Originally Posted by Cujet
Originally Posted by blupupher
There are arguments for both on those motors.
Arguments for thin oil is the VCT solinoids and phaser working "better" as well as getting the timing chain tensioners under pressure faster.
Arguments for thick are better oil pressure overall
The first part is not really so in practice. The oil pump in these 5.4L engines has a steel backplate that leaks oil. The result is that thin oils don't get to the tensioners and VCT/Phasers properly (with sufficient pressure and volume) . Especially the LH cylinder head. Furthermore the tensioner gasket has a tendency to leak or blow out. A bit of the thin oil escapes here too. Leading to very low oil pressure at the head. Measurements of 5W-20 use show 5 PSI at the head when hot and near zero at idle.
A bone stock 5.4 3V engine benefits from a viscosity higher than 5W-20 in most locations.
I use 10W-30 synthetic with good results.
It's fairly well established now that 100K-120K is when problems start using thin oil in hot climates. And 200K when using a higher viscosity. There are always exceptions and so on, but the dealerships that do the work see the same things over and over and over.....
I agree, that's why I stated "arguments". You hear both ways, with some convincing explanations for both.
In the end, it is a poor design on Fords part.
Almost every post/how to page/video on fixing the phasers/timing chain/tensioners also says you must upgrade the oil pump (Melling 340 or 360 I believe??) to actually "fix" the problem (as well as changing the VCT solenoids). Most also say to use a xw-30 oil and do shorter oil changes (
As I said, my brother in laws 3v 5.4 is the only one I have personal experience with. His motor has been louder and more of the diesel sound with 5w-30 oils (being conventional oils from local oil change places before I started doing the changes). The first time I changed the oil for him his truck sounded horrible, drained out some bulk 5w-30, put in some Castrol 5w-20 syn-blend, and within 5 minutes, the motor was much quieter. Last 5 changes had been with varisous syn blends and syn oils, but all 5w-20 oils, and always quiet. Till the last one that I decided to use some Castrol Magnatec 10w-30 in, and the motor is still quiet.
No idea what oil will go in next, but probably some more syn 5w-20 I have in my stash (I mean, I don't want to use any of my "good" RGT oil on his truck
Originally Posted by mpgo4th
I've seen your filter cut open videos on that truck. Are you only using the tough guard kn that vehicle or is that your filter of choice on others as well?
I use whatever filter I have handy.
Currently it has a Supertec on it because I did not want to use my "good" filters from my stash on it (same filter fits my truck).
They always have tons of metal when cut apart, so not really concerned about the filter that much (so long as it does not tear). One of several reasons I do 4,000 mile intervals.
