Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
chapys, DaaBoss, C6H8O7, Jcvjr, Haywood
71590 Registered Users
92 registered members (ABN_CBT_ENGR, 762fermeandyou, 53' Stude, ABerns, 2015_PSD, 8 invisible), 2,472 guests, and 25 spiders.
Topics306,031
Posts5,286,058
Members71,590
Page 3 of 5 1 2 3 4 5
Re: 10,000mi OCI for a 2020 4Runner? [Re: BucDan] #5297218 12/17/19 07:44 PM
T
Triple_Se7en Offline
T
Unless 0W40 appears in the new 4Runners owners manual viscosity chart, I would not use it for the duration of the vehicle warranty.
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: 10,000mi OCI for a 2020 4Runner? [Re: BucDan] #5297328 12/17/19 09:43 PM
Bryanccfshr Offline
This engine runs well on anything I put in it.
Dealer,0w20
Mobil 1 0w40
Havoline DS Pro 10w30.
The owners manual specifically states you can run a higher grade. Bit to be pragmatic, if that is the type of service it sees I wouldn’t have any problem just sticking to 0w20 or higher ILSAC oils For 5 k intervalsand enjoying the reliable, so,I’d vehicle with that amazing Panasonic battery.
I recommend just doing 5 k OCI,s let the dealer due the 10 k changes until done.
After the first oil change I don’t bother changing the filter on the 6 month/5k changes.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: 10,000mi OCI for a 2020 4Runner? [Re: CharlieBauer] #5297381 12/17/19 10:35 PM
M
madeej11 Offline
M
Originally Posted by CharlieBauer
15 minutes in San Diego will be enough to warm things up.
Once a year oil changes will be absolutely ok and required for warranty. Since you'll be nowhere near 10k miles, it will be conservative.
It's a new Toyota and you're in a nice climate. You've paid for peace of mind so enjoy it!
Agree with Charlie. Dump factory fill at 5k then go another 5k. After that just do the Toyota recommended 10k mile oci's. Just take the vehicle out for a half decent run on weekends to offset the short trips and yes stick with the 0w20, it's good oil. After the freebie oil changes are finished I would use Mobil 1 EP 0w20 and stay with 10k oci. Nice ride by the way.
Re: 10,000mi OCI for a 2020 4Runner? [Re: BucDan] #5297467 12/18/19 01:00 AM
O
OilUzer Offline
O
FYI
The 5.7 L V8 Tundra is speced to use 0W20 while towing two 4Runners shocked2
imho, if you want to steer away from 0W20, you will need to use a very good xW30 for example.
I am not a thinnie, however I will take most 0W20's over cheap 5W30's.
Maybe try a 0W30 or a good 5W30 or even 10W30 since you live in San Diego!
Much easier to make an inferior oil with 5W and up as oppose to 0W.
Re: 10,000mi OCI for a 2020 4Runner? [Re: Mad_Hatter] #5297470 12/18/19 01:09 AM
dave1251 Offline
Originally Posted by Mad_Hatter
Is the cost of a basic UOA at 5k miles prohibitive? Get some data then base your decision off it.. you may find that 10k mile oci's work just fine for her. Fwiw I'm not a extended drain fanboi but I think your/her situation is unique.
10K OCI isn't an extended drain. The recommended OCI in the 60's was 6K. Technology has evolved a few dozen generations since then.
don't use.
Re: 10,000mi OCI for a 2020 4Runner? [Re: BucDan] #5297528 12/18/19 04:40 AM
B
BlakeB Online Content
Online Content
B
Severe service is 5k/6 months. You could change the oil every six months and do the oil and filter every other time. If you do an oil drain and fill without changing the filter it takes an even 6 quarts vs 6.6 quarts to change the oil and filter. Dropping the oil every 6 months and putting 6 quarts back in is easy enough because there is an access panel for the oil drain plug. Changing the filter is a pain on these.
[Linked Image]
Re: 10,000mi OCI for a 2020 4Runner? [Re: BucDan] #5297572 12/18/19 06:33 AM
N
NH73 Offline
N
Seems to me that nothing the OP put on constitutes severe driving under what Toyota says. Otherwise, I would stick to a once a year oil change. You may be able to get your 2 free oil changes that way.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: 10,000mi OCI for a 2020 4Runner? [Re: BucDan] #5297577 12/18/19 06:40 AM
A
Amkeer Offline
A
Stick to once a year changes or 10000 miles and 0w/20. You might as well leave the factory fill in there for at least 3000 miles.
Its worth a note that those that change the oil frequently don't hold onto the vehicle long and those that extend the intervals keep them forever.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 107000
2008 Toyota Tundra D Cab 5.7 M1 5-20 100000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 220000 miles
2020 Toyota Camry SE 2.5 600 miles
Re: 10,000mi OCI for a 2020 4Runner? [Re: Amkeer] #5297580 12/18/19 06:46 AM
demarpaint Offline
I change my oil at less than half that interval, in fact in my 32 year old van it averages every 4K miles. I'd consider myself someone who keeps a vehicle forever. My 08 Liberty gets changed every 6K miles, and the 2016 Rubicon every 5K miles. I have no intentions of getting rid of any of them at the moment.
God Bless Our Troops
Re: 10,000mi OCI for a 2020 4Runner? [Re: BucDan] #5297842 12/18/19 10:55 AM
B
BucDan Offline OP
B
Going from 0W20 to 0W40 seems like a pretty big jump. Can't think of a reason why 0W40 would be better. I think just leaving it at 0W20 will be best as it'll be seeing the asphalt 95% of the year and maybe the snowy mountains for a weekend. Ideally, I think it would be best to stick to what Toyota recommends to keep it simple, even though they likely picked that weight for EPA reasons. But if it's working, why change it?
I like that idea about the oil filter though, leave the oil filter in for 2 changes, but since I'll be under there already, I know I'll just tell myself "might as well since I'm already down here".
2013 Audi S4 6MT - 45K miles
- OCI every 5K miles
- Motul X-cess 5w-40
- Mann OEM oil filter
Re: 10,000mi OCI for a 2020 4Runner? [Re: BucDan] #5297857 12/18/19 11:13 AM
O
Oey12 Offline
O
I have a 2017 4Runner with the 4.0. It is my second vehicle and I drive it in two very different ways. First I do a lot of short tripping where sometimes I don’t even get up to full operating temperatures. Secondly when I travel with it, which is typically every other weekend, I do a minimum of 120 miles but usually it’s around 200 miles. And in all honesty I feel that dumping the oil in this truck at 5k is a not necessary. At one year or 10k , these motors will run a very long time. I had a 2012 4.0 Tacoma which is a slightly different motor but I did 10k oil changes on that with 5w30 EP Mobil 1 for 60k with zero issues. I would change that oil filter every 5k. I know many people that severely mistreated those motors and they still run but to each their own...
Re: 10,000mi OCI for a 2020 4Runner? [Re: BucDan] #5298152 12/18/19 03:49 PM
A
ARB1977 Offline
A
Toyota brand 0W20 is a pretty stout oil seen by uoas. My 4.0L in my 15 Tacoma is different from yours and uses 5W30.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: 10,000mi OCI for a 2020 4Runner? [Re: SLO_Town] #5298267 12/18/19 05:34 PM
E
earthbound Offline
E
Originally Posted by SLO_Town
Originally Posted by Danno
If it was mine, 1000 miles on 1st dump, then 5,000 mile oci after that.
^This
Scott
+2...this is how i would roll....
19' Honda Crv 1.5T
19' Ram 1500 5.7 Hemi
06' Pontiac/yoda Vibe
Re: 10,000mi OCI for a 2020 4Runner? [Re: BucDan] #5298277 12/18/19 05:44 PM
N
ndfergy Offline
N
The maintenance schedule through the dealership for our '14 Camry is the first two changes at 8,000km, and after that, every 16,000km. So in your case that raises the question: does cost consideration for the dealership and/or keeping up with the Jones' (competition) outweigh best practice? You won't get a definitive answer on this so go with whatever gives you peace of mind.
2015 Toyota Yaris 5spd Manual
Summer: Mobil Super 1000 10w30
Winter: Mobil Super 1000 5w30
OEM Filter
Re: 10,000mi OCI for a 2020 4Runner? [Re: BucDan] #5298385 12/18/19 08:23 PM
Doublehaul Offline
10k oci M1 0w40
Fram ultra every other change
UOAs to prove it works lol
40wt oil is speced for this engine all over the world and the full saps Mobil (and Castrol) products are on the brink of being 30s anyways. Hugely strong add packs and TBN and they both meet the strictest oil specs on the planet.
Want clean pistons, low cam and bearing wear? See my sig
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
