Originally Posted by spasm3
I would think perhaps xxx gallons of fuel per oil change would be a better measure than hours. Not sure what that number would be, maybe 300 gallons of gas?
I've proposed the same idea, and like it. That would give at least semi-appropriate extra credit for excess idling, short trips, towing, etc. The target number of gallons would obviously vary with the size of the engine. For road vehicles, how about a number of gallons equal to the the number it would consume under favorable conditions travelling the maximum distance the manufacturer recommends between changes?
I don't know whether they still do, but tractors used to have cable-driven mechanical tachometer+hour meters, wherein the "hour" display was actually just a geared counter that showed a number directly proportional to engine revolutions. For example, the one on my father's IH 444 would register one "hour" if you ran the engine for one hour at a constant 1700 RPM, approximately. At any other speed, or varying speeds, it still showed one hour every 1700×60 = 102,000 engine revolutions, regardless of actual time. We changed the oil every 100 "hours." That's about as good as miles or actual hours, but doesn't allow for load.
