Originally Posted by bullwinkle
Originally Posted by Sayjac
.....As an aside, I remember the name of the Puro customer service line that used to give out similar information. The Puro Response Office or PRO.
Those are the same clowns that told me a Bosch Distance Plus filter couldn't handle any more than a 3000 mile OCI-the PRO needs to be spelled "AMATEUR"!
Not long after M&H acquired Puro in 2013 that's when the silly information started coming from the newly 'oxymoronic' acronym named office. There were also several threads where the reps couldn't properly answer the question about filter warranty. Later in at least one thread they were corrected by a manager/higher up with the accurate information. I suspect that along the lines of the BD+ misinformation noted, which I also remember. And the topic can't use synthetic oil with a filter also given to at some point, possible voiding of filter warranty. Again, silly.
Haven't checked but I don't believe they use the name anymore. As noted earlier, I believe the answers similarly scripted here and don't 'imagine' the folks with the job have much if any knowledge of filter function. And speculating, likely paid in kind. While the some of the information nonsensical, none of it the engine damaging kind.
To topic, looking at an anecdote the spec recommended OPE filter, it uses a combo valve. All the more reason in this case, the Protec at least as good, likely the better filter.
