Originally Posted by Gebo
Originally Posted by Spktyr
The Toyota and Lexus factory tool is an end cap wrench. I don't see any reason to use anything else on these vehicles.
You don't have to use the factory one, even if you use factory filters. I use factory filters on my 4Runner, as does my friend with a GX470, and we both have aftermarket cap wrenches for the factory filter. This is the one I use:
https://www.amazon.com/gp/product/B002INVD4Y/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
A cap wrench is, again, the factory specified method for removing the filter - and on my 4R, it is literally the only way to get the oil filter off without having to remove the factory skid plate.
Does it do the cartridge and spin on filter's?
That is only for spin on. You want something like this for canisters: https://www.amazon.com/Motivx-Tools-Toyota-Filter-Engines/dp/B00XTAGHU0/ref=sr_1_1?crid=2KNZ0ZEUDV0GA&keywords=canister+filter+wrench&qid=1577743192&sprefix=canister+filter+wre%2Caps%2C133&sr=8-1
I also use a big 1/2" ratchet for my canister filter housing. It goes on pretty tight and it's not easy to remove. Tons of videos on youtube showing how to replace the filter in the canister where to put the o-ring and where not to put the o-ring.
