Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
67 registered members (alarmguy, AndyB, aba4430, aquariuscsm, 4WD, Aero540T, 7 invisible), 1,628 guests, and 20 spiders.
Topics301,732
Posts5,201,646
Members70,766
08 Mini Clubman S Check Engine Light no codes #5302903 12/24/19 02:03 AM
G
Garyd Offline OP
G
The Check Engine Light just popped on on my 08 Mini Clubman S and I have taken it to 3 different places to scan for codes and no codes are coming up. The car has recently been idling rough and sometimes dies upon start up after it sits overnight or longer but after about 30 seconds to a minute or 2 it starts idling fine and it runs smooth with no seeming problems after that. This started happening about a week before the check engine light came on.
I don't drive the car a lot. It is an 08 and only has about 33k miles. I would try to drive it at least every 2 weeks depending on the weather but recently I've decided to drive it more so I've been driving it almost daily.
Re: 08 Mini Clubman S Check Engine Light no codes [Re: Garyd] #5302990 12/24/19 06:38 AM
N
NYEngineer Offline
N
Where are those things made, England? Maybe it has a code none of these code readers recognize.
Re: 08 Mini Clubman S Check Engine Light no codes [Re: Garyd] #5303016 12/24/19 07:19 AM
J
JC1 Offline
J
Sounds like the throttle body or IAC might need a good cleaning. Was the weather very cold that day? Is the car stored in a garage or outside?
Nobody can find the Codes? Where these shops you went to Mini Specialists or Euro Garages in Denver?
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 08 Mini Clubman S Check Engine Light no codes [Re: Garyd] #5303019 12/24/19 07:22 AM
Astro14 Offline
Generic OBD II readers can only see the OBD codes. In many cars, that covers about 5% of available/possible codes.
Get this read by a Mini specialist, not an auto parts store. You need the Mini software, or a professional code reader.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: 08 Mini Clubman S Check Engine Light no codes [Re: Garyd] #5303044 12/24/19 07:56 AM
M
mk378 Offline
M
Many PCMs require a constant power circuit from the battery to remember codes while the key is off. The lack of that power will cause the codes to not be saved. Also that could explain why it runs poorly for a while after every startup-- the PCM needs to recalibrate since the memory was lost.
So try driving until the CEL comes on, then hook up a code reader and scan without turning the key off.
Re: 08 Mini Clubman S Check Engine Light no codes [Re: Garyd] #5303314 12/24/19 12:07 PM
A
Audios Offline
A
I replace purge valves all the time on them for this issue. Most people say they stall coming to a stop as well. Internal valve fails and allows an unmetered air leak from the evap.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: 08 Mini Clubman S Check Engine Light no codes [Re: Garyd] #5303383 12/24/19 01:06 PM
B
benjy Offline
B
VAG vehicles aka volkswagen auto group "speak" their own language as well! i have RossTech software in my computer since my 2001 jetta, it gets on line updates for newer vehicles + saved me some $$$ in the past. i like minis but would newer buy one as they are problematic + being a BMW product parts + labor repairs are $$$$! you might join mini specific forums for free + get more info on your issue, good luck!
Re: 08 Mini Clubman S Check Engine Light no codes [Re: Garyd] #5303464 12/24/19 02:33 PM
dogememe Offline
You need a more expensive scanner that speaks Euro car haha. The regular OBD scanner the parts store will run for free may or may not have that capability.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: 08 Mini Clubman S Check Engine Light no codes [Re: benjy] #5303466 12/24/19 02:41 PM
G
Garyd Offline OP
G
I just went through 2 different Mini forums and it seems to be such a common problem with Minis that it is called the "Mini flu"! Seems like dealer service and Mini/BMW shops rack up huge bills trying to chase the cause of this. Sometimes it is from a battery that is getting near replacement, sometimes PVC valve, sometimes fuel filter, sometimes fuel pump, sometimes bad gas, etc. etc. Many owners go through all of these and still don't solve the problem. Sometimes going down to a lower octane of gas solves the problem. Dealer and Mini/German car shops all charge no less than $99 or more just to hook up a scanner. Guess I will have to take it to one of these shops to see what's up.
Re: 08 Mini Clubman S Check Engine Light no codes [Re: Garyd] #5303498 12/24/19 03:25 PM
M
MCompact Offline
M
The generic code readers will be of no help. Either get the Carly App or the Schwaben Scan Tool. I use both but either one should be more than adequate for your needs.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: 08 Mini Clubman S Check Engine Light no codes [Re: Garyd] #5303504 12/24/19 03:33 PM
M
MCompact Offline
M
You are just guessing unless you have the proprietary fault codes. A "Mini" shop that can't trace down a CEL is simply incompetent- period. That said, if you want to take a shot in the dark, you might try adding a 20 oz bottle of Techron to an almost empty tank and filling up with Shell V-Power NiTRO+ Premium fuel.
Mine:
2014 M235i
2009 Cooper Clubman
Wife's:
Son's
2009 328i
Re: 08 Mini Clubman S Check Engine Light no codes [Re: MCompact] #5303539 12/24/19 04:16 PM
G
Garyd Offline OP
G
I will give this a try. Do you think taking the negative battery cable off to reset the CEL before doing this is a good idea?
Re: 08 Mini Clubman S Check Engine Light no codes [Re: Garyd] #5303546 12/24/19 04:25 PM
M
MCompact Offline
M
I wouldn't bother with it; if you do you'll have to reinitialize your power windows and it still may not clear the codes.
Mine:
2014 M235i
2009 Cooper Clubman
Wife's:
Son's
2009 328i
Re: 08 Mini Clubman S Check Engine Light no codes [Re: MCompact] #5350182 02/14/20 05:52 PM
G
Garyd Offline OP
G
I tried your suggestion and it seemed to work. It stopped idling rough and dying at first start up and ran smooth and the CEL went out.
Then a couple of weeks after going through the tank of Shell V Power, I refilled it with Costco Premium gas and on the next cold start, it idled rough and died and then it kept cranking but wouldn't start. I let it sit for a couple of hours and it started but it idled rough for about a minute before it ran normally (the symptoms I was having before). A few days later upon a cold start, it idled rough and died, then wouldn't start (but it still cranks). I let it sit for a few hours but it still wouldn't start (but still cranks). After trying to start it for a few minutes, there was a real strong gas smell. It is acting like it's flooded. I've tried to start it a few more times but it just cranks and it almost catches but it just won't start and it starts smelling strong of gas. I checked the oil and I can smell gas on the oil dipstick.
I don't know if this is just a continuation of the original problem or bad gas from Costco. Can fuel injected cars become flooded?
Re: 08 Mini Clubman S Check Engine Light no codes [Re: Garyd] #5351143 02/15/20 08:28 PM
M
MCompact Offline
M
You really need to take it to a shop that knows Minis and has the proper tools to diagnose and service them. This shop is nearby and is affiliated with BIMRS so I'd suggest giving them a call.
Mine:
2014 M235i
2009 Cooper Clubman
Wife's:
Son's
2009 328i
