$.25 washer fluid at WM
by joel95ex - 04/06/20 12:13 AM
`16 Suburban OLM never tripped due to time
by zfasts03 - 04/05/20 11:26 PM
Straight 30W [Briggs & Stratton] @ Amazon
by SlavaB - 04/05/20 10:56 PM
Bosch 3323 Premium Filter Cut Open
by TrainingPolicy - 04/05/20 10:29 PM
CARQUEST Premium Oil filter 84341 Cut Open
by TrainingPolicy - 04/05/20 10:12 PM
C-1706 SAKURA Cut Open
by QuangTeo - 04/05/20 10:07 PM
Had to smile
by AZjeff - 04/05/20 10:04 PM
Childhood friend dies
by Marco620 - 04/05/20 10:00 PM
Leftover 100LL in vehicle
by PantherFan88 - 04/05/20 09:42 PM
The good old days.:)
by A310 - 04/05/20 09:04 PM
Harvest king switched suppliers confirmed.
by Micahmcmeen - 04/05/20 08:15 PM
Mobile 1 Synthetic 15w/50 - Not what it used to be?
by NorCalHD - 04/05/20 06:21 PM
Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
Recommendation for a high mileage engine
by khouan - 04/05/20 03:36 PM
My dog did not make it.
by Chris142 - 04/05/20 03:02 PM
Pennzoil Platinum
by tiger862 - 04/05/20 02:40 PM
F7daved, khouan, daniell, carguy1701, London
71106 Registered Users
38 registered members (Bailes1992, bbhero, carlprop, carguy1701, apollo18, ArrestMeRedZ, 3 invisible), 1,277 guests, and 18 spiders.
Topics303,657
Posts5,239,274
Members71,106
Page 1 of 3 1 2 3
Malibu Boats m5di strange oil pressure issues #5301403 12/22/19 09:30 AM
A
agarabaghi Offline OP
A
I know this is a boat engine, but the engine is really an L83 Chevy 5.3L marinized by Malibu / Axis boats.
The boat is brand new and would idle at 40psi and over 2000rpms would go up to about 60psi all normal.
The dealer came out and did the breaking service, where they replace the oil filter / oil / check for metal shavings in the tranny, etc.... at 25hours.
After this service, we noticed the oil psi gauge reading much higher.
Cold crank, idle 60psi
Engine warm (160F), idle 60psi
Engine warm (160F), 2000+rpm pegged at 80psi (highest the needle goes).
Engine warm (160F), about 25mins after running it 2000+ rpm, idle drops to 40psi
Engine warm (160F), about 45mins after running it 2000+ rpm, psi seems to level out back to 60psi.
I informed the dealer and they reached out to malibu and said high PSI reading happen when engine is overfilled. So we drained about 5.5qt (8qt total) on the lift using a dipstick pump, and refilled making sure not to pass the FULL line on the dip stick. Even with the dipstick reading 1/2 way between ADD and FULL same readings.
The dealer also informed me yesterday that they have now seen this on several other new boats after doing the break in service.
The dealer replaced the oil filter during the breaking service wit ha Hgnst filter, so I was thinking of replacing that with a WIX or NAPA version of the filter.
The manual for the engine / engine oil cap both state to use 5w-30, while i know the L83 engine from chevy says 0w-20.... but oil being hydraulic i dont think that would affect PSI?
Grasping at straws here, dealer said no issue running it as long as the pressure normalizes, but they are continuing to inquire with the manuf.
Re: Malibu Boats m5di strange oil pressure issues [Re: agarabaghi] #5301446 12/22/19 10:19 AM
Snagglefoot Offline
The pressure gage for the 5.3 is normally mounted on the intake manifold, driver’s side. The variance of the oil pressure between idle and higher RPM is controlled by an electrical solenoid. Close to the crankshaft pulley (edit) is an electrical connector that some folks have reported can get damaged.
I don’t know where the solenoid is but this should be checked. It’s possible it went into a failsafe mode and is causing too high of an oil pressure. That’s it for my knowledge on the oiling system. These changes were made in 2014. Good luck and please report back.
Go ahead and change the filter. It can’t hurt.
If you want the job done right......do it yourself.
Re: Malibu Boats m5di strange oil pressure issues [Re: maxdustington] #5301477 12/22/19 10:52 AM
A
A
Originally Posted by maxdustington
Nice bote. Keep the 5W30, change the filter. I would use whatever AC Delco is specced for the L83 just to be sure.
Start documenting everything. High oil pressure = overfilled seems like they are trying to blow you off. The dealer f'd something up during that first service.
if it was a normal dealer i would believe that, they arent blowing me. We are all friends and they are genuinely concerned and interested now. Will try the filter.
Re: Malibu Boats m5di strange oil pressure issues [Re: agarabaghi] #5301482 12/22/19 10:58 AM
O
OVERKILL Offline
O
Oil can certainly affect pressure. If they put 20w-50 in it, that could definitely explain why you are seeing much higher pressure now for example.
Re: Malibu Boats m5di strange oil pressure issues [Re: agarabaghi] #5301487 12/22/19 11:01 AM
A
A
This is the filter they used:
https://www.hengst.com/en/online-catalog/product/2537130000-00.html?catalog=na&freetext=7214
I cant find the micro rating for it, but the NAPA and WIX varients says 17 microns.
Re: Malibu Boats m5di strange oil pressure issues [Re: OVERKILL] #5301490 12/22/19 11:03 AM
A
A
Which is why I personally drained it and put 5w30 back in last night, the dealer also said they did another boat and put 5w30 in as well and it is now doing the same thing.
Re: Malibu Boats m5di strange oil pressure issues [Re: agarabaghi] #5301497 12/22/19 11:08 AM
O
OVERKILL Offline
O
Bizarre! You could definitely try another filter, but I have a hard time picturing it causing such a difference. Did the OEM tell you what viscosity was used for break-in? Maybe it was 0w-16 LOL
Re: Malibu Boats m5di strange oil pressure issues [Re: OVERKILL] #5301507 12/22/19 11:18 AM
A
A
I assume they come pre filled from the Manuf in TN, as the dealer does a breaking for 2 hours, then the owner can use the boat for 15-25hours before needing the first service.
After they they recommend oil and filter every 100hours or once a year.
Im gonna try the napa filter at this point since its the only part i havent done my self. Its cartridge style at the top of the engine so it should be easily done with out needing to drain the whole engine again.
Re: Malibu Boats m5di strange oil pressure issues [Re: agarabaghi] #5301511 12/22/19 11:22 AM
O
OVERKILL Offline
O
Keep us updated on the results, I'm interested.
Re: Malibu Boats m5di strange oil pressure issues [Re: agarabaghi] #5301512 12/22/19 11:25 AM
Snagglefoot Offline
Some pics would be cool. smile
Re: Malibu Boats m5di strange oil pressure issues [Re: agarabaghi] #5301520 12/22/19 11:42 AM
M
maxdustington Offline
M
Yeah, I looked up the engine code and the boats that came up were some super nice ski boats.
5W20 time I reckon. I guess the days of throwing the owner's manual out the window in regards to oil specs are over. I thought the 5.3 could run on anything?!
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Malibu Boats m5di strange oil pressure issues [Re: agarabaghi] #5301568 12/22/19 01:03 PM
A
A
I was under the impression with Oil being hydraulic ... psi would not be affect with slight variance in weight 5w30 vs 5w20 ... as long as the pump can handle it. The L86 version takes 5w30 from the manuf but the LT4 (L83 with a supercharger) takes 0w40.
I got the filter but I am tempted to try 5w20 or 0w20 though I don’t think 0w makes much of a different in FL.
Pics of the boat?
[Linked Image from i.imgur.com]
Re: Malibu Boats m5di strange oil pressure issues [Re: agarabaghi] #5301595 12/22/19 01:31 PM
O
OVERKILL Offline
O
The PSI you are seeing is the system resistance to oil being pushed through it. Ergo, the more viscous the fluid, the higher the resistance. This is why oil pressure drops as the oil heats, as viscosity reduces.
Re: Malibu Boats m5di strange oil pressure issues [Re: agarabaghi] #5301707 12/22/19 04:47 PM
A
A
possible.... no one knows why. Seems weird it would take so long for oil to get to it’s 30 viscous state
Re: Malibu Boats m5di strange oil pressure issues [Re: agarabaghi] #5301712 12/22/19 04:54 PM
O
OVERKILL Offline
O
30 is just a range of hot viscosity numbers @ 100C. Different engine and oil cooling designs will take longer or shorter to get the oil to its operating temperature, which will vary based on OEM spec. Some engines will not get the oil to 100C, some will get it higher than that; often significantly so. This also of course depends on operating conditions.
Page 1 of 3 1 2 3
