Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
25 registered members (Char Baby, Artem, BlakeB, carlprop, blufeb95, ArrestMeRedZ, 5 invisible), 1,301 guests, and 16 spiders.
Topics301,932
Posts5,205,733
Members70,801
Oil recommendation for 2014 2.5l Suburu Forester #5293908 12/13/19 10:50 PM
T
tomartomau Offline OP
T
Hi everyone,
Live down under and we will be traveling through the heart of Australia for Christmas.
It will be around 45 to 48 degrees Celcius I suspect and currently I am running a Helix (Penzoil) 5w30.
I am worried that the hot temperatures might degrade the performance of the oil and was going to change to a 5w40 Helix Ultra.
Is this 5w40 too heavy for the FB25 engine (non turbo).
Thanks in advance
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: tomartomau] #5293913 12/13/19 10:57 PM
A
addyguy Offline
A
Nope, sounds like a good plan.
2010 Kia Soul 2U - 2.0L I-4, auto; 152k miles.
Castrol Edge (black bottle) 5W-30; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: tomartomau] #5293914 12/13/19 11:00 PM
N
NO2 Offline
N
That is crazy hot! Engine internal operating temperatures will not vary much even at those temps. I'd stick with the 5w30. Try not to overload your cooling system with heavy engine loads.
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: tomartomau] #5293920 12/13/19 11:13 PM
G
geeman789 Offline
G
How hot is it inside your engine ? About 100*c +/- ... and that 5w30 works fine.
What does your owners manual recommend ? My 2011 Subaru recommends 5w30, but lists a thicker oil for HOT temperatures.
[Linked Image]
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: geeman789] #5293931 12/13/19 11:32 PM
T
T
The dealerships recommended 0w20, but imo that is just too thin for Aus.
The engine temps today at 33 degrees Celsius was 103 degrees but that was in stop start traffic.
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: tomartomau] #5293940 12/14/19 12:02 AM
Doublehaul Offline
I ran 0w40 in my fb25s many a time. No issues at all. They are known to use oil though so watch those levels!
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: tomartomau] #5294310 12/14/19 01:11 PM
G
geeman789 Offline
G
One often overlooked fact is that a 20 grade oil at 90*c is roughly the same viscosity as a 30 grade oil at 100*c, which is roughly the same viscosity as a 40 grade oil at 110*c. Expected oil temperatures are the primary factor in oil viscosity recommendations.
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: tomartomau] #5296202 12/16/19 05:32 PM
T
T
I decided to run the Shell Helix Ultra 5w/40 just over the hottest part of Summer here. The heat, bushfires and towing a light trailer all contribute to and increased load on the engine.
Thanks everyone for your replies
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: tomartomau] #5298591 12/18/19 11:55 PM
T
T
Hi everyone,
Just an update. I went with the 5w/40 Helix Ultra for the trip through the middle of Australia.
Currently outside is only 42 degrees Celsius, was expected to reach 45 degrees.
The engine temp has sat on 103 degrees which is to be expected and I think a bit better than what it could be.
There is so much carnage on the roads, hundreds (stopped counting at 200 kangaroos) at daybreak , a couple of beautiful wedge tailed eagles, goannas and even a minivan on the side of the road with a kangaroo through the windscreen.
There are a lot of bushfires in Aus at the moment but none encountered as yet.
Really happy with the Forester, the eyesight and adaptive cruise is helpful as is the good perifial vision around the vehicle.
Thanks everyone for your Suggestions.
P.S. I always run a White K&N filter also, far better than a lot of other non genuine offerings here in Aus.
Regards Tony
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: tomartomau] #5298650 12/19/19 04:18 AM
SR5 Offline
Hey Mate,
Glad to hear it all went well for you. That Shell Helix Ultra 5W40 is a great oil, good choice. I have a few mates with Subaru boxer engines and they mostly run 40 grade oils to help control consumption.
I had to change some holiday plans recently because of bush fires. We could really do with some rain.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: SR5] #5298774 12/19/19 08:17 AM
T
T
Yeah, sure can.
I think Warick is nearly out of water. I hope you can find a way to avoid the fires and still have your holiday.
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: tomartomau] #5299301 12/19/19 06:07 PM
T
T
The temperature in parts of Australia are melting the roads, the ambient temps are 121 degrees Fahrenheit.
The engine temp rose to 227 degrees farenheit yesterday, I hope the oil handled that temperature, any ideas when the oil starts to break down and not lubricate properly?
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: tomartomau] #5299613 12/20/19 05:33 AM
K
ka9mnx Offline
K
Above 250F is time to worry.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Oil recommendation for 2014 2.5l Suburu Forester [Re: ka9mnx] #5300493 12/21/19 06:56 AM
T
T
Thank you
