Wheel bearing grease discussion
by Zahndkile - 04/01/20 11:10 PM
Low mileage Hundai Kona 5w-20 or 5w-30?
by j_mac - 04/01/20 10:43 PM
Napa platinum and Napa oil
by NavyVet88 - 04/01/20 10:29 PM
5.0 oil leak f150
by oilstudent24 - 04/01/20 09:17 PM
Dodge Durango 3.6L - HPL 5w-20 - 5,000 Miles on oil
by wwillson - 04/01/20 09:14 PM
Does a cold engine make more power?
by Avery4 - 04/01/20 08:48 PM
Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Code, Adam1, ripcord, KenoshaWizard, junipertoxic
71074 Registered Users
70 registered members (Aero540T, Aaron_Patton, AC1DD, apollo18, bdcardinal, 4 invisible), 1,144 guests, and 17 spiders.
Topics303,465
Posts5,235,629
Members71,074
Rislone Additive success?? #5309104 12/31/19 12:02 PM
spk2000 Offline OP
Wondering who has used this product with success and what was the best manner to use it. Kind of a long shot but I am willing to give it a shot. 2001 Sable transmission is slipping. Cannot climb my steep hill driveway anymore.
https://www.amazon.com/gp/product/B0036Z61MW/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Rislone Additive success [Re: spk2000] #5309106 12/31/19 12:03 PM
spk2000 Offline OP
Any other products that might help would be appreciated as well. Not expecting it to work but a rebuilt transmission has been quoted $4 - 4,500 and a used one $2,5 - 3,000. Car is simply not worth that much so it may be scrap if no cheaper alternatives can be found.
Re: Rislone Additive success [Re: spk2000] #5309119 12/31/19 12:15 PM
B
Brian123 Offline
B
Have you checked your transmission fluid or recently done a pan drop and filter change?
Re: Rislone Additive success [Re: spk2000] #5309137 12/31/19 12:33 PM
dogememe Offline
Try the Bars Transmission Repair that comes in the weird two part bottle. That fixed a transmission for me once. Fixed it completely after about 20 minutes of driving with it in there and that "repair" lasted months.
Idk if the Rislone product is any different since Bars and Rislone are the same company.
2010 Ford Escape 2.5 ~103K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~291K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Rislone Additive success [Re: spk2000] #5309177 12/31/19 01:23 PM
J
Jackson_Slugger Offline
J
Rislone and Bars are one in the same company. I'd try the trans filter and fluid change first. Then add something...
This is the Bar's product: https://barsleaks.com/product/transmission-repair-1400/
Re: Rislone Additive success [Re: spk2000] #5309211 12/31/19 01:58 PM
Chris142 Online Content
Online Content
30 years ago a bottle of Trans-X fixed a slipping auto once.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Rislone Additive success [Re: spk2000] #5309228 12/31/19 02:18 PM
spk2000 Offline OP
No fluid was not changed recently was planning to do a transmission fluid change in the spring. Now it's slipping so I will do a fluid change and try an additive such as Bars or Rislone product and will look into the Trans - X too. Hoping for a low cost solution to get me by a little longer. 2001 with 175,000 miles. Like the car but not enough to put more into than it's worth.
Re: Rislone Additive success [Re: spk2000] #5309249 12/31/19 02:35 PM
E
ET16 Offline
E
Try the fluid change first. You might not need any additives.
Re: Rislone Additive success [Re: spk2000] #5309251 12/31/19 02:38 PM
O
Oro_O Offline
O
I recently had success reviving a weak Honda transmission. It was shifting lazily and at low rpms, flaring on 2-3 and 3-4 upshifts. Here's what I did:
a) Added about 3~4 ozs of Chemtool B-12 to trans.
b) Let my 16 year old step-son practice parallel parking it for about an hour (this really helped!)
c) Next morning it was dramatically better (alternatively, drive it a week wink ).
d) Did a drain and fill with MaxLife, drove it another week.
e) Drained/filled again with Lubegard ATF
The transmission is now excellent, no flare, shifts firmly and at much better shift points - much higher than before. Each of the three steps had a distinct impact (additive, 1st d/f with Maxlife, 2nd d/f with Lubegard). The trans. is only 6.9 qts and you get about 3 qts with each d/f, so this was a substantial fluid swap even though only two drain/fills. I'll do a third with more Lubegard in 10 or 15k miles.
IDK Honda's well but the cw is the seals in the valve body get hard and can't make adequate line pressure. My experience seems to validate that as seal conditioning would happen with each step. I can't say if that's your problem, but this sure worked for me, but it wasn't as bad as your situation.
Re: Rislone Additive success [Re: spk2000] #5309253 12/31/19 02:39 PM
B
benjy Offline
B
do 2 or 3 changes as you only get some of the fluid, cheep if you DIY it + use supertech from wallys
Re: Rislone Additive success [Re: spk2000] #5309287 12/31/19 03:19 PM
K
Kira Offline
K
We had a 1991 Taurus with a bad transmission. Ford replaced it because it failed with fewer than 60K and was a Ford Program Car (a Budget Rent-A-Car fleet return).
Were they bad for 10 years of production?
Re: Rislone Additive success [Re: spk2000] #5309311 12/31/19 03:38 PM
69GTX Offline
I'd use one of the Lubeguard additive products before using Rislone. Lubeguard knows transmission and their stuff has a good track record of actually improving your transmission.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Rislone Additive success [Re: spk2000] #5309394 12/31/19 05:42 PM
J
J
I have the same car as you actually, I'd do the pan drop and make sure you use Mercon V, but you'll get out less than half of the fluid. Have you ever topped off the tranny with, or used, a non Mercon V fluid?
Re: Rislone Additive success [Re: Kira] #5309397 12/31/19 05:43 PM
J
J
No, it's a related but different transmission that was improved and pretty reliable, unless you use anything other than Mercon V...
This might help if you have Dex/Mercon III in it or something: Lubegard
Re: Rislone Additive success [Re: benjy] #5309406 12/31/19 05:51 PM
J
J
But it has to be Mercon V. Not just any Dex/Merc.
[Linked Image from i5.walmartimages.com]
You can also buy an aftermarket transmission pan for less than $50 with a drain-plug in it...
