AC DELCO PF 64 FACTORY FILTER CUT OPEN
In the shop
Good Evening BITOGERS
This filter was off a friends 2020 Chevrolet Malibu. Filter and oil had 4,000 miles on them. Replaced with M1 0w20 and another AC DELCO PF64
Enjoy the photos
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Originally Posted by Chris142
Is metal end caps on an ecore normal?
Maybe becoming normal as few Super Tech filters I cut had metal endcaps
same filter used on girlfriends 13 2.5 malibu that was sucking a qt on a thou or less!!! good luck with yours
Was the sucking caused by the filter?
Not my car as stated in post!
I doubt he meant it like that.
Hey buddy … you should have all of us on ignore and get some Zzzzzzzz's
Interesting filter, I'd call it a hybrid design. Ecore centertube and double baseplate, classic metal endcap with separate poppet type bypass. With the exception of the double baseplate, very similar to the current Super Tech 9688 that's been posted here before. Both made by Champ.
Look fine at 4k miles.
Thanks for c&p.
Nah, most people on here are nice; including you and that cat bbhero
Thanks for c&p.
You are welcome
It's unfortunate Champ/GM does use the silicone ADBV on all it's AC Delco filters. I went a couple decades (mid 80s to around 2005) buying nothing but AC Delco. Then black nitrile ADBVs started appearing on most AC Delco model numbers and that sent me packing-up shop to Motorcraft. Then soon after, Motorcaft started abandoning silicone ADBV. Now I stick to mainly silicone OEM or Wix.
No more K&N, Mobil-1 or Fram TG. Fram wants almost $10 for the silicone Fram TG 9688 that fits my Kia and Hyundai...... ridiculous! They want at least $12 for the Ultra...... no way Jose.
Originally Posted by 53' Stude
Originally Posted by kstanf150
Is this the factory filter ?
Yep
Sorry missed that part
Thanks
Originally Posted by LeakySeals
Wow that looks good. Anybody know what the efficiency is?
The last time I saw efficiency numbers for these filters they weren't all that great, something like 99% at 35-40 microns.
Yep, have been through several PF63E's now (cut them new and used) - all of them well spaced and bonded tight/square - and the nitrile ADBV has been holding back lots of oil from the engine,
(lose about a quart on a filter change).
