Is there a standard or proper way to bleed a cooling system?
I've always just idled the car with the radiator cap off. After a few minutes I top off, close, drive, and check level again once cool. I've also heard of squeezing the upper radiator hose to help purge the system...is this necessary? Lots of cars these days don't have radiator caps anymore. Just pressurized overflow tanks. Does the same procedure work?
Is there any other way that works better?
