Camry vrs Sonata
by tblt44 - 01/28/20 07:50 PM
Parasitic battery draw.
by wtd - 01/28/20 07:49 PM
AAP clearance 2020
by GMguy84 - 01/28/20 07:34 PM
2017-2019 GLA 250 4-Matic vs BMW X-1
by HangFire - 01/28/20 07:20 PM
Good news for .300blk shooters
by The_Eric - 01/28/20 06:43 PM
‘16 Lexus GS350 vs ‘16 Lexus RX350
by miden851 - 01/28/20 06:19 PM
Stone guard removal
by dawgn86 - 01/28/20 06:09 PM
Craigslist is like a petty HOA now
by eljefino - 01/28/20 05:06 PM
Shoretel PABX - any experience?
by stockrex - 01/28/20 04:44 PM
Around Australia record in the 1970's
by sanoptic - 01/28/20 03:21 PM
Oil mixing...does density matter?
by LotI - 01/28/20 02:02 PM
Uh Oh. Subaru Front Halfshaft CV Going Bad
by ARCOgraphite - 01/28/20 01:25 PM
Help choosing the right oil
by CAJ1966 - 01/28/20 12:33 PM
Which cooler line is return?
by LeakySeals - 01/28/20 11:39 AM
New Havoline ProDS 0w20 boosted Moly?
by jayjr1105 - 01/28/20 10:59 AM
Diesel fuel pump, pump synthetic 40 weight?
by H20ham - 01/28/20 10:54 AM
Review: 2019 VW Passat Wolfsburg 2.0T
by wemay - 01/28/20 10:16 AM
Group 2 mix with Group 4
by ridgerunner - 01/28/20 09:50 AM
Power Steering Fluid for 54 Chevy
by ThomasJ49 - 01/28/20 08:54 AM
indigo2020, Towkid, denor, Jubaxtreme, CAJ1966
70551 Registered Users
121 registered members (55hambone, 97prizm, AC1DD, 2015_PSD, 2010Civic, 11 invisible), 3,042 guests, and 17 spiders.
Topics300,680
Posts5,181,010
Members70,550
Scope for auto diagnosis #5300963 12/21/19 04:47 PM
Donald Offline OP
Was watching South Main Auto video where Eric used a 4 channel oscilloscope to diagnose a Ford with smart charge system. He spent time to understand how the system works and to diagnose with both a scope and scan tool.
So my question is does the average Indy shop have a scope and do they take to time to diagnose problems with a scope.
Eric seemed to have an expensive Pico scope adapter that turns a laptop into a scope. Not a $100 cheapie.
But one needs the scope and knowledge to use it. It's a lot more knowledge required to use a scope than take a DVM and measure battery voltage.
2015 Ford F-250 w/Powerstroke
Re: Scope for auto diagnosis [Re: Donald] #5300972 12/21/19 04:58 PM
T
Trav Offline
T
I use an old Bear unit I got on the cheap used, it works fine.
Re: Scope for auto diagnosis [Re: Donald] #5301102 12/21/19 07:59 PM
A
atikovi Online Content
Online Content
A
Would an average person know how to interpret the squiggly lines on an EKG? Not likely. Pretty much the same with a scope. You need experience to tell what's normal and what isn't.
Re: Scope for auto diagnosis [Re: Donald] #5301118 12/21/19 08:19 PM
Silk Offline
My Fluke 98 used to go on every car that came into the shop...that's how you learn. Now it sits in a draw and never comes out, the scanner does it all these days.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Scope for auto diagnosis [Re: Donald] #5301224 12/21/19 11:00 PM
spackard Offline
The picoscope is, well, kind of expensive for a normal oscilloscope but most auto techs buy them.
They have a good library. You can download the software and run it in simulation mode on your computer for free, before you buy.
Trust me, it's the exact same software.
Problem is, once you come to a point where you need to see an AC signal, you don't have a choice, you must use an oscilloscope.
At that point, with Picoscope the choice is 2 channel or 4 channel.
Seems the lifetime is pretty long with these, kind of an industry standard, and they don't nickle and dollar you to death for updates.
In Eric's earlier videos he explained most of the time you can get away with what a scan tool tells you, but sometimes
you need to see the same input the car's computer sees (and he'd emphasize when you'd need the oscilloscope).
Re: Scope for auto diagnosis [Re: Donald] #5301763 12/22/19 05:01 PM
Donald Offline OP
Is there something unique about a Pico scope or does it just make a laptop function as a scope? Would a 2 or 4 channel Tektronix do the same as a Pico scope?
Re: Scope for auto diagnosis [Re: Donald] #5301917 12/22/19 07:52 PM
spackard Offline
You could probably do most work with a Tektronix, though my knowledge of those are the old analog versions.
Using a Picoscope is not like using an analog scope.
I know a lot of signal processing has to occur at the box; the PC/laptop is just a processed signal display.
You'll likely miss the signal in real-time; scroll back and zoom to look at an event.
(Whereas with an analog scope you either see the event in real-time.)
You likely have a higher Vmax with the Pico (+/-100V).
USB3 powers the Picoscope, so that's nice. No extra power supply.
It also does some bus decoding.
Re: Scope for auto diagnosis [Re: spackard] #5302150 12/23/19 07:02 AM
Donald Offline OP
The cost of the Pico scope rules it out for most shade tree mechanics. Is there anything for the shade tree mechanic who understands the basics of using a scope?
Re: Scope for auto diagnosis [Re: Donald] #5302340 12/23/19 10:25 AM
E
Exhaustgases Offline
E
Some high end 2 way scan tools have a built in storage O scope.
Re: Scope for auto diagnosis [Re: Donald] #5302790 12/23/19 09:16 PM
Silk Offline
Plenty of USB scopes out there, which is all the Pico Scope is.
Re: Scope for auto diagnosis [Re: Donald] #5302806 12/23/19 09:35 PM
clinebarger Offline
Honestly......Not many mechanics know how to use a scope!
A lot of manufacturers write their diagnostic information-Trouble Tree's right around the use of a scope! They will have you ohming wires & sampling voltages for hours in a process of elimination...........Toyota being a major exception, They encourage the use of a scope!
I have a Snap-on Vantage Pro, It's not nearly as capable nor does it have the resolution of a "top of the line" 4 channel Pico! But it does everything I need it to do on a professional level. Though I do wish I had more than 2 channels at times.
2001 Chevy Camaro L92/4L80E
Re: Scope for auto diagnosis [Re: Donald] #5303037 12/24/19 07:46 AM
J
JetStar Offline
J
I've been toying with the idea of getting a scope for multiple uses to include automotive, motorcycles, RC hobbies, etc...
I decided on Hantek scopes.
https://www.circuitspecialists.com/blog/best-entry-level-hantek-oscilloscopes/
https://www.circuitspecialists.com/digital-storage-oscilloscopes
They are available from many suppliers and have decent reviews.
2019 Road King Special
2018 Kawasaki Z900RS
2016 Suzuki DR650
2015 Road Glide
1978 Suzuki GS1000 (now 1085)
Re: Scope for auto diagnosis [Re: clinebarger] #5303829 12/25/19 06:18 AM
T
Trav Offline
T
True, they didn't teach that in trade school (that was a long time ago for me I don't know about today), I learned how to use one in a manufacturers school.
Re: Scope for auto diagnosis [Re: Donald] #5305568 12/27/19 02:02 PM
supton Offline
I've been wanting to buy my own Picoscope, I've been wanting to play more with electronics at home and a good scope would be a must. Although when I use one at work I often find only 4 channels limiting. Still. I do like Pico's when debugging stuff at my desk.
For auto work, I've been tempted to buy one of the cheapo things on Ebay. There's a bunch of cheapo single channels one there, which IMO are not much more than a graphing DMM--but that is probably all that is needed for some of the debug work (not debugging CAN or the like, but a simple PWM or O2 sensor? probably good enough). Now that I look I see the price has come down again.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 221k, his
Re: Scope for auto diagnosis [Re: Donald] #5306814 12/29/19 01:29 AM
spackard Offline
Supton - There's a seller on EBay that has two used (says look unused) Agilent U1602B Handheld Digital Oscilloscopes for sale, for $199 each. You'd have to spend more for probes, charger, maybe a current clamp.
Thing is - whenever I asked an EE about buying a 'scope they always asked me 'what is it you want to measure?'.
I didn't have a good answer (I buy test equipment first because I am curious, later finding a real use for it most of the time.)
So I lived decades without one, and I can do a lot without one. I suggest you ask yourself the same question,
as when you have the answer then the answer drives what type of 'scope you need.
My Picoscope I bought this year, having finally answered the question and having no other indirect method I could use. Measuring and comparing the raw signals of two knock sensors, so I could see what the computer was seeing.
