A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
7500hrs on the cummins
by motor_oil_madman - 02/19/20 06:11 PM
Is It Junk?
by yeehaw1960 - 02/19/20 05:49 PM
Dishwasher makes crackling noise
by jayjr1105 - 02/19/20 05:33 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
81 registered members (2strokeNorthstar, 74Widebody, 14Accent, 2010Civic, Ag76, 7 invisible), 1,700 guests, and 19 spiders.
Topics301,681
Posts5,200,391
Members70,756
2018 Ram 2500 (Cummins) 8268mi, Mobil Delvac 1300 15W-40 CK4, 4227mi sample #5298284 12/18/19 04:49 PM
H
HDoilDude Offline OP
H
Here's my third oil change, this one being the first sample after some pieces of my exhaust fell off and my EGR stopped working right around the 4,000mi mark according to the odometer.
Again, lower mileage sample but it's a bit of a hobby and I like trying out different and sampling different CK4 oils while the engine breaks in (previous change is here )
[Linked Image]
Re: 2018 Ram 2500 (Cummins) 8268mi, Mobil Delvac 1300 15W-40 CK4, 4227mi sample [Re: HDoilDude] #5298522 12/18/19 10:10 PM
I
Impatient Offline
I
It might be better to have one thread, with ongoing results, pointing out what each oil was used in each current and historic UOA. For instance, someone happening upon this post would not know what previous oil was. Someone happening on your previous thread on the ESP UOA, would not know you followed up with another drain / change.
Appreciate you documenting all this, just trying to offer constructive comment....but I am NOT the BITOG gestapo. Heck, I should probably be banned myself for always yammering on.
Also, If you are trying to judge the oil, or your engine’s trending, being more consistent with type of oil used could be helpful (coming from a guy who has jumped around on oil’s quite a bit lately. ). Was there anything you did NOT like about the Delvac ESP from last time? FWIW, I don’t necessarily think you can interpret lower iron this time being because of different oil.
BTW, Thanks for bringing Delvac ESP to my attention; I didn’t know it existed.
15 Ford Transit 250 3.5EB Turbo
07 Subaru OBXT 2.5 Turbo Castrol Euro 0w30
Re: 2018 Ram 2500 (Cummins) 8268mi, Mobil Delvac 1300 15W-40 CK4, 4227mi sample [Re: HDoilDude] #5298660 12/19/19 05:00 AM
dnewton3 Offline
Global Moderator
Global Moderator
Pretty typical results, which is good. Wear coming down as break-in settles.
At some point, if you are interested, you'll want to extend out your OFCIs to gain ROI. I believe Ram suggest 15k miles of "normal" and 7.5k for severe? (if my memory serves).
Also, I took away the other two threads. No need to post three threads all at the same time, when all three UOAs are on this sheet.
BTW - welcome
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2018 Ram 2500 (Cummins) 8268mi, Mobil Delvac 1300 15W-40 CK4, 4227mi sample [Re: dnewton3] #5298755 12/19/19 08:04 AM
H
H
Oh ok, thanks for cleaning up. I just figured people would want to see the different oil flavors in each thread. But I s'pose I can do it all on one thread.
Re: 2018 Ram 2500 (Cummins) 8268mi, Mobil Delvac 1300 15W-40 CK4, 4227mi sample [Re: HDoilDude] #5298764 12/19/19 08:11 AM
H
H
[Linked Image]
Can no longer seem to edit the first post but since the other threads were deleted, FYI, the first analysis was factory fill (possibly a Valvoline 5W-40 synthetic). Second is Mobil Delvac ESP 5W-40 synthetic. Third is Mobil Delvac 1300 conventional. All in CK4.
Re: 2018 Ram 2500 (Cummins) 8268mi, Mobil Delvac 1300 15W-40 CK4, 4227mi sample [Re: HDoilDude] #5298988 12/19/19 12:08 PM
H
H
To the person (in one of the previous threads) who said the Mobil Delvac ESP VOA I posted is different to the (slightly?) used sample in the sheet above, here's the response from Blackstone when I brought it to their attention:
"I would disagree. I think the two samples you mentioned (the VOA and the 3K mile one) do look pretty similar. In addition to the impact from carryover, there's also some slight variation caused by oil not being perfectly homogenous. A few elements are higher in the used oil, but the differences aren't very large, and that's pretty normal."
Re: 2018 Ram 2500 (Cummins) 8268mi, Mobil Delvac 1300 15W-40 CK4, 4227mi sample [Re: HDoilDude] #5299665 12/20/19 07:22 AM
B
Bighorn2500 Offline
B
Interesting in the first UOA which was the factory fill of most likely Valvoline PBE 5w40, I see Barium being used for anti-wear as well it would appear. Z & P seem to be on par with the slightly lowered threshold of most CK-4 HDEO’s lately tested.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: 2018 Ram 2500 (Cummins) 8268mi, Mobil Delvac 1300 15W-40 CK4, 4227mi sample [Re: Bighorn2500] #5301695 12/22/19 03:22 PM
H
H
Good catch, I didn't even make the connection before you pointed it out. Thanks!
Re: 2018 Ram 2500 (Cummins) 8268mi, Mobil Delvac 1300 15W-40 CK4, 4227mi sample [Re: HDoilDude] #5347747 02/12/20 12:40 AM
SavagePatch Offline
Thick Conventional shows better wear results than a Thinner Synthetic in UOA's. Food for thought? 🤔
Or just common break-in trends?
