30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
PastPresMike, RedBeard83, dfrybeck, ckinch1, EAC1
70494 Registered Users
106 registered members (2011335d, 53' Stude, 67ZL1, 2015_PSD, 28oz, 1978elcamino, 9 invisible), 2,171 guests, and 16 spiders.
Topics300,385
Posts5,174,704
Members70,492
Exide Batteries #5306493 12/28/19 06:31 PM
N
NoahE Offline OP
N
I work on a small fleet of cars, and got lots of calls for new batteries this winter. We had a cold spell in New York that wiped them out! I never had good luck with Johnson controls batteries especially the ones made in Mexico. I saw Home Depot sold exide , and started using them about a year In a half ago. I also use Walmart’s batteries made by east penn. am I the only one who has had great luck with exide? Everyone to this day is still testing well over it’s rated for. Also, I see some of autozones econocraft are also made by exide, and I seen a picture online of a duralast gold that was An exide. Are they switching over from JC? I know exide gets a bad rep, but i haven’t had an issue. Even interstate is switching over.
Re: Exide Batteries [Re: NoahE] #5306505 12/28/19 06:45 PM
Dave9 Offline
AFAIK it's a regional thing, transportation (and supply) determines which battery is where.
I've not had any unusual problems with JC batteries, but I always buy their top tier flooded, nothing with econo in the name. IMO that' just asking for trouble in a colder climate. Whether they retain a lot of their initial CCA rating or not, it's still down to how much CCA they deliver in cold weather.
Re: Exide Batteries [Re: NoahE] #5306692 12/28/19 09:39 PM
P
PowerSurge Offline
P
It depends on what type of climate you live in. I’ve never had good luck with Clarios (JCI) or Exide down here. East Penn lasts longer for me and also with less instances of leakage.
Re: Exide Batteries [Re: NoahE] #5306770 12/28/19 11:52 PM
B
bbhero Offline
B
It depends upon a number of factors that Exide cannot necessarily control... Like if their batteries are left sitting unsold for a prolonged period of time and there is no maintenance charge applied. Even in a month a battery loses 5-12% of it's charge just sitting... Uncharged. That adds up very quickly obviously in say 4,5,6+ months.... Exide cannot control that not being done. The Exide batteries I saw at my Home Depot were very dusty and had old dates on them... 8 months up to 10 months old... Highly doubtful those batteries were ever charged either. A battery like that will not perform well in service due to permanent loss of reserve capacity and sulfated plates inside the battery. Exide cannot control lack of maintenance in those stores.
The leaking problem with their batteries could potentially be from people cranking way too hard on the terminals of the batteries creating a way for the battery to leak gases. If it is not that then it is from the caps on those batteries not being sufficiently sealed to prevent the internal gas from the battery from escaping causing the corrosion on the battery terminals... Or it could be from a alternator pushing too many amps to the battery on the positive side of the battery creating gases within the battery that causes battery terminal corrosion. Or the opposite with a draw on the battery causing the negative terminal to get corroded...
When buying any battery 1) freshness matters a whole lot with a regular flooded battery. 2) Properly installing the battery without compromising the battery case integrity is also important to prevent corrosion issues. 3) A properly functional alternator will not over charge the battery... ( Though in many instances now the charging algorithm is set that the alternator in many new cars actually chronically undercharges starter batteries ) 4) Preventive treating of the battery terminals with diaelectric grease will prevent any corrosion from battery off gasing... 5) How well the battery was treated in transport and storage prior to you buying it matters too... High temperature exposure and vibration is not helpful to the battery internal structure. 6) if you able to apply a recharge a battery to a true one hundred percent of static charge where it is only accepting half and amp per 100 amp hours the battery is rated for then longevity will be far more likely. Example my group 35 battery is rated for 55 amp hours... For it to be truly at one hundred percent charge it is simply 55 multiplied by 0.005= at the battery accepting 0.275 amps per hour or less than that it would be one hundred percent charged. If one can do this even once a month it will help with battery longevity a fair amount.
Nissan Altima 3.5 Coupe
Cam2 full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Exide Batteries [Re: NoahE] #5307299 12/29/19 05:19 PM
Donald Online Content
Online Content
Consider EP AGM batteries.
2015 Ford F-250 w/Powerstroke
Re: Exide Batteries [Re: NoahE] #5308553 12/30/19 08:49 PM
cronk Offline
I havent bought an Exide battery in about 15 years. Any of the top posts seemed to always have leaky damp posts. I had one in an s10 with side terminals that I got 5 or 6 years out of, that was about the best.
Had about the same luck with jci batteries.
Have the best life and driest terminals with Deka/ east penn batteries.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Exide Batteries [Re: NoahE] #5312772 01/04/20 12:13 AM
CR94 Offline
... am I the only one who has had great luck with exide?...
The one I had (from Rural King) did not leak and make a corroded mess, unlike the JCIs I had earlier.
2011 Toyota Prius now at 107K
Re: Exide Batteries [Re: NoahE] #5312861 01/04/20 06:47 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I’m having success with exide, group 78.
Re: Exide Batteries [Re: NoahE] #5312933 01/04/20 08:29 AM
W
willbur Offline
W
Sign of a shill is someone providing good review(s) of a product with a new account and low post count. Just saying...
Re: Exide Batteries [Re: NoahE] #5313335 01/04/20 05:09 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I kind of doubt that Exide is using paid shills on an oil forum, but I could be wrong...
Re: Exide Batteries [Re: JHZR2] #5313342 01/04/20 05:15 PM
W
willbur Offline
W
Born yesterday?
Re: Exide Batteries [Re: NoahE] #5313343 01/04/20 05:16 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Burden of proof falls on you.
Re: Exide Batteries [Re: NoahE] #5313347 01/04/20 05:23 PM
J
JustinH Offline
J
Just replaced a battery in my Escape today, installed a Walmart Mexico JC battery for $99, 2 year warranty.
Every one else wanted $150+ for a similar quality battery. Never thought to look at Home Depot for car batteries however. I have had no luck with batteries in South Texas, so have started going to Walmart because they are so easy to exchange.
'16 Ford Escape
'11 Scion XB
Re: Exide Batteries [Re: JHZR2] #5313385 01/04/20 06:16 PM
W
willbur Offline
W
I have nothing to prove. Line of evidence speaks for itself i.e. known behavior on many forums. Prove it was a "paid" shill then
Re: Exide Batteries [Re: NoahE] #5313712 01/05/20 08:07 AM
Online Content
The question at least for people around the northeast is why would you use any battery other than East Penn? The Walmart batteries are East Penn as well as some from NAPA and other places. No extra cost for East Penn.
Other areas of the country may have more difficulty finding East Penn.
