5w-20 vs 5w-30
by joel95ex - 02/26/20 10:59 PM
Need help d/l'ing vids from JVC GZ-MG27
by daves66nova - 02/26/20 10:18 PM
Need a riding mower
by FirstNissan - 02/26/20 08:32 PM
Just bot Quicken 2020 Premier for
by Ed_T - 02/26/20 08:31 PM
Corona Virus and Car Sales?
by Vern_in_IL - 02/26/20 07:34 PM
Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
20 registered members (cjolson140, Char Baby, Dave_Mark, bworley, blufeb95, 2 invisible), 1,058 guests, and 14 spiders.
Topics301,965
Posts5,206,612
Members70,808
Ford Focus SE knocking sounds from bellhousing (6MT) #5303569 12/24/19 05:06 PM
P
Pew Offline OP
P
Hello ladies and gents,
Would anybody know if the 6 spd manual transmission on this engine (same as fiesta ST trans I think) has a peep-through hole where I can check the clutch assembly in the bell housing? I'm getting some nasty knocking sounds and I think I've narrowed it down to the clutch assembly. The noise seems louder up by the turbo but seeing as driveability was unaffected in my 1500 mile drive back home through the Colorado mountains, I don't think it's turbo related.
Symptoms: Really bad knocking sounds and the engine shakes like crazy but when I clutch-in the noise is gone. Once the RPMs go above 1000rpms, whether cruising or just pressing the gas while at a stop the sound goes away too. Drive-ability seems unaffected but I was in the middle of a roadtrip 1500 miles away from home before the noise started (drove the 1500 miles back without an issue.) Car is currently on stands and nothing looks broken from what I can see. I've had a similar knocking sound, but 10x quieter, since ~30,000 miles but I never thought anything of it since the car drove the same.
No modifications, car has 180,000 miles on it. I just got an oil change before the trip (~2000miles on oil + filter). Oil is still pretty clear and isn't milky.
Heres a link to the video: https://photos.app.goo.gl/AFQH9qnht6rW3DbV7
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Pew] #5303587 12/24/19 05:51 PM
A
ammolab Offline
A
Engine shakes? Do you have a broken engine or transmission mount?
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: ammolab] #5303590 12/24/19 06:00 PM
P
Pew Offline OP
P
That was the first thing I looked for but they all look intact.
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Pew] #5303725 12/24/19 10:44 PM
P
Pew Offline OP
P
Looks like there's a pressure plate recall for my car. Looks like I'm in luck, I'll just bring it in and get a new clutch assembly and hopefully that solves my issue.
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Pew] #5303727 12/24/19 10:48 PM
M
mattd Offline
M
There is probably broken/worn or loose spring on the clutch disc or there are some worn/broken fingers on the pressure plate.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Pew] #5303834 12/25/19 06:32 AM
M
Miller88 Offline
M
Which engine do you have? 1.0? The 2.0 NA only came with the MTX75 transmsision. Unless you have the ST 2.0T or 2.3 (1st generation US) , that is.
Either way, my old 2011 Focus 2.0 5 speed always had that rattle in the transmission. I was always told it was gear rollover noise, whatever that means. That's also the cause for the rattling in my ZF 5 speed 350 transmission when the engine is lugged down.
Edit, just watched the video. Could it be a problem with the dual mass flywheel?
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Pew] #5303876 12/25/19 08:06 AM
T
Trav Offline
T
Does it sound like this..
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Pew] #5303919 12/25/19 09:03 AM
Cujet Offline
While I don't have any vehicle specific knowledge, that sure sounds like a flywheel/clutch/pressure plate problem.
Typically when the clutch springs break, there is a buzzing sound upon a specific level of acceleration or deceleration. Along with a knock at idle when the clutch pedal is not depressed.
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Miller88] #5303939 12/25/19 09:37 AM
P
Pew Offline OP
P
Yep it's the 1.0L with the 6spd manual.
Thanks for the replies guys. The video is exactly what the noise sounds like. I may have just dodged a hefty repair with the recall.
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Pew] #5303987 12/25/19 11:09 AM
T
Trav Offline
T
A really common issue with VW/Audi cars, the turbo engines can really tear them up in a hurry if driven with any enthusiasm, the only real fix is a single mass flywheel.
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Trav] #5304158 12/25/19 05:18 PM
P
Pew Offline OP
P
That's good to know, I never knew something like that existed. All the clutch issues I've ran across were from broken throw out bearings or clutch forks.
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Pew] #5330257 01/23/20 11:33 AM
P
Pew Offline OP
P
Hi folks, an update:
So the dealer won't cover it under the recall because it passed the "clutch slip test" but they did say the flywheel, TOB, and the bolts are all damaged. They'll replace it all for the lovely price of $1020. I really don't have any other choice since the backup car I'm using has summer tires and I do NOT want to be driving that in this freezing weather (plus snow/ice.) I'll pay it at the dealer but should I contact Ford for a [censored] statement to see if they'll reimburse me, maybe part of the cost if not the whole thing? The description of the recall is down below. What else should I do? Can I ask the dealer for the damaged parts back in case Ford corporate wants to see them?
RECALL
CLUTCH PRESSURE PLATE CRACKS
NHTSA Recall Number: 18V169 NHTSA Date:MAR 12, 2018 Ford Recall number: 18S07
Status:11 - RECALL INCOMPLETE
Recall Description:CLUTCH PRESSURE PLATE CRACKS
Risk to Safety:THIS MAY RESULT IN DAMAGE TO THE TRANSMISSION ASSEMBLY, FLUID LEAKS, AND POSSIBLY A VEHICLE FIRE.
Remedy Program: FOCUS: FORD MOTOR COMPANY HAS AUTHORIZED YOUR DEALER TO REPROGRAM THE POWERTRAIN CONTROL MODULE (PCM), PERFORM A CLUTCH SLIPPAGE TEST, AND REPLACE THE CLUTCH ASSEMBLY IF NECESSARY. FREE OF CHARGE (PARTS AND LABOR). FUSION: FORD MOTOR COMPANY HAS AUTHORIZED YOUR DEALER TO REPLACE THE CLUTCH ASSEMBLY FREE OF CHARGE (PARTS AND LABOR).
Manufacturer Notes:TO CHECK FOR NON-SAFETY-RELATED PROGRAMS APPLICABLE TO YOUR VEHICLE, SEE HTTP://WWW.FORD.COM/ OR CALL YOUR FORD DEALER.
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Pew] #5330602 01/23/20 07:08 PM
DuckRyder Offline
Search that recall number on NHTSA, theres some interesting reading in the documents.
I feel like I’d be on the phone to Ford and NHTSA... If it is under a recall for a defective pressure plate and they’ve determined it has a bad pressure plate it seems a bit irrelevant whether is passes a slip test or not...
On the other hand at 180,000 it might just be worn out In which case it seems like it would fail the slip test.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Pew] #5330633 01/23/20 07:44 PM
Z
zzyzzx Offline
Z
Good luck with that at 180K miles!
Re: Ford Focus SE knocking sounds from bellhousing (6MT) [Re: Pew] #5330662 01/23/20 08:18 PM
E
E365 Offline
E
Very interesting result from the dealer. I have the same car (Focus 1.0 / 6M) and just assumed that recall was a new clutch assembly and new programming - no questions asked.
I’m at 85,000 miles and was just planning on waiting until past 100,000 miles, to get the most life out of this clutch I can. I doubt I’ll ever “wear it out” though.
Whatever's on sale...
