Post Your Latest Coolant Change.
04 Buick LeSabre
3.8 v6
Replaced radiator hoses, heater hoses, heater bypass tubes and thermostat, powerflushed radiator, block and heater core, then did a chemical flush
Out: reddish brown crap, water, a little bit of 50/50, qmi cooling system flush
In: 70/30 Napa universal green and water, qmi cooling system conditioner
00 Buick LeSabre
3.8 v6
Radiator and radiator hoses replaced, replaced what came out of radiator
Out: green coolant
In: one gallon Napa universal green full strength
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
2004 CRV 147k
Out-something blue-probably Honda with unknown age or mileage
In-Pride Asia plus mixed 50/50 with distilled water
96 jeep Cherokee
4.0 inline six
Out: unknown green coolant, water, qmi cooling system flush
In: 60/40 Napa universal green and water, qmi cooling system conditioner
2012 G37x Sedan 85,600
Lower radiator hose was soft and had 2-3 pin leaks near block inlet, upper was slightly soft, both needed changing ASAP.
Out: Valvoline Zerex Asian Blue 18months 8k
In: 2 Gallons Valvoline Zerex Asian Blue
Gates Hoses, Gates Thermoclamp (Thanks The Critic!) and Marine grade US made Stainless constant tension clamps on the rest. New OEM Thermostat and gasket, seemed like a good idea given age and mileage on a Nissan. It is below zero now so I committed a mortal sin and paid a local retired Nissan mechanic with his own heated shop, a lift and excellent recommendations to do the job and an oil change and tire rotation with the parts I supplied. Did about 100 miles since, looks like they did excellent work,
P.S. 370z/g37 owners, This is not a repair to put off and hope but I have seen many a 08-09 Z/G's with soft weepy original hoses and $2500 in rims and rubber. Our cars cannot not detect engine temp without coolant in the loop, so if your radiator hoses fail catastrophically and you loose a large amount of coolant while driving it can result in the coolant temperature sensor(s) not being fully submerged in coolant and thus not functional. If that were to happen it's possible you could overheat the car without the temperature gauge indicating an overheating condition.
08 Chevy Silverado 1500
5.3 v8
Drained and filled coolant reservoir
04(?) Pontiac gto
5.7(?) V8
Out: orange coolant
02 Chevy express g3500
5.7 v8
Out: probably dexcool, qmi cooling system flush
09 GMC Sierra
5.3 v8
02 Toyota Tacoma
2.4 4 cyl
Water pump replacement
In: 60/40 prime guard universal green and water, qmi cooling system conditioner
04 Pontiac gto
5.7 v8
Out: probably dexcool, water, qmi cooling system flush
05 Chevy Silverado 1500
5.3 v8
Water pump, radiator hose and heater hose replacement
Out: mix of probably dexcool and some green coolant, water, qmi cooling system flush
1995 Maxima SE - 77k miles
simple drain and refill with new Lisle funnel - yee hah! that funnel is nice!!
out: Nissan genuine green coolant
in: same, mixing 50/50 with distilled water
specification is every 30k or 24 months
94 gmc c1500
5.7 v8
Out: reddish orange water, Clean water, qmi cooling system flush
11 Dodge journey
3.6 v6
Out: presumably factory orange coolant that was diluted with an unknown, white substance, water, qmi cooling system flush
06 jeep liberty
3.7 v6
Radiator, radiator hose and radiator cap replacement, cooling system flush
Out: probably mostly prestone universal green premix, water, qmi cooling system flush
In; 60/40 napa universal green and water, qmi cooling system conditioner
