Originally Posted by wowthisexists
I used up the rest of my May 2017 brake fluid.
2.5 years old. Car stops better than ever!
The 1 bottle did 3 different cars in 3 different years!
Don't believe the fake news hype of OCD suckers throwing out perfectly good fluid just because it's 2 days old.
Cars drive around with literally 20 year old brake fluid and no one died with no brakes.
No, many have died due to brake failure with old brake fluid as the cause. You have NO support for the opposite assertion.
But being a cheap Scot - Pol mutt, If I use two oz of brake hydraulic fluid, I'm
capping the bottle tight and it goes back on the shelf. For next time. I might write a "opened on" date and not use if its over 5 years old. Def not use if over ten years old.
Not much if any moisture to absorb in a closed container - compared to the installed systems on the car.
Now your fluid near the calipers and at the reservoir absorbs lots of moisture, and if you ever pulled apart calipers - which are subject to a hot water wash in the rain and salty snow wash in the Winter - you would see the rust and junk in there from moisture attacking and corroding the metal.
So flush is necessary every 2 years or so in harsh climes. Maybe in the desert you can go 5 years
