
Every option in the first post are good options. I wouldn't go above a 10w-40 myself.
