Changed my drive belt a couple weeks back and noticed some moisture around the water pump. I swabbed it with a q-tip and it appeared to not be oil but likely some coolant. Water pump isn't a major job on this car since it's not linked to a timing belt, it's just a stretch fit belt over the main pulley.
Aisin branded water pump is about $60 and it comes with the new seals. Belt is $15. Could I ignore this until 75K miles when I'll do a large maintenance job? Right now at 68K
