Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward, MrH1325
70486 Registered Users
107 registered members (AndyB, 14Accent, 2002 Maxima SE, ABerns, A310, aquariuscsm, 8 invisible), 2,291 guests, and 40 spiders.
Topics300,342
Posts5,173,738
Members70,486
Most Online3,825
Jan 19th, 2020
vw - adding external trans filter #5299239 12/19/19 04:59 PM
A
anderson Offline OP
A
just a quick question for all the minds of bitog
picked up a 2005 vw passat tdi (bhw engine code) 444,000kms ,
grabbed a wix 24762 mounting base and a 33343 out of my inventory was wondering if that filter would be suitable for transmission oil use
it is rated at 10 microns , im mainly trying to clean all the metal debris and nasty bits out of the transmission with 2 pan drops before switching to a 51515xp as the lifetime filter
pentosin aft1 will be used as the oil of choice
thoughts?
Re: vw - adding external trans filter [Re: anderson] #5299295 12/19/19 05:58 PM
Dufus2 Offline
The filter I suggest is a WIX 51269 (hydraulic filter) because of the 8 psi bypass and the beta ratio of 6/20=5/17 and it works very well on a transmission cooler line. not sure about the filter you suggested as the numbers suggest it may be a fuel filter.
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
Re: vw - adding external trans filter [Re: anderson] #5299351 12/19/19 07:07 PM
A
anderson Offline OP
A
correct , it is a fuel filter. i was just going off the micron rating and the fact that i already have a case of them
Re: vw - adding external trans filter [Re: anderson] #5299427 12/19/19 08:26 PM
Donald Offline
thoughts?
Magnefine since it has a magnet and media.
2015 Ford F-250 w/Powerstroke
Re: vw - adding external trans filter [Re: anderson] #5299552 12/20/19 01:33 AM
O
Olas Offline
O
Drain plug can feed the filter, fill plug can act as the return.
Put a big [censored] magnet in there and use Redline or Schaeffers before Pentosin
Cable ties should hold it
Re: vw - adding external trans filter [Re: anderson] #5299917 12/20/19 12:00 PM
P
Pyrotechnic Offline
P
That 33343 fuel filter might work, but the lack of a bypass valve is a bit of concern. Personally, I would not use it unless there was a back pressure gauge on the cooler circuit to warn of an over pressure condition.
The Wix 51515 and its equivalents work great for transmission filters, they have a bypass valve, and it's a common oil filter that can be bought anywhere at any time. For short clean up intervals, any filters that cross to the 51515 p/n will be fine.
The Fram Ultra advertises 20 micron at 99%, which is an excellent option. I've used these on transmissions with good results.The Wix XP is a great filter too, though the parent company has never given us a clear answer on the micron and efficiency rating.
Re: vw - adding external trans filter [Re: anderson] #5300056 12/20/19 02:56 PM
A
anderson Offline OP
A
i think ill only use the 33343 for a day or two to filter the nasty black oil a bit before changing to the 51515xp.
only using wix because its what i keep in stock, its always scary doing the first fluid change on a high mileage transmission. 444.000 kms and not one documented fluid change frown
Re: vw - adding external trans filter [Re: anderson] #5300104 12/20/19 04:03 PM
P
Pyrotechnic Offline
P
Ouch. I would use several spin on filters to help clean up the original fluid, only adding enough fresh fluid to fill the new filter each time. Each dose of detergent rich fresh fluid may loosen up more dirt. Once the fluid starts looking nice on the dipstick, it's likely safe to drop the pan and change all of the fluid.
If you have already have a case of those fuel filters to use up, it may be worth it to tee in a pressure gauge before the filter while you run them.
Re: vw - adding external trans filter [Re: Pyrotechnic] #5302292 12/23/19 09:16 AM
Z
zorobabel Offline
Z
The best way to clean dirty fluid is to change it.
1997 Maxima 210k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 211k, Valvoline SynPower 5W-30, K&N HP-1003
Re: vw - adding external trans filter [Re: anderson] #5302430 12/23/19 12:32 PM
A
anderson Offline OP
A
dropped the pan and discovered a 1/2 inch thick layer of black metalic sludge on the bottom. that explains why when i pulled the drain plug nothing poured out frown
filled with pentosin atf1 and installed the wix filter mount and 33343 on the output line from the trans cooler. also put a hayden cooler on line after the filter leading back to the trans.
we shall see how the trans holds up
Re: vw - adding external trans filter [Re: anderson] #5302431 12/23/19 12:33 PM
A
anderson Offline OP
A
going to change the filter after 500kms to a 51269 for 5000kms
Re: vw - adding external trans filter [Re: anderson] #5320826 01/12/20 02:41 PM
DrSmith Offline
Very interesting, do you ahve any pictures of your setup?
I too am considering using a fuel filter as my transmission oil filter as the micron rating is nice and low.
