Anybody burn wood for heat? Advice please.
by dlundblad - 01/25/20 07:21 AM
2002 cummins
by coondog - 01/25/20 07:07 AM
New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
coondog, steelbeams, Pete44, Connie7, 2020XT
70520 Registered Users
85 registered members (2009Edge, BAJA_05, 2002 Maxima SE, Aero540T, atikovi, bachman, 10 invisible), 2,211 guests, and 17 spiders.
Topics300,520
Posts5,177,667
Members70,520
Bike been sitting...sitting....sitting.... #5309821 01/01/20 08:16 AM
B
BigJohn Offline OP
B
Gang, I found and purchased a "barn bike".....
Ok, so most won't consider this a barn bike since it is still pretty new, but here's the story.... 60 year old purchased the bike back in 2009. Put 120 miles on it and then let it sit in the garage until this week... when I purchased it. It has been sitting for 9+ years. Of course it won't start.... so my work begins.
It's a 2009 Kawasaki KLW250S that I purchased for the wife, so that we can explore a little more, off the tarmac.
I am completely ignorant regarding different types of cleaners, etc.... So I need the collective advice here.
Step #1: Drain the fuel tank.
Step #2: Pull the carb, take it apart for proper cleaning. (which I need to do anyway, as I need to re-jet.... live at 7,500 elevation)
Step #3: replace fuel line from tank to carb.
If this were your bike, what would you use?
I think it prudent to flush the gas tank..... but is there an additive or cleaner that I need to include with the fuel?
What is the best carb cleaner?
Once finished, should I run a tank of gas that has some sort of cleaning additive?
I've heard guys talk about SeaFoam, etc.... Just don't know what is the best.
Thanks in advance for the advice.
[Linked Image from i.imgur.com]
14 Ram 1500 EcoDiesel 4x4, T6 5w40
15 Mercedes ML250 BlueTec, PenEuro 5w30
16 Honda VFR1200x, T4/T6 Blend
14 BMW G650GS Sertao, T4/T6 Blend
10 Mahindra 2816 HST, T6 15w40
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5309832 01/01/20 08:31 AM
J
jhs914 Offline
J
I would pull the plug and squirt Marvel Mystery Oil or some type of top end lubricant into the cylinder and kick it over with the ignition off to get some lubrication on the cylinder walls and rings before cranking it.
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5309847 01/01/20 08:42 AM
DuckRyder Offline
See if you can get a gallon of berryman carb soak at the local box stores... it’ll come with a little basket for the small parts..
The tank is plastic right? I would just drain it and slosh some fresh fuel around in it...
Agree with lubing the Cylinder...
Change oil and filter (if it has one) tires and brake fluid.
Cool little bike.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5309851 01/01/20 08:47 AM
T
tc1446 Offline
T
As long as there is no rust in the tank, I'd just slosh some gas around and dump it, drain some clean gas thru fuel lines. After carb is cleaned, you should be good to go.
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5309867 01/01/20 09:04 AM
R
Rat407 Offline
R
it might not be as bad as you think. Did he store it with a full tank of fuel or at what level?
Very nice find! smile
2002 Silverado 5.3 0w-20 AMSOIL
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5309882 01/01/20 09:18 AM
spasm3 Offline
I'd probably just pull the carb disassemble and clean it out. Especially if you have to rejet. Should not take that long. New fuel filter. Run a few tanks of fuel through it and replace fuel filter again.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5309977 01/01/20 10:53 AM
G
gman2304 Offline
G
Nice find! Sea foam is a good cleaner. I would also add, change/flush brake fluid and coolant and service the chain.
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5310054 01/01/20 11:54 AM
H
HangFire Offline
H
A new carb is not too pricey.
https://www.amazon.com/Carburetor-Kawasaki-KLX250R-KLX250S-KLX250SF/dp/B07QR5NXNN
Apparently these were carb'ed in the US and EFI abroad. Gee, Thanks, Kawasaki.
Various musings: http://hangfire.net
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5310082 01/01/20 12:20 PM
Marco620 Offline
https://www.youtube.com/watch?v=tcqZwH8CK5g
Archoil 5100 for rust.
Try the Archoil 6200 with non ethanol fuel.
15' Civic 1.8 i-vtec 302,000 mi M1 AP 0w20 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
Doberman,Heckler & Koch & SONY Aficionado
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5310132 01/01/20 01:11 PM
B
BigJohn Offline OP
B
This bike has a metal gas tank. Actually surprised me that it does, but no worries with the gas tank, as I just ordered a 3 gallon IMS plastic. The stock is only 2 gallons, so an extra gallon will give us the range we need, hopefully 150+ miles.
A new plug is on order, so when I change it, I will add some Mystery to the cylinder.
And yep.... I have a new air filter and 3 new oil filters on order. I will dump the 10 year old factory fill..... pour in Rotella T4 and run it for a good, long bike ride, getting it good and hot and mixed up.... Come home and dump it. Change the filter and then pour in my own mix (half T6 and half T4). Probably over-kill.... but I only blow a filter and a quart of oil.
I also found an FMF PowerCore4 on clearance on Ebay for this bike and I will be stripping off all of the Kalifornia emissions, opening up the air box where she can breath..... so the jetting might be an experiment for a while.
While there is ice and snow in my subdivision for the next 2 month..... I will pull off the forks and replace the seals and dust covers and refill with some new, 5w fork oil... cause I just noticed they are leaking. I will also lube the steering stem bearings.
Not wanting my wife riding on 10 year old tires, I ordered new sneakers and new tubes. While I have the rear wheel off, I will pull the swing arm bolt and lube the swing arm bearings.
Dumping the brake fluid or having to do anything with the brakes will probably wait until the 20-21 winter.
Coolant is an easy flush and fill and will be done before trying to start.
Re: Bike been sitting...sitting....sitting.... [Re: HangFire] #5310138 01/01/20 01:24 PM
B
BigJohn Offline OP
B
I've tried Chinese Carbs twice and they were a disaster on other bikes and a genset...... never again.
I'm much smarter and wiser to rebuild the Keihin.......
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5310156 01/01/20 01:45 PM
BusyLittleShop Offline
Did you mean 2009 KLX250S???
What ever you do... first spin the engine over without starting or until
the red low oil pressure light extinguishes to force fresh oil between
crankshaft and the journals... this action is necessary to prevent any
metal to metal wear on start up... because after 10 years the risk is
that the oil separating these critical parts is unknown...
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5310165 01/01/20 02:00 PM
CT8 Offline
Put new gas in the tank. Drain the float bowl ,new engine oil and see if it starts and runs. Go from there.
2015 F150 2.7
2018 F350 6.2
Re: Bike been sitting...sitting....sitting.... [Re: BigJohn] #5310166 01/01/20 02:01 PM
CT8 Offline
2015 F150 2.7
2018 F350 6.2
Re: Bike been sitting...sitting....sitting.... [Re: BusyLittleShop] #5310213 01/01/20 03:06 PM
B
BigJohn Offline OP
B
Yes, KLX250S... that was a typo.
You guys may laugh at this, but the local bike mechanic that I admire the most and usually get his opinion... said to do this.....
Get three friends..... lift the bike and turn it upsides down. Set it on blocks on the ends of the handlebars and seat. Let it rest in that position, over-night. Next day, turn it back over for a few hours, before you try to start it. He claims the oil will penetrate all the important parts of the top-end and then when it is turned back over for a few hours the oil will settle back in to the sump and be ready for some cranking.
Him telling me to do this, sparked my memory of a situation I was in a while back. A few years ago I purchase a very nice Honda Genset that the owner said was seized. The Genset was basically brand new, but had sat in a storage shed unused for 4 years. When I tried to pull the cord... it was seized. The small engine mechanic that I occasionally use told be to turn it upside down and leave it that way for a week. Then flip it over... after about an hour, see if you can pull the cord. It worked like a charm and that Genset has been working perfectly for me for years.
Maybe the bike is about to go... rubber side up!
