RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
reylafo, PastPresMike, RedBeard83, dfrybeck, ckinch1
70495 Registered Users
106 registered members (2015_PSD, 90crvtec, 1978elcamino, AlaskaMike, aircooled, 2011335d, 8 invisible), 2,267 guests, and 21 spiders.
Topics300,388
Posts5,174,772
Members70,495
Bleed air and old fluid from ABS module #5305320 12/27/19 08:35 AM
dan_erickson Offline OP
Is there any way to bleed the air and old fluid from and ABS module with out a scan tool? The 2011 Fusion that we have, IMO, seems that the brake pedal is a little spongy. The car still stops fine but the pedal feel is not great.
I did just do a brake fluid exchange and bleed a couple days ago and that made the pedal feel a little better but not great.
15 Accord Coupe EX-L V6 Navi
Castrol Magnatec 0w20
Re: Bleed air and old fluid from ABS module [Re: dan_erickson] #5305324 12/27/19 08:46 AM
L
LotI Offline
L
Doesn’t look like it:
[Linked Image]
[Linked Image]
The sequence is RR, LR, RF, LF.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: Bleed air and old fluid from ABS module [Re: dan_erickson] #5305335 12/27/19 09:01 AM
J
jhs914 Offline
J
You might try what has worked for me in the past and drive down a dirt road and stomp the brakes several times to activate ABS. Then bleed the brakes again to get any air that escaped from the ABS module if you still don't have a firm pedal.
Re: Bleed air and old fluid from ABS module [Re: jhs914] #5305414 12/27/19 10:10 AM
Yes that’s what i was thinking of trying next
Re: Bleed air and old fluid from ABS module [Re: jhs914] #5305415 12/27/19 10:10 AM
Spktyr Offline
This doesn't work in a lot of recent ABS modules. The internal plumbing geometry will trap air in the system and there's a specific scanner-activated air bleed sequence that is absolutely required to get all the air out. Spent a week trying to help a buddy out with power flushing and the like on a BMW (standard Bosch ABS block) and we *had* to get a scan tool to work the ABS block to get the last air out. Same story on another friend's Mustang.
Re: Bleed air and old fluid from ABS module [Re: Spktyr] #5305510 12/27/19 12:31 PM
Was using the scanner pretty straight forward?
Re: Bleed air and old fluid from ABS module [Re: dan_erickson] #5305567 12/27/19 02:00 PM
Yah-Tah-Hey Offline
If the brake system has never been opened for component replacement and came from the factory without air in the system,NO.
Re: Bleed air and old fluid from ABS module [Re: Yah-Tah-Hey] #5305674 12/27/19 04:15 PM
Can’t say for sure because the car is used
Re: Bleed air and old fluid from ABS module [Re: dan_erickson] #5307632 12/30/19 03:30 AM
Spktyr Offline
It was a Snap-On scanner, and it was very straight forward. In the case of the BMW, there was a factory block bleed/purge command that you ran and then bled each caliper in an order and sequence stated on the screen, if I recall correctly. I don't recall how the Mustang worked as while I was the guy in the seat running the scanner on the BMW, on the Mustang I was on the calipers instead and didn't see the scantool screen much at all. :P
Re: Bleed air and old fluid from ABS module [Re: dan_erickson] #5316818 01/08/20 01:38 PM
T
timoboy Offline
T
Same issue for my Fusion. Got ForScan trial (free) which can do the bleeding, and HS/ MS switch equipped OBD dongle on Amazon ($20).
Note that early Fusions have an ABS module issue where it corrodes internally and gives a soft pedal. Ford has chosen to ignore the issue in the face of a govt investigation. Realistically, a $350 ABS module may end up needed to fix the pedal 100%. Mine is about 80-85% now, not worth the money for the new module on a 200k car.
Re: Bleed air and old fluid from ABS module [Re: dan_erickson] #5318265 01/09/20 10:21 PM
Using Forscan to bleed the ABS module and reverse bleeding the brakes helped some. I may do this again when i get some more time and hopefully it will be good
